#15 |
So elite I'm 1338
Drives: WRB Subaru BRZ
People have answered your question.
If you aren't throwing a CEL and you don't hear/notice any strange behavior in your car, then I wouldn't worry. |
#16 |
| The Following 4 Users Say Thank You to husker741 For This Useful Post: |
#17 |
Go wipe your finger across any exhaust pipe on any car parked on the street. your finger will be black. thats just how it goes
#18 |
So elite I'm 1338
#19 |
#20 |
Drives: FR-S 10 #103 AT
If it got that dark that fast, you should monitor your AFR just as a check. You are probably running pig rich. I have 10,000 miles on my car and not a spec of soot that you can see without getting down behind the car to check specifically for it.
My old Speed3, now that had a black exhaust tip, but that was because factory turbo = pig rich mixture.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
#21 |
Drives: '13 GBS Subaru BRZ
It's likely just the way the exhaust tips are shaped. My Perrin exhaust makes even a tiny bit of "soot" very obvious on the large smooth surface compared to the stock tips which have lots of edges to catch and hide it.
#22 |
Drives: First SWP BRZ-L
As Mid_Life_Crisis stated, AFR plays a role. Additionally, be aware that the stock tune is pig-rich, so in stock form this is pretty common. A tune actually would reduce the soot levels some
Neutron256 also makes a valid point too. Tip shape might have impact.
First white BRZ in the country
![]() Limited SWP BRZ, 35% tint, clear bra, Nameless Performance downpipe, axelback, headers |
#23 | |
Drives: 2005 Toyota Camry
I put JDM GT86 tips on my stock exhaust. Black "soot" more visible without change in driving style. My conclusion: when you mod the car, you notice these small things more. I went back and looked at my stock tips, and lo and behold... they're pretty damn dark too! I just never noticed with a stock exhaust because I wasn't bothering to look. -alex |
#24 |
Berz
#25 | |
Depends on yur driving and if its all city stuff you tend to get more soot , lot of freeway driving and it will be less As others have said tip design can make a difference larger tips run cooler and accumulate more soot you can see Fuel also makes a difference 10 percent ethanol fuels produce less soot nad emmissions as the ethanol aids combustion. Run E85 with appropiate tune and there will be no soot at all perfectly clean :-) These cars being sports cars are generally tuned a bit richer than your family ecno box so you will often see more soot on sports cars |
| The Following User Says Thank You to steve99 For This Useful Post: | J_kennington (05-22-2014) |
| List of dB levels for aftermarket exhausts. | l0aded | Engine, Exhaust, Transmission | 22 | 07-01-2022 05:51 PM |
| Does TRD diffuser work with aftermarket exhausts? | sittinSideways | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 05-16-2013 01:58 AM |
| Black Stealth Exhausts | Cjymiller | Engine, Exhaust, Transmission | 7 | 05-07-2013 11:25 PM |
| Water with black soot in exhaust | KamalT | Engine, Exhaust, Transmission | 17 | 01-08-2013 10:28 AM |
| Aftermarket Exhausts? | devinclfalcons | Engine, Exhaust, Transmission | 309 | 10-18-2012 03:07 AM |
