Old 06-08-2014, 07:24 PM   #15
PollosHermanos
PollosHermanos's Avatar
Drives: 2014 SWP BRZ Limited 6SP
Originally Posted by blackhawkdown View Post
same here, just horror stories about VW in general. we had a 2003 jetta that had a lot of electrical issues, sold that bitch quick after constantly fixing it.
Well, former VW owner here. I had a 2011 2DR base GTI untill December of last year when I sold it and bought the BRZ.
Mechanical Mods:
CAI
APR Stage I ECU Flash (@ 7k miles)
S3 Short Shifter (OEM part, comes from said S3 in europe)
Replica HID projectors
Here is a list of things that I had to get addressed on the car in the 27k I owned it (1.5 years):
  1. Water Pump Failure replaced under warranty at 11k. Revised parts known to fail as well, similar to crickets in the 86 they just don't seem to get it right.
  2. Broken wire in the MAF bundle I removed my CAI in prep for a sale and a wire in the harness broke somewhere between the harness and the ECU. Blamed on me since they knew I had modded the car, paid $350 to have it diagnosed and repaired.
  3. Random hard idle/blinking CEL Had it towed to the dealer with 5 codes being thrown, one cam timing code (caused the blinking) and one for each cylinder's misfire. Dealer cleared codes, found no issue. They chalked it up to not being warmed up before it was driven
I tuned the car and did tinker a little so I can't say any of that was the cars fault with the exception of the water pump. Otherwise it was a blast to drive and so versatile. I autocrossed, moved, hauled everything I could imagine, and also got a decent 0-60 time.
Had held on to it I'm certain I would have had to do something somewhat major, even if it was as predictable as the carbon cleaning of the valves due to the DI engine. That was something owners saw at 50k or as late as 75k but would be something every owner would have to deal with eventually.
If the Golf R wasn't so damned expensive I could see us getting one as our next car. The interiors really are amazingly nice and quite comfortable.
1990 Laser RS - Lights go up, lights go down ||1992 MX-6 Coupe - Hah ... no || 2001 Integra GSR - Almost rice. Risotto || 2003 IS300 - A nice car but no fun. || 2011 Stage I GTI - Lots of fun. Would buy another
2014 BRZ - That BRZ. So hot right now.
PollosHermanos is offline   Reply With Quote
Old 06-08-2014, 07:33 PM   #16
PollosHermanos
Oh and back on topic ...
I think the Mk7 will be a great car, really it comes down to what the small pain in the ass things are that they inevitable overlooked. We all have them of course, just depends on if you can live with them.
Comparing these two cars is very hard to do - they are so very different experiences. That being said I haven't driven a Mk7 and from what i understand the dynamics are quite different if you get the power pack and diff. package.
People will cross shop them with the 86 but I personally don't think they will have too many buyers in common. I bought the BRZ because my fiance got a civic so I could have a car that wasn't as practical; otherwise I would have been a one car guy and the BRZ wouldn't have been a possibility.
Old 06-08-2014, 08:10 PM   #17
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
The Mk7 Golf GTI for the US is not the same as the one for RoW.
The car is being made in Mexico, the engine will not come with multi-port injection only direct injection (10hp less and carbon build-up?), no fancy rotary valve thermo mgmt unit but a simple thermostat, smaller LCD on the headunit, no LED taillights, no sliding cover over the cupholders, it does come with a manual handbrake and not an electronic one but then the center console looks really cheap as a result.
Typical VWoA last minute cost cutting.
The new Mk7 Golf also comes with a plastic oil pan and steel lower control arms and no longer aluminum. But the MQB does have aluminum on its structure to keep the weight down. Performance Pack coming by the end of the year.
After owning a Mk5 Golf GTI which was a total disaster (DV rubber diaphragm rip, PCV keep going bad almost blew off the valve cover with pressure build up, HPFP cam follower wear, DSG skipping gears, weak subframe bolts causing it to shift to the point the bolts can be loosen by hand, broken power lumber and power door locks, MFD2 GPS and iPod interface constantly freezing, DVD drive motor grinding noise, etc), no thanks I will stick with Subaru / Toyota.
krayzie is offline   Reply With Quote
The Following User Says Thank You to krayzie For This Useful Post:
juliog (06-08-2014)
Old 06-09-2014, 01:24 AM   #18
DSOmegaX
DSOmegaX's Avatar
Test drove the Mk7 yesterday (starting the search for a second car), and while there's apparent cutbacks from the Euro-model, it still felt great and a good improvement over the mk6 (which I loved), which I previously owned.
Granted for the same price, my choice at the moment is still a WRX. Really with VW its hit or miss. I've heard and seen horror stories with many friends' cars but can say that mine was hassle-free with the exception of a blown coilpack (which is very common anyway). My Mk6 was pushing 300hp at the time too so really YMMV.
At the end of the day, really all you can do with any car is treat it well and properly maintain it. You'd think with all the problems people post of the FRS/BRZ that no one would buy those. It's the same line of thinking; every manufacturer has its issues; some just get blown out of proportion.
@dsomegax.cars
Old 06-09-2014, 01:51 AM   #19
FRSpappa
FRSpappa's Avatar
Drives: 2014 FR-S Whiteout
FRS/BRZ vs 2015 Golf GTI
Had two CRX Si's so done the FWD thing and not going back! Have a Corvette and FRS now and my other rides are rear wheel drive. Coworker awhile back had to get the dealer to take his VW back under the Lemon Law so don't think I would buy one...
FRSpappa is offline   Reply With Quote
Old 06-09-2014, 06:20 AM   #20
blackhawkdown
blackhawkdown's Avatar
Drives: 2012 WRX, 2003 RSX Type S
Went AWD turbo and never went back to FWD. Gonna go RWD now for some change.
Sent from my GT-N5110 using Tapatalk
Originally Posted by fatoni View Post
saying they wanted to add weight to improve handling is like saying people wear condoms to improve sex.
blackhawkdown is offline   Reply With Quote
The Following User Says Thank You to blackhawkdown For This Useful Post:
FRSpappa (06-09-2014)
Old 06-09-2014, 07:06 AM   #21
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
Ordered a new Golf R for my wife as our "family car". Can't wait to get it but October delivery as we wanted a Oryx paint and leather - damn it. Might also be an issue that I need a RHD car too.
nzer is offline   Reply With Quote
Old 06-09-2014, 07:41 AM   #22
PollosHermanos
Yep. With all the "CATASTROPHIC CAM TENSIONER FAILED ZOMG" threads you'd think the Mk6 was a doomed platform as well.
Message boards can be a great source of data ... but in most cases there is a lot more smoke than real fire.
Old 06-09-2014, 11:40 PM   #23
krayzie
Drive From Home
krayzie's Avatar
LOL you gotta love German Engineering.
Most of the local forum peeps used to pull the EA113 2.0T HPFP out to check for cam follower wear after 40,000km and the amount of wear was insane (mine included) especially on chipped cars. After the class action lawsuit, it became a 10 year / 191000km warranty item. My local dealer even stocks a spare BPY engine just in case.
There was also a time when the first EA888 2.0T came out on the 2009 MkV GTI and engines were blowing up prior to or just after delivery. VW instructed the dealers to break in the engine at high speeds on a good 20 mins highway run as part of PDI.
Old 06-10-2014, 09:52 PM   #24
Lonewolf
Lonewolf's Avatar
Drives: Moped
Except that when reliability studies year after year back up those anecdotes and issues blown out of proportion, then its not really an apples to apples comparison. I would rather have crickets and leaky taillights (common problems with the FRS) than repeated and mysterious electrical and sensor issues that leave me stranded or without headlights...(see several Audi/VW issues over the years)
Old 06-18-2014, 01:36 PM   #25
Jose_Timberlake
Jose_Timberlake's Avatar
Drives: Scion FRS 2.0 6AT
x3! I remember coming across this article not too long ago and it was pretty spot on:
http://dougdemuro.kinja.com/german-r...mer-1572026115
As sophisticated looking and sturdy as those V-dubs might be, I'll stick with my FR-S
Jose_Timberlake is offline   Reply With Quote
Old 10-16-2015, 01:43 PM   #26
iwantafrs
Drives: GTI
GTI > BRZ.
I just bought my GTI a few days ago and love it! I test drove the BRZ at 3 Subaru dealerships and it only took one shot at the Volkswagen dealership to get me hooked to the Turbocharged GTI. The BRZ doesn't give me the wow factor like the GTI does. The interior reminds me of a luxury Audi. The overall quality was better build. I also feel like the metal used to build the fenders and frame for the GTI is stronger than the BRZ.
Hello fellow ft86 members.
iwantafrs is offline   Reply With Quote
Old 10-16-2015, 02:12 PM   #27
RIP.S2000
RIP.S2000's Avatar
Drives: 2015 BRZ Series.Blue, ('00 S2000)
Originally Posted by iwantafrs View Post
GTI > BRZ.
But does it pass emissions...? Haha I'm kidding man. I had the same dilemma but I ended up going with the brz. I liked the power from the gti but the handling on the brz is what took me. Congrats on your purchase. Now your name should be iwantanfrsdroveabrzbutboughtagti
Sent from my SAMSUNG-SM-N910A using Tapatalk
RIP.S2000 is offline   Reply With Quote
Old 10-16-2015, 02:35 PM   #28
JS + BRZ
Drives: 2010 MS3
GTI > BRZ.
Nice feelz man. Feelz.
JS + BRZ is offline   Reply With Quote
Search this Thread:
Advanced Search
Golf Bag mattyboy311 Scion FR-S / Toyota 86 GT86 General Forum 21 06-17-2019 02:01 PM
Nissan to enter 2015 24 Hours of Le Mans + 2015 FIA WEC mav1178 Other Vehicles & General Automotive Discussions 1 05-23-2014 11:47 PM
86 vs 15 Golf R ? Whitigir FR-S / BRZ vs.... 69 02-01-2014 05:15 PM
Used Golf R32 or less used Golf R? Trashed675 Other Vehicles & General Automotive Discussions 32 01-24-2014 10:42 PM
Specs drop on 2015 Volkswagen Golf R for NA Sport-Tech Other Vehicles & General Automotive Discussions 5 01-09-2014 10:27 PM
