#225 |
Drives: FR-S Whiteout
Knock free at WOT even at 90+ IAT's!
Check it out: http://datazap.me/u/solidone/2enrich...2&zoom=383-705 Only change was increasing the port ratio to about 0.148 at the very top which is actually only about 5% decrease from stock values of 0.203. Very happy and very excite. Here is one with the values set at 0.000 at the same spots. All else the same, with the IAT's about 5f lower. http://datazap.me/u/solidone/2enrich...12&zoom=11-345 |
| The Following User Says Thank You to solidONE For This Useful Post: | steve99 (07-24-2014) |
#226 | |
strange how it reduced knock at the lower rpms as shown in second log or were other changes made ? thanks http://i174.photobucket.com/albums/w...atioTables.jpg |
| The Following User Says Thank You to steve99 For This Useful Post: | solidONE (07-24-2014) |
#227 | |
Hmmm... good point. The only other variable was the fuel. The log with the knock was at less than half a tank of gas, while the knock free log was almost immediately after I fueled up to a full tank with Shell 91 octane at my usual gas station. As far as I remember the petrol was from the same station. I will have to keep an eye on it as I run down the tank of gas. Edit: I looked at the logs over more carefully and it seems that maf voltages were stuck at 1.12v. It would appear that the flkc and knock correction values were also stuck at zero. It is likely that the OFT was not logging correctly at the time I took the log and that in fact it was still knocking after I made the changes to the port ratios. Sorry guys. Please disregard my earlier post about being knock free.
#228 |
Drives: 13 White MT FR-S
Should I redo my MAF scale with the new shiv tune? I transferred my scale from 1.59 to 2.01 and the car ran bad. Ran the 2.01 without changes and the car felt immensely better. Couldn't tell a difference in any of the fuel tables though.
#229 |
Drives: UK GT86
Cam timing can have an impact on AFRs so the scaling may well be off. May be worth looking at why it runs worse though by logging and comparing. Don't forget that a change in MAF scale will impact on load calculations, so if your scale is bumped up, you'll see higher loads, which is usually richer and less advance. If that's all that is happened, you could adjust the load headers in the appropriate tables.
.: Stealth 86 :.
#230 |
Afe Takeda BRZ/86 Maf Scaling
If your running an AFE intake your maf scaling will likely be out with LTFT running at over 15% scaling attached (and to first post) should get LTFT below 5%. these intakes seem to have some resonance or turbulence in a couple of spots |
| The Following User Says Thank You to steve99 For This Useful Post: | aristo (09-04-2014) |
#231 |
Drives: BRZ SWP 14
You're a wizard
#232 |
Avo Turboworld Phil Rep
Drives: Forester 2009 XT on e85
@steve99 most likely from maf location ? Here's where you can further fine tune the takeda
![]() You can use Airboy's rev 3 over here http://www.romraider.com/forum/viewt...hp?f=32&t=5483 or @vgi OS utility (should be updated soon :-) ) http://www.romraider.com/forum/viewt...p?f=32&t=10481 Last edited by MFB; 09-07-2014 at 08:10 PM. Reason: Updated with links |
| The Following User Says Thank You to MFB For This Useful Post: | steve99 (09-05-2014) |
#233 |
sorry AEM intake scaling not correct was AFE Takeda.
#236 |
Drives: 86 GTS
Does it matter if we have more parameters in the log from a sample rate perspective? My usual tactrix logcfg has the following:
AF_Corr_3, AF_Learn_3, AFR, AFR_command, BaseTiming, CL_OL, Direct_IPW, Direct_IPW_0, ECT, FBKC, FLKC, FLKC_Offset, IAM, IAT, KCA, Load, LTFT, MAF, MAF_V, MAP, Port_IPW, RPM, Speed, STFT, Throttle, Tip_In_Enrich, TipIn, TotTiming Or should I limit to the following for the purpose of using the java app? AFR, AFR_command, CL_OL, IAM, IAT, Load, LTFT, MAF_V, MAP, RPM, Speed, STFT, Throttle Also from what I'm reading in the thread, I can do 15-20mins of crusing and then a bunch of WOT runs all in the same session/log and get a good scale in one shot? The info on injector scaling/ratios was interesting but don't quite understand it enough as yet. |
#237 | |
Tactrix will log about 20 parameters at about 20 times a second. you probably only need about 5 times a second for most things so you could leave all those parameters in. |
| The Following User Says Thank You to steve99 For This Useful Post: | tech86 (10-02-2014) |
#238 |
Drives: UK GT86
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | steve99 (10-03-2014) |
| AFR in Closed Loop | Toyota John | Software Tuning | 39 | 07-07-2019 09:26 AM |
| BRZedit Fuel Trims, Closed to Open loop transiton | mad_sb | Engine, Exhaust, Transmission | 32 | 08-06-2015 04:14 AM |
| Notes on injector / maf scalining using full time open loop | mad_sb | Software Tuning | 40 | 03-03-2014 06:49 PM |
| Screencast: closed loop boost control with RaceRom | jamesm | Software Tuning | 2 | 02-10-2014 03:23 PM |
| Screencast: experimenting with full-time closed loop fueling | jamesm | Software Tuning | 2 | 12-27-2013 11:19 AM |
