Old 08-02-2016, 09:02 PM   #519
EffaressNOOB
EffaressNOOB's Avatar
Drives: Halo 2016 Scion FR-S, 6MT
IAM = advance multiplier
Ignition advance is total ignition timing
IAM at 0.9 is acceptable but not good, on E85 you should be iam=1 as you should have no knock
I just filled up my 3rd tank of E85. During my 2nd tank, my LTFTs during idle and cruise are within +/- 5%, but my IAM=0
I don't hear or feel anything wrong with the way the car drives. Do I only check IAM during WOT or should it be at 1 the whole time?
Enkei TFR (Copper) 17x9+45 | Hankook Ventus V12 Evo2 245/40 | Tein Flex A
OFT Stage 2, E85 | Kraftwerks Skunk2 CAI
Open Flash Unequal Length Header
Invidia N1 CatBack
InstaGram: 49RJ
EffaressNOOB is offline   Reply With Quote
Old 08-02-2016, 10:43 PM   #520
steve99
Im pretty sure iam is not logging correctly if its zero, some leter model cars oft logging of some parameters does not work correctly
Iam should be one all the time, but i think its just monitoring incorrectly
you should see ignition advance at about 32 degrees at full throttle higher rpm if so your not pulling any timing and iam os actually 1..
EffaressNOOB (08-03-2016)
Old 08-03-2016, 04:04 PM   #521
EffaressNOOB
Ok, I'll check on the IGN ADVANCE tonight when I drive home. I also noticed that I may be able to ADD or SUBTRACT the IAMs manually through the tablet itself? good or bad idea? lol!
Invidia N1 CatBack
InstaGram: 49RJ
Old 08-03-2016, 06:13 PM   #522
steve99
yes you can add and remove monitoring\logged parameters on oft, not much point monitoring iam if it not logging correctly, tell the oft guys they may update oft software to fix.
Old 08-04-2016, 03:27 AM   #523
EffaressNOOB
Originally Posted by bleox View Post
Btw I meant -7.5.....Yeah it is my first tank of e85...I'm check it out I only have like 25 miles on this tank so far, I'm drive a lil more i rushed from the old tune to the e85 tune...STFT raised a lot and nothing was happening in the LTFT because according to guide it states shortly after it should increase nothing was happening and I switched over ...I think think I made the jump to the e85 to son and some gas aka petrol was still left in the lines or where ever the LTFT sensor is lol
Has your LTFT gotten any better? During my first tank @ 70mph, I was in the high -8% range. Now on my 3rd tank and I'm at -3.5% @ 3000rpm and +6% @2500rpm
@steve99
At wot on 2nd and 3rd gear, my ignition advance is right at 32 degrees and my AFR is around 12:1, but IAM is still at 0. I'm hoping it's a software issue. Nothing to worry about right? I'll give @shiv and his team a holler to see what they can do about an update..... Thanks again
Invidia N1 CatBack
InstaGram: 49RJ
Old 08-04-2016, 03:56 AM   #524
steve99
@steve99
Ok that advance and afr sound spot on for e85 tunes, the iam at 0 is definitly a bug in oft logging setup each rom calid has different ram addresses for logged parameters
if iam was actually O the advqnce would be much less and the car likey in limp home mode
EffaressNOOB (08-04-2016)
Old 08-25-2016, 06:08 PM   #525
TilesMeague
TilesMeague's Avatar
Drives: 2013 SSM BRZ
If I picked up a 5w-20 e85 rated oil, would it be compatible for flip flopping between e85 and 91? E85 isn't widely available in my area.
Drop several gears and become slightly further away
TilesMeague is offline   Reply With Quote
Old 08-25-2016, 10:23 PM   #526
steve99
Should be fine if is SN or GF5 rated
TilesMeague (08-28-2016)
Old 08-25-2016, 10:53 PM   #527
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
@steve99 off topic question, but I'm thinking of mixing some E85 into our (crappy) 98ron fuel to achieve approx E10....question is, how many litres of E85 would do you need to fill in order to achieve this?
Currently running OFT350 tuned for 98 only, but adding some E85 would surely help in the summer months later on.
Fizz is offline   Reply With Quote
Old 08-25-2016, 11:33 PM   #528
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
It's going to be less painful and much safer to tune the car properly than calculate and mess up a different mixture of E% every fill up and have the AFR skewed during the 100km or so it takes for the LTFT to catch up.
The Following User Says Thank You to Wayno For This Useful Post:
Fizz (08-26-2016)
Old 08-25-2016, 11:34 PM   #529
steve99
depends which E85 your using.
United E85 is actually 85% consistent and mixed with premium petrol
Caltex Eflex is minimum 70% but varies but mixed with low grade petrol.
For what you want United will be far better option.
To achieve aprox 10% E content in a full tank of 98 (assuming the 98 is ethanol free) you will need to add aprox 6 litres of united E85 to a full tank of 98 petrol (ie 50 litres)
calcs
united E85 is 85% ethanol so 6L of united E85 contains 6*0.85 litres of ethanol =5.1 litres of ethanol in the 6 litres of E85.
car holds aprox 50 litres so for 10% you need 5 l of ethanol added so aprox 6 litres of united E85 then fill tank with petrol.
generally your not going to be fully empty, even on low fuel light there is about 10L of fuel left. so if your at low fuel light of close you will only need about 5 litres of E85 then fill tank.
Fizz (08-26-2016)
Old 09-05-2016, 07:01 AM   #530
yip
Drives: 1997 Chevy S10
Been running OFT/E85 for about 5 months now and never had an issue until my last tank of gas. At about 1/2 tank I felt the car start to hesitate at throttle tip in and a dull popping sound a few times. It also felt like when i was WOT there was resistance like I was carrying 2 passengers or a feeling of drag.
Was thinking maybe it was just me but I drove it down to pretty much empty and filled up again and it felt like normal again right away and haven't felt any of the previous issues since.
yip is offline   Reply With Quote
Old 09-12-2016, 03:57 AM   #531
Camsheim
Hachiroku
Camsheim's Avatar
Drives: GT86 AT Mid 2012
Hi guys,
I have flashed the E85 Stage 2 EL to my car (Mid 2012 AT with just the HKS Hybrid Filter)
This is the datalog after 50km/30mi (1st Tank , approx 6/7L RON98 left before refueling)
Can you check my datalog ? it seems ok but i have some doubts with the knocks (Negative ?)
http://www.datazap.me/u/camsheim/e85...-8-10-11-12-14
Thanks
Camsheim is offline   Reply With Quote
Old 09-12-2016, 08:54 PM   #532
steve99
Originally Posted by Camsheim View Post
Hi guys,
Thanks
cannot access the log did you click the public option ?
Camsheim (09-23-2016)
Search this Thread:
Advanced Search
Stock FR-S Tune Just Done Zach3794 Engine, Exhaust, Transmission 67 11-05-2017 03:01 PM
stock BR-Z, much detonation during shifts: tune? elefunkd Engine, Exhaust, Transmission 69 07-26-2013 05:20 PM
Anyone have a stock tune from Visconti? Bleevin CANADA 3 07-03-2013 02:01 AM
My Initial (all stock) BRZedit tune mad_sb Engine, Exhaust, Transmission 6 02-16-2013 01:20 PM
Save stock tune with ecutek? gdrider77 Engine, Exhaust, Transmission 7 01-06-2013 01:50 AM
