#379 |
Drives: 2013 Scion FRS
Just updating precoous info in switching back to 93 while i was still on e85 tune with 93 in tank right after fill up ltft dropped to about 14% i know when ltft changed i am supposed to switch to the other tune but it dropped to almost normal levels while on e85 i am very co fused here? Can i get your input on this please
#380 | |
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
#381 | |
Bottled FRS
Drives: 2016 manual frs
here's my log could you take a look please? http://www.datazap.me/u/texas2016frs...7-8-9-10-11-12 |
#382 | |
it looks ok from what i can see, some of the parameters like iam are not logging correctly appears the oft logging for the 2015 some parameters not working correctly. it very light throttle but it looks ok. maybe do a short full throttle from 2000-5000 and see what that looks like_ You should see afr getting down to 13 and into 12 past 4000 or so. |
| The Following User Says Thank You to steve99 For This Useful Post: | Texas2016Frs (12-30-2015) |
#383 | |
Bottled FRS
afr does get down to 12 anything else i should look for? thank you for your help! |
#384 |
#385 | |
Bottled FRS
here is a log of a few wot accelerations, if you have time please take a look (: http://www.datazap.me/u/texas2016frs...7-8-9-10-12-14 |
#386 | |
no knock indicated, dont worry about the iam being zero looks like oft logging issue are you on latest openflash manager and template files from oft downloads site ?? |
#387 | |
Bottled FRS
Thanks for taking a look! |
#388 | |
with very high fuel trims previouisly its possible the wrong tune was flashed, if all thats changed since last log, ie you havenot refilled tank |
#389 |
Bottled FRS
I know that it's the same tune because I took great care (checked like 5 times) to make sure I put the right tune on and then also checked after it was flashed to the car any ideas?
#390 |
Bottled FRS
#391 |
Wow 40 yep you could expect the lower end fuel trims to vary maybe 5% with uch a big change, it probably the residual petrol in tank as well and trims averaging out but looks ok now, the lower end fuel trims vary more as at idle and low speed temps vary widly under bonnet especially in hot weather.
#392 | |
Bottled FRS
Do you think that once the ecu learns the trims again it will run less rich? |
| Stock FR-S Tune Just Done | Zach3794 | Engine, Exhaust, Transmission | 67 | 11-05-2017 03:01 PM |
| stock BR-Z, much detonation during shifts: tune? | elefunkd | Engine, Exhaust, Transmission | 69 | 07-26-2013 05:20 PM |
| Anyone have a stock tune from Visconti? | Bleevin | CANADA | 3 | 07-03-2013 02:01 AM |
| My Initial (all stock) BRZedit tune | mad_sb | Engine, Exhaust, Transmission | 6 | 02-16-2013 01:20 PM |
| Save stock tune with ecutek? | gdrider77 | Engine, Exhaust, Transmission | 7 | 01-06-2013 01:50 AM |
