Old 10-09-2018, 03:42 PM   #29
covance
Drives: 2015 BRZ series.blue
Originally Posted by Muskokan View Post
Soo quick update on this, went to a few different body/detail shops around my area and was appalled to learn that a proper fix for both those chips would be around 1,000 bucks!!! Because of the white being a 3 stage, they'd have to paint the entire fender and roof.
Obviously, that's steep but that's to get it back to perfect. I'm broke ass so I ordered the touch up paint and I'll see how I can manage. Might post pics of the finished result if I don't muck it up too bad.
Think twice before winter driving a pearl car with weak ass paint!!!
I have the same issue - a paint chip on the roof that has rusted. Do you need to do anything before using the paint touch up pen? I was thinking of getting one of the 2 way pens where one side is the paint, the other is the clearcoat.
Do I just apply the paint over the rust spot, let it dry, then apply the clearcoat?
Thanks for your advice - I know nothing about paint/detailing.
covance is offline   Reply With Quote
Old 10-09-2018, 03:57 PM   #30
Pick up a prep pen sanding stick and get rid of every trace of rust. Make sure you get all loose paint as well. Then use the touch up paint.
The roof panel is very obviously not treated for rust resistance the same as the lower body panels. I have a major chip on the front fender that after 4 years and salty winters has some minor surface discoloration on the steel. I have 5 chips along the front of my roof that look like a 20 year old car already.
Old 10-09-2018, 05:51 PM   #31
Weigaldo
Weigaldo's Avatar
Drives: 2016 Steel AT FRS
I have some old IronX from when I used to work near a rail yard and was fighting fallout daily. If you can get some of that to knock out the rust before you apply, that's what I did. Then you can keep it around and detail a couple times a year with it. Much easier than claying. Also my method involves getting a dab of the paint on a piece of paper and applying with a toothpick. Once it dries too much make another small dab. Let it settle each time before you apply another layer. Unless you would rather over apply and then sand down with a circle of fine grit sand paper glued to the eraser tip of a pencil.
Weigaldo is offline   Reply With Quote
Search this Thread:
Advanced Search
Throw out bearing/Left Front speaker/Paint Chips 2014scionfrs Issues | Warranty | Recalls / TSB 11 01-06-2014 12:20 PM
304 SS rusting in two weeks? Anorax Engine, Exhaust, Transmission 91 06-11-2013 11:37 PM
My FRS is already rusting! shawnperolis Scion FR-S / Toyota 86 GT86 General Forum 17 04-29-2013 01:26 PM
Ding and Paint Chips! how to fix it? Tamoor Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 17 03-17-2013 09:29 AM
Anybody else's car rusting yet? Selvedge Issues | Warranty | Recalls / TSB 17 10-31-2012 10:11 AM
