86WORX
Old 06-08-2014, 04:30 PM   #15
ZionsWrath
Thanks
ZionsWrath's Avatar
interesting...
Old 12-31-2014, 06:07 AM   #16
juliog
juliog's Avatar
Drives: 86
Been having this issue again and again and again, after going trough a couple set of front pads and replacement rotors.
After 1-2 track days the brake pedal gets very mushy. Bleeding helps but doesn't eliminate the softness completely. A couple days after bleeding it usually suddenly gets noticeable better, but still a far cry from what it should be.
The end result is that the braking feel is not linear and I have a lot of trouble being consistent with initial application and release, making threshold braking very difficult at the track.
juliog is offline   Reply With Quote
Old 12-31-2014, 10:26 PM   #17
wparsons
wparsons's Avatar
What fluid are you running? It sounds like you're boiling the fluid a bit and it's not recovering.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
juliog (06-03-2015)
Old 12-31-2014, 10:40 PM   #18
juliog
juliog's Avatar
Drives: 86
Was on Project Mu GFour, then changed to RBF660. Stock calipers and DBA4000 rotors. Doing a full flush this weekend with Torque RT700.
Old 06-03-2015, 03:13 PM   #19
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
Digging up this old thread, but it is relevant to me right now. Did the full flush with Torque RT700 do the trick? What bleeding method did you use?
Old 06-03-2015, 03:42 PM   #20
juliog
juliog's Avatar
Drives: 86
No problems since I switched to AP Racing Sprint Kit + Torque RT700. I think I might have had air somewhere in the lines that didn't go away until I did the install of the BBK and put some fresh SS lines. Since then, virtually no degradation after 4 track days. Might bleed after the 5th just for the peace of mind.
Using the same fluid now on a S2000 with stock brakes (my daily), again it's holding up much better than the Motul, 2 track days and many canyons and brake pedal still feels right.
My roommate's FR-S with OEM brakes is still on RBF660 and has to bleed after every single event, pedal gets noticeably softer. And he's a low-intermediate driver. He'll be switching to Project-Mu or Torque soon...
For the record, I have the Motive power bleeder but most of the time I just use the two-man method to bleed the brake fluid.
The Following User Says Thank You to juliog For This Useful Post:
CSG Mike (06-03-2015)
Old 06-03-2015, 03:53 PM   #21
Two man method is just so much faster once you get coordinated...
wparsons (06-03-2015)
Old 06-06-2015, 04:23 PM   #22
ZionsWrath
Thanks
ZionsWrath's Avatar
Probably but it's hard when you have no friends 😢
When I bled my clutch I had to teach my girl what is a clutch pedal ❤
The Following User Says Thank You to ZionsWrath For This Useful Post:
wparsons (06-06-2015)
Old 06-06-2015, 06:55 PM   #23
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
1) Put on new front brake pads —old ones were worn out.
2) Bled brakes with help of another person. Brake pedal felt very firm.
3) After starting engine, brake pedal feels very soft the first 50%, almost (but not quite) like a dead zone. It does not become firm again after shutting down engine.
Drove for a couple days. Successfully bedded my pads at night with no traffic around (no more squealing on these PMU CR). Tried bleeding brakes again, two person method plus vacuum pump, same result.
Any hints or tips? I've changed pads and bled brakes several times in the past, but never had this problem. Could it be air? Should I try bleeding again?
You can reverse bleed the brakes feeding from the bleed nipples up to the reservoir if you want to get really anal.
Here a vid so you get an idea what I'm talking about.
[ame="https://www.youtube.com/watch?v=FB8kzUEqK3U"]Phoenix Systems V-12 DIY Reverse Brake Bleeder Walkthrough - YouTube[/ame]
You really dont need any fancy tools to reverse bleed, although they do make the job much faster. You can make a brake fluid IV (gravity feed insead of assisted by pressurization with a tool) with some hoses and fitting from homedepot.
edit:
Old 10-28-2018, 07:15 PM   #24
Spacemane969
Spacemane969's Avatar
Drives: 2013 ARGENTO A/T
I just did my full flush and I have about 80% play in the pedal before the brakes apply. It still feels good but I need the firmness back. Two things could have caused this: I used the one man IV method and on my last wheel the bottle fell to the ground. Not sure if air got sucked in. Second forgot to go front right in sted of front left. What's the most simple fix here?
Thanks
Spacemane969 is offline   Reply With Quote
Search this Thread:
Advanced Search
Is anyone else's dead pedal loose/making noise? KevinR Issues | Warranty | Recalls / TSB 41 01-16-2017 01:33 PM
AFR's Danger zone!? Brick Software Tuning 20 02-24-2014 07:14 PM
Installed exhaust and Intake, pedal dead spot. How long does it last jflogerzi Engine, Exhaust, Transmission 24 02-23-2013 06:11 PM
Popping/Clicking Dead Pedal BRaZinDave BRZ First-Gen (2012+) -- General Topics 6 12-08-2012 05:14 AM
Dead pedal height bqe-lie-fdr Scion FR-S / Toyota 86 GT86 General Forum 0 02-25-2012 09:21 AM
