Old 05-21-2014, 03:51 PM   #281
Originally Posted by sw20kosh View Post
@CSG Mike what oil cooler do you recommend after seeing some of these kits first hand and in action on the track?
The difficulty is actually finding an Off-the-shelf oil cooler that fits with an off-the-shelf FI kit.
So far, the only kit designed that way, is the Jackson Racing kits.
However, due to the mounting method of the NA version of the Jackson Racing Oil Cooler, it fits with a lot of FMICs that sit further forward in front of the AC condenser.
It doesn't hurt that the JR kit also includes a thermostatic plate and has a larger cooling capacity to boot.
If the off-the-shelf kits don't work, then you'll be best off piecing together your own using high quality components.
Old 05-21-2014, 03:53 PM   #282
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
Many kits use the same mishimoto core.
IMO, get one that has nylon braided wires (in lieu of SS braid) and has the best angle/adapter for the filter block. For street driving, make sure to get one with a thermostat in the oil block. I would also opt for one that mounts in the side fender if you ever plan on going FI.
Outside of that they are all very similar and can't really offer drastic differences.
Ironsquid is offline   Reply With Quote
Old 05-21-2014, 04:15 PM   #283
The Jackson Racing kit uses a Setrab core, and Aeroquip lines with full float fittings.
http://www.ft86club.com/forums/showthread.php?t=65715
Old 05-21-2014, 04:20 PM   #284
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Yeah that one is good, the FBM V2 one is good also.
The Following User Says Thank You to Ironsquid For This Useful Post:
CSG Mike (05-21-2014)
Old 05-21-2014, 05:47 PM   #285
Dipstik-sportech
Dipstik-sportech's Avatar
The fbm one fits my FI kit just fine because it mount behind the fog light
The Frozen North
The Following User Says Thank You to Dipstik-sportech For This Useful Post:
Old 05-24-2014, 12:44 AM   #286
mike the snake
Here's something I found that shows thermal imaging of a race car. I found it interesting, especially where they placed the hood vents.
http://www.1addicts.com/forums/showthread.php?t=989327
The Following User Says Thank You to mike the snake For This Useful Post:
juliog (05-25-2014)
Old 05-24-2014, 06:49 AM   #287
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Went to the track today. Car was running hot. It's the middle of summer right now, and ambient temp was 36C. After three hot laps, coolant was at 111C (232F), oil temp was 127C (260F). Temps were taken from the OBD port.
I have a Vortech Supercharger. Cooling mods are Perrin oil cooler and Koyo radiator. I can only imagine what the temps would be in a turbocharged car. Now I'm seriously considering getting a vented hood.
HRTROB is offline   Reply With Quote
Old 05-24-2014, 11:46 AM   #288
xwd
That's pretty cool. If you look at the GT300 BRZ it uses a turbo sitting in front of the engine and they have a large double vent right in front near there.
Old 05-24-2014, 01:34 PM   #289
mike the snake
If there were any decent plastic insert style vents I'd consider modifying my stock hood as well.
Just need to find something that looks good and is effective. Placement might be tricky with the under-structure though.
Old 05-24-2014, 01:50 PM   #290
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Those are the exact temps that I've seen at my last track event with Koyo Radiator and OEM oil cooler. I think maybe I can consider vented hoods and cutting the fender garnish to release heat for track days. With that said I've been using Mobil 1 0w-40 just for a safety net
glamcem is offline   Reply With Quote
Old 05-24-2014, 01:51 PM   #291
sw20kosh
Drives: 2013 Black FR-S
This is concerning. @csg_mike here is an overheating supercharger setup
Old 05-24-2014, 01:58 PM   #292
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
try amsoil dominator next and let us know if there is a change
Old 05-24-2014, 02:07 PM   #293
mike the snake
I've modded my skidplate, hoping to possibly avoid having to buy a vented hood. I still might need the hood for tracking, but I know my skidplate mod works. A LOT of heat is exhausted out through the hole in the skidplate, and the trip strips help pull the hot air out at speed.
ftc~brz (05-24-2014)
Old 05-24-2014, 03:20 PM   #294
glamcem
glamcem's Avatar
I don't think there would be any difference temp wise, the main reason I switched to thicker oil is because it just provides better lubrication at certain temps and higher flash points
going forced induction ft86me Forced Induction 14 02-05-2014 09:23 AM
So who is running Forced Induction and tracking their car? track_warrior Tracking / Autocross / HPDE / Drifting 88 08-20-2013 11:00 PM
Forced induction for ATs? Lokutus Forced Induction 10 02-26-2013 04:42 PM
NOS or Forced Induction? v3rgil AFRICA 1 11-08-2012 08:17 AM
Forced Induction Primo86 Engine, Exhaust, Transmission 11 05-29-2012 08:50 PM
