Old 02-28-2015, 05:02 PM   #827
pr0xy
Drives: '13 WRB BRZ
Originally Posted by adamg View Post
was your ebrake pulled the whole time? try putting it down and see what happens
This is one of the differences between USDM and EUDM - the ebrake does not have any effect on the light of EUDM cars. The DRLs are on with and without the ebrake.
pr0xy is offline   Reply With Quote
Old 02-28-2015, 05:46 PM   #828
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Originally Posted by pr0xy View Post
Video:
I guess this Kit is just not working at all for EUDM (which makes me very sad, I SO want this to work )
That would suck, my kit is on the way!
Old 02-28-2015, 05:49 PM   #829
livert
livert's Avatar
Yup. I have a feeling these do not work on JDM, EUDM and Australian cars. Refer to my previous comment too.
livert is offline   Reply With Quote
Old 02-28-2015, 05:59 PM   #830
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
I'm assuming the difference is the pin layout on the non-US cars.
I think if you guys took pictures of your stock headlight harness, that would help out @Diode Dynamics
The fix is probably as simple as switching which wires go to which pins (i hope)
PandaSPUR is offline   Reply With Quote
The Following User Says Thank You to PandaSPUR For This Useful Post:
livert (02-28-2015)
Old 02-28-2015, 06:16 PM   #831
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Meh
The Following 2 Users Say Thank You to Guillaume For This Useful Post:
Choco (03-03-2015), pr0xy (02-28-2015)
Old 02-28-2015, 06:19 PM   #832
tracerit
Drives: '13 SSM BRZ Limited 6MT
Makes me wonder, even though our cars are built in Japan, it seems all the after market vendors are in the US.
tracerit is offline   Reply With Quote
Old 02-28-2015, 07:04 PM   #833
livert
livert's Avatar
Here you go. These were taken on the passenger side of my RHD car (the side furthest away from the fusebox).
Old 02-28-2015, 10:57 PM   #834
ericmpena
ericmpena's Avatar
Drives: Subaru BRZ Limited
So, I want to order these but just want to make sure....USDM models do not appear to be having any issues, right? Does that sum it up? Or...are there USDM models that are having issues with the kit as well?
ericmpena is offline   Reply With Quote
Old 02-28-2015, 11:09 PM   #835
Husker BRZ
Go Big Red!!
Drives: 2013 SSM BRZ Limited
Here ya go! Mine worked perfectly fine from the get go!
Originally Posted by Diode Dynamics View Post
We have identified a problem in one part of the harness that was contracted out, specifically, one wire is switched in pin position. It was not something that we checked for in our testing process which is done on each unit. Please contact us directly if you encounter any problems with your kit. We believe it's less than 3% of the modules shipped so far, and we've now eliminated the possible point of failure. We'll of course immediately replace any defective units. Thank you.
Husker BRZ is offline   Reply With Quote
The Following User Says Thank You to Husker BRZ For This Useful Post:
ericmpena (03-01-2015)
Old 03-01-2015, 12:06 AM   #836
tracerit
Auto does not make any difference in the way the lights work- it jsut automatically picks "on" or "off" for you. If it's not working properly with lights in either on or off position, we will provide replacement. Again, "auto" setting makes no difference in the way the lights are actually powered, so the module will work just fine in Auto mode.
Will this warranty be extended to modules purchased from other vendors? (I have one coming from FTeightysix hopefully next week). Is there anyway to check it out before actually installing and using it?
Old 03-01-2015, 06:34 AM   #837
banane63
banane63's Avatar
Drives: BRZ Club blanc perle
There seems to be a difference in the wiring on this A60 connector between G4400BE and G4400GE on pins 2 and 3 :
Collecteur et frontpipe Supersprint full décat - Catback Remus
Admission directe Greddy - Kit Flexfuel et map Ecutek Visconti Tuning - Tein Street Advance EDFC Pro - NED modine - OZ Alleggerita 18 Michelin PS4 - Wilwood 6 pistons
banane63 is offline   Reply With Quote
Old 03-01-2015, 06:51 AM   #838
livert
livert's Avatar
Are these comparing USDM vs EUDM? Where did you get these diagrams?
Old 03-01-2015, 07:05 AM   #839
banane63
banane63's Avatar
http://www.ft86club.com/forums/showthread.php?p=1166113
Old 03-01-2015, 07:18 AM   #840
livert
livert's Avatar
Could someone with a USDM BRZ please post a few pics of the stock headlight wiring connector on the driver's side please? Curious to know if all 8 wires look the same.
Thanks banane. It seems The G4400GE manual details the wiring of both RHD and LHD whereas G4400BE only has LHD? Anyone here have the expertise to interpret them? I think it could simply be a matter of changing the spliced wires between the headlight connectors with the wires from the DRL module.
[Closed] Gauging Interest thread pansontw Cosmetic Modification (Interior/Exterior/Lighting) 49 08-27-2014 04:14 PM
So has anyone managed to get the BRZ Boomerang/parking lights to operate as DRLs? gt8613 BRZ First-Gen (2012+) -- General Topics 18 04-27-2014 03:09 AM
Gauging Interest ISC Suspension Announcements, Contests, Giveaways 17 04-03-2014 10:44 AM
Jdm headlights - gauging interest Hawk77FT Exterior Parts (Aero, Lighting, Etc.) 7 03-31-2014 10:38 AM
FS: Oil Pressure gauge (includes Block galley plug for free!) True plug and play! Sportsguy83 Engine, Exhaust, Bolt-Ons 10 08-30-2013 11:53 AM
