Northern California NorCal
Old 05-19-2014, 11:00 AM   #15
Corradooo
Corradooo's Avatar
Drives: Storm trooper FRS
Originally Posted by Kaotic Lazagna View Post
I believe if a smog tech gets caught, it is now a felony charge in California. That's why it's hard to find someone who will be willing to do it, and those that are willing will charge an arm and a leg. If I were you, I'd find a couple of friends, and assign parts to swap back too. With multiple people working on the car, it shouldn't take very long.
Makes sense. Def sucks. I dunno if you've ever been under yours yet, but I'm 6'4" so when I'm under there there's really no extra room for anyone else. Only have 1 set of stands so it's going to be a back and fourth process. Really no way around me doing all of the work 4 times, that's why I was looking to see if the smog place would play but I guess that's not looking like an option lol. Thanks for the help.
Corradooo is offline   Reply With Quote
Old 05-19-2014, 11:32 AM   #16
Pwolf
Pwolf's Avatar
Drives: 2013 GBS BRZ Limited
Welcome to California
Pwolf is offline   Reply With Quote
The Following 2 Users Say Thank You to Pwolf For This Useful Post:
Kaotic Lazagna (05-20-2014), suaveflooder (05-19-2014)
Old 05-19-2014, 11:57 AM   #17
cdo221
Drives: 2013 Ultramarine FR-S, 2015 RS 1.0
My understanding is that the muffler delete has no effect on smog. I have no personally experience, just what I've heard. Same with the intake I think? Just your two cats need to be stock and working properly. Can anybody else confirm that?
cdo221 is offline   Reply With Quote
Old 05-19-2014, 12:12 PM   #18
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Technically speakibg I believe its true, but always swapped mine to be safe.
And also $200 would be cheap. My cousin pays almost $400 to get his SR 240 done.
Old 05-19-2014, 12:21 PM   #19
Corradooo
Corradooo's Avatar
Damnnnn California is no joke. Guess you gotta pay to play... Or be ready to do the work lol
Old 05-19-2014, 12:47 PM   #20
Haeb
Haeb's Avatar
Drives: 2014 Scion FR-S Monogram Series
Intake will have to either be stock or if aftermarket have an Executive Order number clearly listed for the intake. Usually anything past the muffler is ignored or not looked at during a smog.
Haeb is offline   Reply With Quote
Old 05-19-2014, 01:05 PM   #21
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
Any emissions equipment may not be tampered with unless replaced by a California Air Resource Board approved part.
This is your ECU, your intake, your header and your front pipe, cams, cam gears... Anything that has to do with emissions.
Not sure on internal work, I.E. high/low comp pistons, stroker kits etc.
But Im betting that those are a no go also.
Old 05-19-2014, 01:19 PM   #22
doggieboy09
Sènior Member
doggieboy09's Avatar
Drives: '22 BRZ |'13 BRZ SSC (formerly)
I've went to same exact situation went I brought my Stage 2 WRX from Virginia to California. I went to the whole process of working in a friend's small garage working under the car with 4 jack stands, replacing the turboback pipe to stock and replacing it back to stage 2 right after the smog test. I know its a mass amount of time and effort to do this but there is no other way. If you really don't want to go crawl under your car, I recommend to go to Pit Row in Santa Clara so you can work under a lift. If you are going to do this, do this the right way. I'll be at the Wednesday meet up if you want to network some help.
Btw if you have a tune, you must drive your car a good 3-5 days so the ECU can relearn everything. Smog test can pick that up based upon my experience.
Sent from my Android phone
doggieboy09 is offline   Reply With Quote
Old 05-19-2014, 01:20 PM   #23
HapaHaole
Drives: Grocery cart
Anything after the last emissions device is not part of the emissions inspection. ONLY thing a SMOG fails for parts after a CAT is if there are too many leaks in the exhaust causing a high O2 content then the vehicle fails the sniffer part.
SOLD: 2014 BRZ Limited WRB 6 Speed.
HapaHaole is offline   Reply With Quote
Old 05-19-2014, 02:01 PM   #24
HapaHaole
The state started to use scores on technicians and track each car to the technician. Therefore the costs of doing a "Clean piping" went up in California, because if he passes you and later on you take it somewhere else in the future and it says tampered the first technican who did the smog gets a bad score. So yea, its expensive!
Old 05-20-2014, 12:57 AM   #25
Kaotic Lazagna
Drives: GR Corolla
When we had our Camry, it passed the sniffer with flying colors, but failed overall cuz of visual.....there was a crack in the stock intake tubing....
Kaotic Lazagna is online now   Reply With Quote
Search this Thread:
Advanced Search
Visual Garage Shark fin antenna EvoXDD Cosmetic Modification (Interior/Exterior/Lighting) 86 08-02-2015 03:20 PM
Suspension - visual inspection points? 1Cor10:23 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 03-21-2014 02:15 PM
Visual Basic and SQL Trashed675 Off-Topic Lounge [WARNING: NO POLITICS] 10 06-10-2013 01:18 PM
visual garage shark fin group buy. Mr.Jay Exterior Parts - The Rest 39 07-02-2012 11:09 PM
