#15 |
Drives: 2013 MT Asphalt FRS
I used a breaker bar and a metal tube to give me more leverage.
#16 |
Drives: Subaru BRZ (6027xx) Premium Manual
Not sure what you mean... Can you explain?
FT86SpeedFactory catted UEL Header / GReddy EVO3 Catback / Cosworth Drop-in air filter / Shifteck short throw shifter / Kartboy pulley / Rear bumper diffuser / Perrin shorty antenna / Raceseng Slammer knob / Carsmo armrest / Clear side markers / 10" CustomSubEnclosure|Rockford R500X1D|Rockford P3D4-10 / Perrin Inlet Hose / GrimmSpeed front strut bar / Valentine V1 with BlendMount / All LED Inside
#17 |
#18 |
Also disable whatever you need to so the car doesnt start accidently
#19 |
Guy on internet
Drives: Slowly
Lots of incorrect info here...hmm...
#20 |
you seem to be doing it right... It may have been overtorqued at the factory, mine took me 10 minutes... and the hardest part was removing the pulley from the sleeve...
#21 |
Drives: 2013 Asphalt 6spd
I also had to do the starter bump on my 240. but if you have a friend and a strap wrench that should help.
#22 |
Drives: Evo 8
Chain Wrench ? And 24" 1/2 ratchet
I break em losse at work no problem all day |
#23 | |
That Guy
Drives: 2013 asphalt FRS MT
A part of this mechanical path is the clutch disk which is has a sprung hub. When you attempt to turn the bolt at the front of the crankshaft the first thing you're gonna do is take up slack (backlash) in differential and transmission, next you're going to take up slack in the driveline/bushings, next your're going to take up slack in the breaks/suspension, finally you're going to turn the clutch disk hub against the springs until they bind. At this point you can finally put torque into removing the bolt and not just turning the crankshaft and deflecting bushings & springs. It's been a while, but I'd estimate there was about 45 deg of rotation before I could put any real force on the bar. |
| The Following User Says Thank You to Calum For This Useful Post: | Sportsguy83 (05-13-2014) |
#24 |
Drives: #1553 10 Series FRS
#25 | |
#26 |
Drives: BRZ Sport-tech
#27 |
Drives: 2013 asphalt scion FRS
Pretty sure he meant for the "bump" technique of loosing the bolt. In otherwords, pull the fuse for the injectors. So when you bump the motor to break the bolt loose, the car doesn't actually fire and keep spinning.
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car) 1995 gmc 1500 4x4(off road toy) 2005 Yamaha yz250f |
#28 |
Yeh that's what i meant. Or pull something so no spark goes to the plugs
| The Following User Says Thank You to stevesnj For This Useful Post: | PMPB (05-12-2014) |
| Tags |
| crank pulley, installation |
| What is best crank pulley? | Mixlplix | Engine, Exhaust, Transmission | 49 | 10-28-2017 06:44 PM |
| Perrin crank pulley / Beatrush alternator pulley | Krimlin | Engine, Exhaust, Bolt-Ons | 7 | 08-26-2013 11:12 AM |
| Steering Loosen up after break-in? | Accathla | BRZ First-Gen (2012+) -- General Topics | 16 | 11-22-2012 12:45 PM |
| NEOPLOT Crank pulley Alternator pulley& Waterpump pulley | ANREX | Engine, Exhaust, Transmission | 10 | 10-25-2012 08:45 PM |
