Old 01-27-2015, 08:02 PM   #183
itsjustdavep
itsjustdavep's Avatar
Drives: Asphalt Scion FR-S
I fell silly steve. IAM?
2013 Asphalt HRI Tuned-K&N DropIn-Tomei UEL-Tomei OP-Invidia FP-Nameless Muffled Trackpipe...and corn
itsjustdavep is offline   Reply With Quote
Old 01-27-2015, 08:31 PM   #184
steve99
ignition advance multiplier
have a read of first link below it will explain logging parameters
Old 01-27-2015, 10:03 PM   #185
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
Ah that's how you guys do that. Also I totally meant CANT feel difference in the butt dyno
along with what steve said, if you have a good stock (3rd gear run from 2k to 6 or 7k rpm, and include IAT, TIME, Eng RPM, and throttle in the log, you can do a similar run after switching over, and compare the time it takes to get from X(low) rpm to Y(high) rpm, and similar IAT's will keep you honest.
for example here is one I did from stage 1, to stage 2 E85 + ESC:
*Edit: you want to try to run on the same road(flat if possible) with similar temps to produce the most accurate comparison.
Originally Posted by Target70 View Post
Just logged a run on E85 before I go back to 93. I compared it to one of my old logs, both are 3rd gear pulls from 2k to about 7,100 rpm. Quite the difference:
pic one is Stock car with K&N filter, stage 1 V1.5 OFT tune on 93 at about 70 degrees ambient.
pic two is K&N filter, OFH, stage 2 V2.X E85, ESC TQ250 dump 2.0 with about 30 pulls on batts, that are semi warm, at 50 degrees.
the middle line in the first pic is 8.2 seconds from start of run, to give a reference point to the 8.2 second total run time of the ESC log
Old 01-27-2015, 10:41 PM   #186
itsjustdavep
so hows this look? o.0
http://datazap.me/u/itsjustdavep/e85...g=0&data=0-1-3
Old 01-28-2015, 11:57 PM   #187
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
Still a noob myself but I'm learning...
IAM steady at one which is good, no FLKC or Knock Correction also good.
Running a little bit rich @ 11.25 AFR on your wot pull.
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
Old 01-29-2015, 12:46 AM   #188
itsjustdavep
So according to this video I went from 30 in 2nd to wot at 100mph in 16 seconds. That was on a cold snap night down hill at a full tank. I didn't do anything today, so I still got a full tank.
Let's see how much time from 30 to 100 has been knocked off
[ame]http://youtu.be/uXXVtYJUxO0[/ame]
The Following 2 Users Say Thank You to itsjustdavep For This Useful Post:
IDFWU 420 (01-29-2015), Kronos (01-29-2015)
Old 01-29-2015, 12:55 AM   #189
Kronos
Kronos's Avatar
Drives: Asphalt FR-S MT
Nice run. I can't wait for it to warm up so I can switch back to e85.
Kronos is offline   Reply With Quote
The Following User Says Thank You to Kronos For This Useful Post:
Takumidesh (09-26-2017)
Old 01-29-2015, 12:59 AM   #190
itsjustdavep
That video was from when I was rock stock. I better see at least a full second shaved off lol
The Following User Says Thank You to itsjustdavep For This Useful Post:
Old 01-29-2015, 01:34 AM   #191
IDFWU 420
Honarary Member
IDFWU 420's Avatar
Drives: 2015 FRS
What mods do you have on now?
IDFWU 420 is offline   Reply With Quote
Old 01-29-2015, 01:35 AM   #192
Kronos
Kronos's Avatar
I'm curious to know too
Old 01-29-2015, 01:35 AM   #193
itsjustdavep
Still stock. Dirty air filter. Needs oil change.
I'm just running the v2.06 el e85 tune with some shell e85. I just got home so I'm gonna pull the log
Old 01-29-2015, 01:38 AM   #194
itsjustdavep
I drove 15 minutes past the local spot where us knuckleheads race to get to that same on ramp. These toll booths are killing me. A dollar, everytime.
Old 01-29-2015, 02:10 AM   #195
itsjustdavep
edit: got it working. pulled log. run was cut short at 97 mph because my V1 went off butit was under 13 seconds, so a 3 second shave off seems kind of drastic...?
http://datazap.me/u/itsjustdavep/30-...log=0&data=0-9
Old 01-29-2015, 02:24 AM   #196
Phantobe
Phantobe's Avatar
woooooooooooo
Mine did that too, I just closed OFM then reopened it.
Search this Thread:
Advanced Search
Stock FR-S Tune Just Done Zach3794 Engine, Exhaust, Transmission 67 11-05-2017 03:01 PM
stock BR-Z, much detonation during shifts: tune? elefunkd Engine, Exhaust, Transmission 69 07-26-2013 05:20 PM
Anyone have a stock tune from Visconti? Bleevin CANADA 3 07-03-2013 02:01 AM
My Initial (all stock) BRZedit tune mad_sb Engine, Exhaust, Transmission 6 02-16-2013 01:20 PM
Save stock tune with ecutek? gdrider77 Engine, Exhaust, Transmission 7 01-06-2013 01:50 AM
