#15 |
Drives: 2013 Brz sport-tech
yah dude, our chevron here is total BS , i get a great tank where i can run a full 93oct tune with no knock, other times i get a tank where a 91tune is knocking like mad, i put 91vpower the knock stops and pulls smooth and steady, thus meaning at some times that 94 is of lesser quality than the 91. that is to me false marketing , to label a product as something it does not perform to
#16 | |
KCCO From Canada
Drives: Asphalt FRS
#17 | |
Off Topic
It's a low horsepower car, you probably don't need a full honey badger. I'd go with a mink first and work up from there. Mink are assholes. |
| The Following User Says Thank You to gramicci101 For This Useful Post: | SirBrass (05-02-2014) |
#18 | |
Trust me, I'm the Doctor
Daily Driver: 2014 BRZ 6MT Limited ^GT5 Replay Photo Mode^ |
#19 | |
Quick Trip's 91, though, is good stuff too. Not a fan of chevron ever since Clark Turner (almost a god among tuners of the turbo'd EJ motor) warned away turbo'd subies guys from it, saying how he can tell when an EJ has been running it for a while (significant loss of power from where it should be).
#20 | |
#21 |
Drives: 2013 GBS BRZ Limited
Any results with seafoam?
I was reading about "rejuvinating" a 99 Chevy Suburban, and a lot of people said it made a huge difference. The procedure for the Chevy was to allow the seafoam to be "ingested" by a vacuum line, so that method wouldnt help the HPFP. But putting it in the tank would make it pass through the hpfp. |
#22 | |
#23 |
Off Topic
I'd add it before, so the gas inflow would stir it around and provide a decent mix. If you pour it in after you put the gas in, you're basically depending on the additive to dissolve thoroughly into the full tank of gas.
#24 | |
I'm doing an all day corner-carving cruise around the back routes of central Arizona tomorrow, so I'll let that trip be the first several tanks of this stuff. I don't have crickets, but everyone always appends "yet" onto my statement.
#25 |
Off Topic
You can get it at Walmart, Autozone, anywhere that can service two stroke engines. I picked up a quart of Castrol 2-stroke with TCw3 from Autozone for about $4.
I'm using a 4 oz bottle from a previous fuel additive so I can keep it in the glove compartment. That'll get me through two tanks of gas. |
#26 |
Pull my finger...
Drives: Silver Scion Slushbox
I grew up on sleds and bikes and I'm completely aligned with your thinking, OP.
However, I can't help but think that the wrong oil, and not used sparingly could foul plugs and the proposition of having to check/change/clean plugs on the boxer doesn't sit well with me when things go wrong. Just a thought... |
#27 | |
| The Following User Says Thank You to BC-Boy For This Useful Post: | CircuitJerk (05-03-2014) |
#28 | |
On phone I am. Therefore, if mistakes I make, Frank Oz blame you should.
| Tags |
| chirping, noise |
| Plano Tx - Quaker Steak & Lube Meet | 20firestorm13 | Southwest | 1 | 06-03-2013 05:55 PM |
| So my girlfriend took the car to Jiffy Lube... | Mandy | Other Vehicles & General Automotive Discussions | 24 | 04-08-2013 03:35 PM |
| How shall I lube? | jimmillion | Off-Topic Lounge [WARNING: NO POLITICS] | 5 | 11-17-2012 02:13 AM |
| Anyone change transmission lube yet? | BMWDavid | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 14 | 08-21-2012 06:47 AM |
| the BMW killer! | RRnold | Off-Topic Lounge [WARNING: NO POLITICS] | 10 | 08-28-2010 02:48 AM |
