steve99
Old 04-28-2017, 01:54 AM   #575
steve99
Hey folks. Followed the instructions in the first post to scale my MAF as I was seeing LTFT of +5 to +10. The vgi scaling program worked great for closed loop. Though it resulted in a slightly bumpy scale, my LTFT was down to +-3%.
Open loop scaling, on the other hand was quite wavy, and the transition showed the 3V lump folks were talking about back on page 8 of this thread. I cant seem to follow the logic/conversation and stopped trying a few pages in, but it seemed like it involved having to first get the injectors set correctly?
I know it was discussed in a number of threads back in 2014-ish, but if anyone could explain the consensus reached about why this happens and if I should/how I can get the scaling on the upper end right, I would very much appreciate it.
Just FYI: Stock engine, OFT, and Perrin inlet tube (because sound generator was annoying) in case that matters.
Don't worry about rescaling pi/di unless you have changed injectors
You will often get a bump around 3v as that's the cl to ol transition. just manually smooth that area. Then recheck the ol fueling
Old 04-29-2017, 02:45 AM   #576
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Thanks steve99. Mind taking a look at what I have right now?
Below are the adjustments the application wants me to make from open loop logs. This is after I've re-scaled and smoothed in open loop and closed loop. The current MAF in the 3-3.5 region already shows a bit of a dip in the graph (hard to see in the picture). Also attached the %difference of my current scale (From Kodename47's tool).
Any thoughts or recommendations? It looks weird to me that it is so bumpy, but it could just be resonance, etc. Im thinking I might use one of the smoothed outputs from Kodenames tool and leave it at that.
Old 04-29-2017, 05:40 AM   #577
steve99
Yes definitly smooth out the lumpy bits
solidONE (04-29-2017)
Old 05-08-2017, 02:12 PM   #578
allowe
allowe's Avatar
I can't seem to figure out how to get the trims needed for data logging
allowe is offline   Reply With Quote
Old 05-08-2017, 07:21 PM   #579
steve99
Try updating oft to pick up new template file, if that doesnt work manually update template file from here
http://www.ft86club.com/forums/showp...79&postcount=2
Old 05-08-2017, 07:27 PM   #580
allowe
allowe's Avatar
Updating happens when you open up openflash manager with oft plugged in right?
Old 05-08-2017, 07:29 PM   #581
allowe
allowe's Avatar
MAF Scaling - Open/Closed Loop Fueling info
Nevermind just did it manually thank u!!
Edit @steve99 it still displays nothing even after manual update.
Old 05-08-2017, 08:03 PM   #582
steve99
Is it just that screen of parameters ? What avout other screens of parameters
What shows up in the log files ?
Looks like you need to talk to oft guys
Old 05-08-2017, 08:45 PM   #583
allowe
allowe's Avatar
It shows column 1 , 2 ,3 etc
Old 05-08-2017, 10:01 PM   #584
steve99
Yeah sounds like you need to talk to oft guys something not correct their
Old 05-09-2017, 02:29 AM   #585
allowe
allowe's Avatar
Wouldn't I know which data is which by just getting the names from a picture that has the names for those tables? The pids still fluctuate and give a reading
Old 05-09-2017, 09:45 AM   #586
steve99
could be possible if you can work out what they are
Old 05-11-2017, 01:10 PM   #587
allowe
allowe's Avatar
If anyone encounters this problem, i linked the file that worked for me that i got from Shiv. hope this could help someone out there!
GT86 Customized 8.zip
Old 05-16-2017, 04:22 PM   #588
allowe
allowe's Avatar
What else should I select? This could help those who have the oft
Search this Thread:
Advanced Search
AFR in Closed Loop Toyota John Software Tuning 39 07-07-2019 09:26 AM
BRZedit Fuel Trims, Closed to Open loop transiton mad_sb Engine, Exhaust, Transmission 32 08-06-2015 04:14 AM
Notes on injector / maf scalining using full time open loop mad_sb Software Tuning 40 03-03-2014 06:49 PM
Screencast: closed loop boost control with RaceRom jamesm Software Tuning 2 02-10-2014 03:23 PM
Screencast: experimenting with full-time closed loop fueling jamesm Software Tuning 2 12-27-2013 11:19 AM
