#113 | |
Drives: 2013 Subaru BRZ
That being said, 265s are probably overkill for any "reasonable" forced induction power level. |
#114 |
Drives: Used to Drive:Grand-Am GS #54 E36M3
#115 |
Off Topic
For the experts: what is your opinion of a square tire size, but lower offset wheels in the back?
For example, 17x8+45 in the front and 17x8+35 in the back, with 225s all around. |
#116 | |
i'm sorry, what?
Drives: Canada
higher offset means more strain on the bearings and a requirement to get longer studs as well. but you're increasing your track width, which reduces weight transfer by a small amount. just got to think about how all this factors into what you want
| The Following User Says Thank You to 7thgear For This Useful Post: | gramicci101 (06-20-2014) |
#117 |
Been running 18X9.5 for a while now with KW V3's. I would say my car handles significantly better than stock, and rides better, and I'm lowered about 1.6". -2 camber in front, -1.3 in the rear. It's a balancing act.
Yes, they clear in the front with plenty of room. My RP03's are lighter than stock even in a larger size. Car looks great, handles great, can't complain. ![]() This is a good thread and its things like this that helped me plan out how I wanted my car to turn out. When you cheap out on coilovers, you realize the mistake you made once you put on a more expensive, more adjustable, more reputable set. That's only part of it. Adjusting it properly is the next part. I may look at other parts to further improve my ride with bushings. |
#118 |
i'm sorry, what?
Drives: Canada
so you have before and after lap times? How have your autocross times changed after the upgrade? when you changed suspension did you also change the tires?
#119 | |
Haven't put my car on the track to see. It's a street car more than anything. |
#120 | |
i'm sorry, what?
Drives: Canada
so how do you know if your cars handling is actually improved? Having a lower car with a stiffer ride certainly translates your inputs quicker, so you feel like the car is more responsive, but until you start navigating the car at the limit I'd caution about making claims of "significant" handling improvement.. a lot of which can be attributed to a tire change more so than suspension. the key point is to be very specific with the descriptions. A car with crisp response is more specific than the more generic "handling"
#121 |
245/45 is pretty tall.
Website
https://www.racecompengineering.com/ Instagram: https://www.instagram.com/racecompengineering https://www.instagram.com/theapexfiles <- tech articles |
#122 |
Off Topic
The weight transfer thing confused me, until I realized you meant side to side, not front to back.
#123 | |
- Andy
Website
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | SStratos (04-19-2016) |
#124 | |
- Andy
Website
#125 |
Drives: 1993 Impreza w/ WRX Swap + FWD!
Sure.
With the tires/wheels, springs, swaybars I have now the car is indeed capable 15-20% faster speeds in corners. But the progressive handling charecteristics are gone. This is what I would classify as a "grip" setup now, and when that grip does finally give way, its much more sudden and less controlled. Nothing at all like it was before. The lost off some suspension travel and the rear swaybar have also caused the rear inside tire to lift more in cornering which is not what you want in a RWD car with a LSD. I think a better (very expensive) suspension setup might be able to compensate for this, but at the same time might change the car even more. |
#126 | |
Drives: 370z
| BRZ Limited Backup Camera Step by Step (WARNING long post, many pictures) | runny_yolk | Electronics | Audio | NAV | Infotainment | 120 | 01-29-2021 07:18 PM |
| step 1 :buy frs in phx, step 2: drive to pikes peak | haymaker | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 15 | 08-21-2012 11:44 AM |
| [StreetFX] License Plate LED light upgrade, and DIY step by step guide (GT and GTS) | WTF | Australia Classifieds | 0 | 07-11-2012 12:38 PM |
| [StreetFX] BRIGHT Boot/Trunk LED light upgrade & DIY step by step guide (GT and GTS) | WTF | Australia Classifieds | 0 | 07-11-2012 12:27 PM |
