View Poll Results: How modified is your FR-S/BRZ/GT86?
Bone Stock 28 13.33%
Light cosmetic modification 38 18.10%
Light performance modification 19 9.05%
Light cosmetic and performance modification 78 37.14%
Substantial cosmetic modification 4 1.90%
Substantial performance modification 13 6.19%
Substantial cosmetic and performance modification 22 10.48%
Extreme cosmetic modification 1 0.48%
Extreme performance modification 3 1.43%
Extreme cosmetic and performance modification 1 0.48%
My car is too modified to drive on the street 3 1.43%
Voters: 210. You may not vote on this poll
Old 05-28-2014, 11:06 PM   #29
STV3
Señor Member
STV3's Avatar
Originally Posted by WhiteRose View Post
Do you know if ft86speedfactory has custom el headers?
Sent from my SM-N900V using Tapatalk
Don't believe so. There are a ton of EL header options out there so I don't see them making a set of their own.
STV3 is offline   Reply With Quote
The Following User Says Thank You to STV3 For This Useful Post:
WhiteRose (05-29-2014)
Old 05-28-2014, 11:21 PM   #30
monkie
monkie's Avatar
Drives: 86 GTS
I went with Substantial cosmetic modification, hope it was correct
Cosmetic
APR Carbon fibre front lip
APR Carbon fibre Side Rocker Extensions
APR Carbon fibre Rear Spats
APR Carbon fibre Rear Diffuser/Overlay
APR Carbon fibre Brake Ducts
Work XT7 18 x 8.5 +38 Front
Work XT7 18 x 9.5 +38 Rear
235/40/18 Square tyres
MCA Blue Coil overs
Project Mu Super 7 locknuts
Toms Tail lights
Beatsonic Sharkfin
30% Tinted windows
Opticoat
LED light upgrades
JPM coachworks hood cluster
Tada-San signed dash
Performance so far only starting now
Perrin 2.5" Catback Exhaust
Thats all I can think off the top of my head most likely forgot things
monkie is offline   Reply With Quote
Old 05-28-2014, 11:46 PM   #31
Quentin
Drives: ‘16 4Runner, ‘19 Corolla HB
My FR-S isn't here yet, but I already know what I'm going to do mod wise.
TRD exhaust - sound and aesthetics (maybe performance... that is debatable)
TRD air filter - performance (minor)
TRD sway bar set - performance (minor)
Prodrive GT1 wheels - aesthetics (performance is a wash, IMO)
Summer tires - aesthetics and performance (more grip, but likely worse accel due to weight)
If I buy out my company lease, I might do some more permanent things like the Cusco steering wheel and TRD ducktail rear spoiler.
Quentin is offline   Reply With Quote
Old 05-29-2014, 10:30 AM   #32
Mister
Mister's Avatar
Drives: Firestorm FRS
Light cosmetics, the $$ is starting to pile up but if someone who was not a twin owner were to sit in my car, I doubt they would notice it is not stock:
Heated Seats
Heated Seat Plaque by YoSpeed
JDM red stitched knee pads
JDM red stitched speaker panels
JPM red stitched leather gauge hood
TRD Shift knob
JDM red stitched e-brake boot
BRZ Trunk Liner
BRZ Spoiler
BRZ Auto-dimming mirror
MLV/GTMAT sound deadening in the trunk (floor pan coming soon)
Perrin Inlet Hose (sound tube delete)
Once I finish sound deadening in the floor pan I am going to be doing more performance modifications, with the goal of 190-200whp at OEM or near OEM sound levels.
I had a friend of mine in the car the other day and they commented what a nice interior the car has, mission accomplished! I would not mind getting a 2014 touchscreen HU just because I hate the looks of the stock radio, but still waiting until good deals/better prices on this show up.
Mister is offline   Reply With Quote
The Following User Says Thank You to Mister For This Useful Post:
NWFRS (05-29-2014)
Old 05-29-2014, 11:07 AM   #33
Dream20b
Y u do dis?
bone stock atm.
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
Old 05-29-2014, 11:08 AM   #34
STV3
Señor Member
STV3's Avatar
Heated Seats
TRD Shift knob
BRZ Trunk Liner
BRZ Spoiler
How exactly did you go about installing these if you dont mind me asking. Did you use the stock seat heaters from the BRZ or Monogram FRS?
Old 05-29-2014, 11:13 AM   #35
Mister
Mister's Avatar
I posted this somewhere else as well. I should really post a DIY or something for it with more detailed information. I did not use the BRZ/Monogram parts as they were absurdly expensive. I did it for <$100. This is a response I had to someone else a last month...
Np. I meant to do a write up, but when I was doing it my phone was dead so no pictures.
I used this kit:
http://www.amazon.com/gp/product/B00B1DCKL2/
It comes with heating pads, switches, and regulators.
I took the seats out of the car and pulled up the upholstery on it just enough to slide these underneath. The fabric is just held on by plastic clips and metal rings. You can use special tools for the metal rings or you can just yank them out and replace with zip-ties on reassembly.
I took apart the center console (there are a couple DIY for this on the forum) and tapped the 12v supply that goes to the Aux port. I used regular wire tapping hardware from the store, no wire stripping involved, and wrapped it up good and tight with electric tape.
Run the wiring under the carpet while the seats are still out and re-install.
The passenger seat has a air bag sensor which will be triggered by the heating pad, it does not matter if you put it above or below the sensor. You can either get the warning light/sound disabled, leave the pad out, or find a good way to insulate it from the capacitive sensor. I have found in my research that a Teflon fabric should be good enough to isolate the sensor from the heating pad, but have not had a chance to try it yet.
I installed the switches in the OEM location. With my great foresight I saw I would never cut nice neat holes so I bought one of the BRZ Limited Center Console plaques by YoSpeed. The switch is a bit bigger then OEM so it slid right on top of the template and looks perfect. I plan to post some pictures in the next couple of weeks.
STV3 (05-29-2014)
Old 05-29-2014, 11:24 AM   #36
DarkSunrise
DarkSunrise's Avatar
Mine is lightly modded at the moment, mostly for the track.
Current mods:
- 17x8 TSW Nurburgring
- 215/45/17 Sumitomo HTR ZIII
- Stoptech SP pads
- ATE Type 200 brake fluid
- Perrin CBE
Next step in mods will be similar, just upgraded a bit.
Next mods:
- 235/40/17 Nitto NT05
- Hawk HP+ pads
- Whiteline camber bolts
- Whiteline differential inserts
- FT86SF catted UEL header
- Nameless OP/DP combo
- custom tune
And after that, I'll be looking to substantially increase performance.
More mods:
- 245/40/17 Hankook RS3
- 17x9 Enkei RPF1
- RCE T0 coilovers
- Carbotech XP10 pads
- JR Supercharger
- Exedy stage 1 clutch + flywheel
2022 BRZ Build
2013 FR-S Build
Old 05-29-2014, 11:42 AM   #37
cwb48
cwb48's Avatar
Drives: 2013 FR-s Firestorm
I voted bone stock, but I actually have two mods- plugged the soundtube and bought the $50 trunk lid liner.
cwb48 is offline   Reply With Quote
Old 05-29-2014, 11:52 AM   #38
Mikem53
Drives: FR-S 6MT
Two mods ... I'm done.
Nameless axleback exhaust. So it sounds as good as it looks.
Rexpeed convex side mirrors. To ease the blind spots
Mikem53 is offline   Reply With Quote
Old 05-29-2014, 11:57 AM   #39
Annahra
Annahra's Avatar
Drives: 2014 WRB BRZ LTD
Does it count as a mod if it was an option on some cars but you added it later? I'm always curious about this when I see some build threads.
Annahra is offline   Reply With Quote
Old 05-29-2014, 08:59 PM   #40
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
I think mine counts as substantial performance
Innovate Supercharged with 70mm pulley
Nameless intake tube
Nameless header, 3" op/fp, and 3" exhaust
Tomei 2 way
4.56 ring and pinion
Aluminum carrier bushings
ACT clutch & flywheel
Full Blown radiator and fan shroud with SPAL fans
Dustin is offline   Reply With Quote
The Following User Says Thank You to Dustin For This Useful Post:
NWFRS (05-29-2014)
Old 05-29-2014, 09:06 PM   #41
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
I wanna see these too modded for the street builds...
Old 05-29-2014, 09:25 PM   #42
acg2010
Drives: 4 wheels/engine/seats
Perhaps they're like this one. I call it the Rick Moranis mod:
acg2010 is offline   Reply With Quote
The Following 2 Users Say Thank You to acg2010 For This Useful Post:
BlueDubbinTDI (05-29-2014), tennisfreak (05-30-2014)
Search this Thread:
Advanced Search
BRZ vs modified Mustang GT ansibe FR-S / BRZ vs.... 16 08-03-2013 01:27 PM
Modified FR-S/86 Thread poormans_LFA FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 125 09-22-2012 01:10 PM
Modified BRZ Thread poormans_LFA BRZ Photos, Videos, Wallpapers, Gallery Forum 21 04-13-2012 06:31 AM
Modified or Unmolested? DC87 Scion FR-S / Toyota 86 GT86 General Forum 145 10-27-2011 08:55 PM
New Supra = Modified FT-86? Rainmaker86 Scion FR-S / Toyota 86 GT86 General Forum 77 10-18-2011 01:56 AM
