#519 |
Drives: 86 GT
Default settings but limit to 3v as suggested.
#520 |
Drives: UK GT86
You have decent data so lower the dV/dt to something like 0.3/0.25. Looking over the mean/mode data I would say that the 1st rescale was pretty good. I would revert to that, smooth it out (I've added the data below) and then use the Engine Load Comps to get the last bit dialed in as you'll get a finer tune as the last bit of variance is probably due to changing manifold pressures.
It's worth using the log view tab to give you a good overview of LTFT and STFT Code:
[Table2D] 0.898 0.938 0.977 1.016 1.055 1.094 1.133 1.172 1.211 1.25 1.289 1.328 1.367 1.406 1.445 1.484 1.523 1.563 1.602 1.641 1.68 1.719 1.758 1.797 1.836 1.875 1.914 1.953 1.992 2.031 2.07 2.109 2.148 2.188 2.227 2.266 2.305 2.344 2.383 2.422 2.461 2.5 2.578 2.773 2.969 3.203 3.438 3.711 3.906 4.063 4.297 4.492 4.727 5 0.850342095 1.29491002 1.50415138 1.726490438 1.965994823 2.230315661 2.522716665 2.83903296 3.177060843 3.533967423 3.911788416 4.321375585 4.782655239 5.308370113 5.846223021 6.423442554 7.049371672 7.681936693 8.404752493 9.174043798 9.961086225 10.83313208 11.73953028 12.67853832 13.66015129 14.69431467 15.77506762 16.89282169 18.05510235 19.27290268 20.54888573 21.87280598 23.22922325 24.62534809 26.07107887 27.5764925 29.14266014 30.76554508 32.44162388 34.17392902 35.96828251 37.82774658 41.27758583 51.36894608 63.05139932 79.5941153 96.81557007 121.6440552 139.5471259 155.2441674 180.9846387 207.9978871 244.997 296.216
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | dave- (06-19-2016) |
#521 |
Drives: GT86
Some general advice:
Have a look at this example: Some thoughts: I assume that your "800 A02G MAF CL" is the maf scale you started with, isn't it? It definitely does not look oem-ish, since it's already off. If you're using cruise control, make sure the engine runs at different rpms for some time to gather enough data for different maf voltages. Use the higher rpms as well. You definately want to get data for 3.20V in closed-loop(!) and that's really difficult. 3.2v is used in open-loop as well, this is where load limits come into play. Have a look at @Wayno 's thread, to understand how it's done. I've thrown the data from your first run into the vgi tool and edited it manually to reduce the bump that vgi tool exaggerated. This is the result, formatted for RomRaider: Code:
[Table2D] 0.898 0.938 0.977 1.016 1.055 1.094 1.133 1.172 1.211 1.25 1.289 1.328 1.367 1.406 1.445 1.484 1.523 1.563 1.602 1.641 1.68 1.719 1.758 1.797 1.836 1.875 1.914 1.953 1.992 2.031 2.07 2.109 2.148 2.188 2.227 2.266 2.305 2.344 2.383 2.422 2.461 2.5 2.578 2.773 2.969 3.203 3.438 3.711 3.906 4.063 4.297 4.492 4.727 5.0 1.029 1.514928254206154 1.7854511567429672 2.016297366907714 2.171397164362154 2.4779897872372088 2.8723520629353185 3.213812082137341 3.6057697098129013 3.9231832487894285 4.401708205276769 4.686658995948879 5.0605817634553185 5.361162766274 5.986371252136857 6.5334286772668575 7.044416382058616 7.70689691227099 8.392221598697583 9.283143691052155 10.13198444301211 11.085427383952968 12.098986525457562 12.981107171381447 13.660391017596005 14.724515247918555 16.008930066512995 16.465358003588204 17.6245198570147 18.39369093249791 19.777754143348883 21.000733009055068 22.591672322162538 23.86109346483927 25.308604435098285 26.626383312277333 28 30 31.5 33.56470134642 35.758709892278574 37.85333820183826 41 51.24455641064684 61.940777131117194 76.20261494572648 94.527 126.111 142.083 155.297 180.36 209.266 244.997 296.216 |
| The Following User Says Thank You to freerunner For This Useful Post: | dave- (06-19-2016) |
#522 |
Drives: GT86
Yay! @Kodename47 beat me to it.
#523 | ||
Drives: 86 GT
The Engine load table hasn't been altered from stock, doing a test run with the current data in the load rescale gives MP calc changes in the final 1.01 column only. Is that what I should expect once I have data from your revised scale? Quote:
Also didn't think about Celsius vs Fahrenheit. And you were correct about the scale, it isn't the OEM one. I probably should have started there but it was supplied by someone familiar with the same turbo kit I have installed. Expected it to be close enough straight up but wasn't the case. |
#524 | |
Drives: UK GT86
What logging/tuning system are you using? If not ECUtek beware of differences in pressures between logging and the table definition. Not unusual for MRP/MAP or bar/psi. Sounds like the table is in MAP bar, how are you logging pressure? As ELC is just done in closed loop I rarely see changes made to the last column, but you should have many changes elsewhere.
.: Stealth 86 :.
#525 | |
Drives: 86 GT
I'm using BRZedit for changes as that is the format the base tune with injector scaling data was supplied in. Also got it for the live log ability but find the sample rate is terrible (doing something wrong obviously). I should transpose the relevant changes back to a romraider bin file and work from there as it would be easier working with the mafscale utility and info on the forums. Differences from current file to a stock A01G below, BRZedit names the tables differently in some cases. My current tactrix config file to generate the logs is attached, thought I'd attached it in the earlier post which might have helped. Code:
1D: Front Oxygen Sensor Rich Limit: Data 1D: MAP Scaling A Mul: Data 1D: MAP Scaling A Base: Data 1D: MAP Scaling B Mul: Data 1D: MAP Scaling B Base: Data 1D: Mass Air Flow Limit A: Data 2D: Engine Load Limit A: Data 2D: Engine Load Limit B: Data 3D: Calc Engine Load B: Data 1D: Injector Flow Scaling: Data 1D: Injector Minimum Open time : Data 1D: Injector Flow Scaling v2: Data 2D: Low Pulse Width Fuel Injector Compensation: Row 2D: Low Pulse Width Fuel Injector Compensation: Data 2D: Throttle Delta Fuel Comp (Delta) A: Data 2D: Throttle Delta Fuel Comp (Delta) B: Data 2D: Cranking Injector Pulse Width: Data 2D: PI Manifold Relative Pressure Comp: Data 2D: DI Quantity Maximum Allowed: Data 3D: GDI Pressure Target B: Data 3D: Total Injection Ratio GDI port (Cold): Data 3D: Total Injection Ratio GDI port (Warm): Data 3D: Total Injection Ratio GDI port (Hot): Data 3D: Fuel Map: Col 3D: Fuel Map: Data 3D: Cranking Fuel Injector Pulse Width A (ECT): Data 3D: Cranking Fuel Injector Pulse Width B (ECT): Data 3D: Cranking Fuel Injector Pulse Width C (ECT): Data 3D: Cranking Fuel Injector Pulse Width D (ECT): Data 3D: Cranking Fuel Injector Pulse Width E (ECT): Data 3D: Cranking Fuel Injector Pulse Width F (ECT): Data 3D: Cranking Fuel Injector Pulse Width G (ECT): Data 3D: Cranking Fuel Injector Pulse Width H (ECT): Data 3D: Cranking Fuel Injector Pulse Width I (ECT): Data 3D: Cranking Fuel Injector Pulse Width J (ECT): Data 3D: Injectory Battery Offset: Col 3D: Injectory Battery Offset: Data 1D: Initial Advance Multiplier: Data 3D: Ignition Base (Safe): Col 3D: Ignition Base (Safe): Data 3D: Ignition Base (Normal): Col 3D: Ignition Base (Normal): Data 3D: Ignition Advance: Col 2D: Idle Target A: Data 2D: Idle Target B: Data 2D: Idle Target C: Data 2D: Idle Target D: Data 2D: Idle Target E: Data 2D: Idle Target F: Data 2D: Idle Target G: Data 2D: Idle Target H: Data 2D: Idle Target I: Data 1D: Manifold Pressure Sensor Limits (CEL): Data 1D: MAP Scaling C Mul: Data 1D: MAP Scaling C Base: Data 2D: MAF Sensor Scaling: Data 2D: Front O2 Sensor Scaling A: Row 2D: Front O2 Sensor Scaling A: Data 2D: Front O2 Sensor Scaling B: Row 2D: Front O2 Sensor Scaling B: Data |
#526 | |
Drives: GT86
![]() What sampling rate do you usually get? |
#527 |
Drives: UK GT86
@dave- you're logging MAP in kPa. Need to divide the logging value by 100 to get Bar as per the table.
.: Stealth 86 :.
#528 |
Drives: 86 GT
From memory it was ~150ms+ freerunner with only half a dozen parameters selected. Tactrix with 20-30 is much faster.
Thanks Kodename47. Haven't been able to get out there and play around, weather is crazy cold now |
#529 |
Drives: FR-S Whiteout
I'm not sure whether if this has been brought up in this thread. I just want to make sure I'm on the right page with this. The CL fueling compensation table values adjustment can cause the Cl fueling to go richer or leaner than what is indicated on the OL fuel table, yes? Changing the value to 0 would cause the CL fueling to match that of the OL fuel map? Or am I oversimplifying.
OL fuel map: ![]() CL Fuel comp: ![]() Resulting Cl fueling: http://datazap.me/u/solidone/z6-kc1i...mark=1574-1575 CL fuel comp adjusted: ![]() Result: http://datazap.me/u/solidone/z7-kc1i...zoom=7483-7927 The adjustments to the OL fuel table and Cl fueling compensation did not seem to have too much if any effect on CL fuel target at 0.6 loads. Though once it switches over to OL operation fuelking is right on target.
Intent > Content
cowardice is the mother of cruelty. Last edited by solidONE; 07-26-2016 at 12:43 AM. |
#530 | |
Drives: Toyota 86 GTS
No Did you read the table description and the previous threads on CL? CL fueling is an adjustment from 14.70. It has nothing to do with the values in the OL table. After the ECU determines the CL fuel value and the OL fuel value it may chose a point between them. Until then CL values have nothing to do with OL values. All setting it to 0 will do is disable LTFT and/or disable CL.
| The Following User Says Thank You to Wayno For This Useful Post: | solidONE (07-26-2016) |
#531 | |
Intent > Content
cowardice is the mother of cruelty. |
#532 | |
So, you have E85 in the tank?
You're going to go around in circles every time you fill up. Can you go back to 98? This is what you SHOULD do: I assume you're using stock MAF sensor with same diameter MAF housing as stock. You should have 100% 98 in the tank, use the 100% STOCK MAF scale which is very close for E0, then you can scale your injectors. Once you have your injectors scaled, you can then do the 100% DI scaling and 100% PI scaling to tweak the injector scales if required. THEN scale the open loop MAF. Then you should put E85 in and re-scale the injectors for E85. If you don't want to do that, you could do the same on E85. You need a 100% stable blend/mixture though. And you will need to pick a MAF scale to do the port injector scaling. I use the CL part of the openflash scales for my E85 tunes. Do the 100% DI scaling to scale the closed loop MAF scale. Then do 100% PI scaling against your closed loop MAF scale to scale your port injectors. Then combine DI/PI and do your open loop MAF scaling. If you have a stock MAF sensor and stock MAF scale, and are seeing 20% trims, it's an injector scaling problem, not MAF scaling. Adjusting the MAF scale by that much will throw your tune out by putting you in to different load columns. If the kit came with a different MAF scale due to having a different MAF housing diameter, then you will need to use that scale. Note: most petrol tunes from the US and especially the openflash petrol tunes have MAF scales for E10. If the tune is for E85 though you might get lucky. Quote:
| AFR in Closed Loop | Toyota John | Software Tuning | 39 | 07-07-2019 09:26 AM |
| BRZedit Fuel Trims, Closed to Open loop transiton | mad_sb | Engine, Exhaust, Transmission | 32 | 08-06-2015 04:14 AM |
| Notes on injector / maf scalining using full time open loop | mad_sb | Software Tuning | 40 | 03-03-2014 06:49 PM |
| Screencast: closed loop boost control with RaceRom | jamesm | Software Tuning | 2 | 02-10-2014 03:23 PM |
| Screencast: experimenting with full-time closed loop fueling | jamesm | Software Tuning | 2 | 12-27-2013 11:19 AM |
