Old 06-20-2016, 09:25 PM   #15
el-92
el-92's Avatar
Drives: 2014 ASPHALT FR-S MT
Originally Posted by Racecomp Engineering View Post
Yes sir, more grip means more roll. Swaybars are an easy way to go and an adjustable set gives you some tuning options. Stiffer springs work too.
Remember a little roll is OKAY...but if you're rolling excessively and uncomfortable with the car's handling then yes some swaybars are a good next step.
- Andrew
Cool thanks I'll be ordering your sway bars soon 😎👍🏻
el-92 is offline   Reply With Quote
The Following 2 Users Say Thank You to el-92 For This Useful Post:
Racecomp Engineering (06-21-2016), smg1138 (06-21-2016)
Old 06-21-2016, 07:19 PM   #16
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
- Andrew
@Racecomp Engineering Are the RCE swaybars good for AutoX or mostly designed for track? I've read different things about adding a stiffer bar in back. In currently running a 20mm Whiteline bar up front and stock rear.
smg1138 is offline   Reply With Quote
Old 06-24-2016, 12:11 PM   #17
It depends on the rest of your set-up. For an STX car that's already on coilovers with 400/400 rates, the front 20mm bar is probably all you need. If you were stuck with running softer springs, then I would recommend them.
Also for an SM car on hoosiers, the bars would be helpful IMO.
- Andrew
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
smg1138 (06-24-2016)
Old 06-24-2016, 06:30 PM   #18
smg1138
smg1138's Avatar
- Andrew
Yeah, I'm running in STX on Tarmac 2's with the 400/400 rates. Thanks for feedback.
The Following User Says Thank You to smg1138 For This Useful Post:
Racecomp Engineering (06-25-2016)
coilovers, rce, tarmac, tarmac 2
RCE Tarmac 2 CLUBSPORT and RCE Tarmac 0 coilovers available now Racecomp Engineering Suspension | Chassis | Brakes -- Sponsored by 949 Racing 589 11-21-2021 05:13 PM
***FT-86 SpeedFactory RCE Tarmac 2 Clubsport and Tarmac Zero Sale Thread*** FT-86 SpeedFactory Brakes, Suspension, Chassis 208 09-30-2016 04:43 PM
Recommended tire choice for 18x9.5 +40 all round setup? KruszR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 01-18-2014 04:04 PM
Damper crosstalk ayau Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 08-01-2013 03:21 AM
