#43 | ||
Drives: 2013 Ultramarine FR-S
Ironsquid said: Quote:
![]() '13 Ultramarine 6MT FR-S || K&N Drop-In, SpeedFactory V1 Cat-Back || Moto-East tuned Join the 86 Owners Clan on Clash of Clans: "86 Owners" Password: "fa20" || Help us take over the world || Thread |
| The Following User Says Thank You to AllDayJonRay For This Useful Post: | airrick (05-03-2020) |
#44 |
#45 |
Drives: 2JZ FRS
So my Gti should have died way before I parted it out then? I had a 5858 oil fed only Turbo on a 2.8 6 cylinder VW engine with 10.5:1 compression for 4 years with nothing but the factory oiling system. No added coolers what so ever minus the intercooler. OEM Rad as well. I never had one issue with that car and it made over 400whp. Over double the factory output. I think its a little broad of a statement to say that adding a Turbo without additional oil cooling for it will kill the engine or Turbo itself. Hell, I've never seen a VW person add an oil cooler. Even the 900hp vr6 drag/street car we run has stock oiling and cooling.
| The Following User Says Thank You to spitfire481 For This Useful Post: | ftc~brz (05-22-2014) |
#46 | |
Drives: 1997 Eagle Talon TSi AWD
Anyway, I think everyone needs to consider the repercussions of a turbo kit on these cars for the long term, whether it be racing or daily driving. I don't sell Speed by Design and it makes no difference to me. I'm trying to give peoe a heads up based on a lot of past experiences I've dealt with on my own cars and 100's of customer cars. For example, the Ralliart I drive is turbocharged and Mitsu cheaped out and didn't put an oil cooler. Albeit these cars run at 20-24psi, I've had at least 10 busted turbos and a handful of lifted head gaskets because of oil temps getting way too high. I just don't want people to have problems long term and an oil cooler is really a no brainer when it comes to turbocharging. |
| The Following User Says Thank You to Jason@DSG For This Useful Post: | Strife26 (10-19-2015) |
#47 | |
#48 | |
I run my personal car with 260-280F oil temps, and have yet to have an oil related failure. In fact, I have an oil analysis for every single oil change on my car, showing that I'm doing just fine with those temps. I even run 10k oil change intervals. Of course, YMMV. |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | AllDayJonRay (05-21-2014), Calum (05-21-2014) |
#49 |
Drives: 2JZ FRS
You are correct about that on my car. Its been a while. The sandwich plate is tiny, probably about what the forester plate is. The drag/street car has not had one since 2005
#50 | |
#51 |
Ya the VW OEM cooling system was really good. Ze Germans, they know. I've only had a few R32's upgrade or run twin OEM. Nonetheless, there's still a cooling system, it's just not a traditional cooler core.
#52 | |
Also, once again not worried about oil degradation lol. Worried about longevity of the turbo (especially a smaller one like a 20g that produces a pretty substantial amount of heat). Overtime, turbo seals can go and it's a really annoying ordeal to get repaired or replaced |
#53 | |
The point is that I run my own car far hotter than what you claim is safe. Yes, my engine is currently stock. Down to the 13.6:1 AFRs, which most would consider unsafe. Regardless, the FA20 does reduce output with high oil temps, and IMO, every FA20 should have an oil cooler, even NA. |
#54 |
Drives: Attitude
What does lifting heads have to do with oil temp - that's purely a boost issue...
#55 | |
No, my point (I've said it quite a few times also -- even in caps!) is the longevity of the turbo and preventing excessively hot oil from potentially causing damaged to the turbo seals as well as higher oil pressure (higher temp equals higher pressure equals potential for lifted head) I claim that controlling the temperature for guys not changing and analyzing their oil after every track event should ensure that they don't run unnecessarily hot oil temps. Like I said (also for the 10th time), I firmly believe that an oil cooler is an essential mod for this car (while of course monitoring temps to ensure they are always optimal -- no cold runs or pulls) if you are going turbo. PS: Oil temps increase with higher boost (in reply to your other post). A 10psi application versus a 25psi will have vastly different internal cartridge temps |
#56 | |
| Oil cooler needed? Don't know? See some results inside | Sportsguy83 | Engine, Exhaust, Transmission | 159 | 03-15-2015 06:27 PM |
| Perrin Oil Cooler - Impressions, Pics, and Data | swift996 | Engine, Exhaust, Transmission | 36 | 04-29-2014 10:03 AM |
| Robispec Radiator/oil cooler NEW $800 or trade for NEW FB oil cooler kit. | mike the snake | Engine, Exhaust, Bolt-Ons | 1 | 01-31-2014 06:46 PM |
| Car/Ambient temperature to log data | gdrider77 | Software Tuning | 6 | 01-19-2014 09:49 AM |
