#379 | |
Slow Learner
Drives: 15 Halo FRS
I will reset the maf volt to 5 rather than 3 but my entire to is in cl. Thanks for the help |
#380 | |
closed loop fueling mode is 2 open loop is 4 make sure your not logging injection mode that is port\direct injection. |
| The Following User Says Thank You to steve99 For This Useful Post: | MGPAX (10-14-2015) |
#381 |
@steve99 this is probably a dumb question, but how do you past from excel into RR? Edit > paste doesn't seem to be working for me...thanks!
#382 |
Drives: FR-S Whiteout
What if you only want to process high intake temp data? That would be cool if they also had a min temp setting as well. Can come in useful for tuning for high temp and to do MAF IAT compensation tweaking for specific temp ranges.
Intent > Content
cowardice is the mother of cruelty. |
#383 | |
but you can copy from excel to vgi tool then to romraider. |
| The Following User Says Thank You to steve99 For This Useful Post: | 1Cor10:23 (09-26-2015) |
#384 | |
| The Following User Says Thank You to steve99 For This Useful Post: | solidONE (09-26-2015) |
#385 | |
Intent > Content
#386 | |
Slow Learner
Drives: 15 Halo FRS
As always I appreciate your help and all that you contribute to the forum. |
#387 | |
copy will only allow you to copy to excell or notepad ect. |
#388 | |
Slow Learner
Drives: 15 Halo FRS
Yeah, I'm logging OL/CL and not injection mode. I logged about an hour of closed loop data yesterday. One thing became apparent, OL would kick in and out depending on how hard I pushed on the throttle. But even if I accelerated as slow as possible (using cruise control to increase speed) once MAF voltage hits 3.0 it goes to OL no matter what else was going on. When selecting my filters for closed loop data it seemed reasonable to use 3.0 V max on the VGI table. My intention was not to stack multiple logs with OL/CL data mixed but to only attempt to collect closed loop data and scale that first. |
#389 | |
Slow Learner
Drives: 15 Halo FRS
That's kind of what I thought. It was late and I was trying to figure it all out. Do you have to select all the cells in the vgi tool and then copy_romraider to get the whole table or is the whole table selected by default. |
#390 | |
yep just select all cells and copy_romraider |
| The Following User Says Thank You to steve99 For This Useful Post: | RustySocket (09-26-2015) |
#391 |
Drives: UK GT86
The reason you can't copy Excel direct to Romraider is that it expects the top left cell to contain [Table2D]. You can use excel if you offset the top row 1 to the right and add that in. It'll look odd at the 2 rows won't line up but it'll work
Obviously the Copy Romraider option does that for you. See what happens if you do that and then paste to Excel....You'll never get a log with just CL. There are multiple reasons the ECU switches to OL. Throttle angle, speed and the OL fuel map are all factors. Realistically I doubt you'll get much reliable data above 2.5V. @solidONE just use the log stats screen if you want to start playing with IAT compensations. I do everything in that tab, including MAF changes. It's quite powerful.
.: Stealth 86 :.
| The Following 4 Users Say Thank You to Kodename47 For This Useful Post: |
#392 |
Anyone have a direct link / mirror to VGI tool? RR website is down...thanks!
| AFR in Closed Loop | Toyota John | Software Tuning | 39 | 07-07-2019 09:26 AM |
| BRZedit Fuel Trims, Closed to Open loop transiton | mad_sb | Engine, Exhaust, Transmission | 32 | 08-06-2015 04:14 AM |
| Notes on injector / maf scalining using full time open loop | mad_sb | Software Tuning | 40 | 03-03-2014 06:49 PM |
| Screencast: closed loop boost control with RaceRom | jamesm | Software Tuning | 2 | 02-10-2014 03:23 PM |
| Screencast: experimenting with full-time closed loop fueling | jamesm | Software Tuning | 2 | 12-27-2013 11:19 AM |
