Old 05-13-2014, 05:31 AM   #197
diss7
Drives: AE86, 2x GT86, TE27
Any other challengers for those that think their FI can withstand even 1 lap of track driving by me?
Next time you're in NZ, have a go at mine.
diss7 is offline   Reply With Quote
Old 05-13-2014, 08:42 AM   #198
mike the snake
My goal is to address the heat issues so that Yes, my car could withstand track laps with you driving.
The Following User Says Thank You to mike the snake For This Useful Post:
CSG Mike (05-13-2014)
Old 05-13-2014, 10:34 AM   #199
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
The fans are more important than the radiator, IMO.
And what upgrades are there in that regard?
On phone I am. Therefore, if mistakes I make, Frank Oz blame you should.
^GT5 Replay Photo Mode^
Old 05-13-2014, 10:38 AM   #200
mike the snake
The shroud is as important as the fans IMO. It helps focus the air through the radiator.
SirBrass (05-13-2014)
Old 05-13-2014, 01:22 PM   #201
xwd
People have been combating temp issues on the WRX/STi for years since a lot of them are modded and use water-cooled turbos. In general if your coolant temp is under 210F you are okay. 220F and above you need to start looking at remedies. Here are the things I did on my WRX and is common:
1) Upgraded radiator and ducting. As noted in this thread the ducting is very important, you could probably not upgrade the core as long as the ducting is good.
2) 100% distilled water with water wetter. Antifreeze is terrible at eliminating heat. This alone dropped my coolant temps a good bit.
3) Higher pressure radiator cap, effectively raises the boiling point, more important if you aren't running antifreeze.
4) Lower temp thermostat (or no thermostat), coolant starts flowing sooner through the radiator before it reaches too high of a point.
5) Run the fans at high speed all the time. I don't know if the SPAL fans are variable speed when hooked up to the stock wiring, but when I had them in my WRX I used a relay and whenever the ECU kicked the fans on, the fans were running at high speed. Some just run the fans all the time on the track.
6) Oil cooler. Lower oil temps result in lower temps overall, oil retains a lot more heat than coolant.
7) Properly bled coolant system. Air pockets are the devil and will raise temps a ton in a hurry, make sure all of the air is out of the system.
The guy who was at 257/293. If the car comes out unscathed after that, it's pretty stout. No melted fans or anything else though?
Old 05-13-2014, 01:30 PM   #202
Jesse36m3
Jesse36m3's Avatar
Drives: JDL Turbo BRZ
Originally Posted by glamcem View Post
I have to disagree with some of the above comments ..yes, the tires, brakes and suspension mods make a lot of difference but I think we all have to agree that this car is very very slow in stock form simply because it doesn't make a healthy 200 hp with its torque dip... and OP already mentioned that he tracks his FRS regularly so don't you think that "address other issues before more power" line getting old?
Also "fast driver > fast car" is a very bold statement.. how much of a fast or technologically advanced car are we talking about here? sure a more experienced driver can make better lap times in his/hers slightly lesser car but I can almost guarantee you if you put a mediocre driver in a GT-R, he/she'll be always faster than your stock powered BRZ/FRS unless of course it's their very first track day or something wrong with the car simply because GT-R does everything for the driver and a lot easier to drive fast with confidence .. HP advantage makes up for the difference in many cases .. take a look at the below video that I took last week, I am pretty sure the driver in the GT3RS is a new driver or something (brake, tires) are wrong with his car since even I was a lot faster at tight corners and was able to catch him! the car pulls away like a train as soon as it sees a straightaway which makes it for the difference easily (my car is stock powered with Nitto NT01 R -comps) does that mean fast driver > fast car ? no, it only means fast driver > extremely slow driver (or fast car with a problem)
Long story short this car only lacks about 50hp ( stable hp without the dip) not some crazy amount of power but rather sufficient power to balance its weight
haha that Porsche was like "fuck you, bye" on the straight.
Jesse36m3 is offline   Reply With Quote
Old 05-13-2014, 02:02 PM   #203
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
won't happen again
glamcem is offline   Reply With Quote
Old 05-13-2014, 02:15 PM   #204
SirBrass
SirBrass's Avatar
Just to make sure I'm understanding you, by "radiator shroud" you mean something like this, right: http://ft86speedfactory.com/apr-carb...late-1341.html
Old 05-13-2014, 02:29 PM   #205
xwd
That could be one piece of it. The FBM "shroud" is a fan shroud, not a radiator shroud, it's only going to help you if air is being directed at the radiator surface correctly. The point of ducting/shrouds on the frontside is to make sure air doesn't escape around the radiator. It's all about eliminating gaps around the radiator.
The Following User Says Thank You to xwd For This Useful Post:
OjiGeorge (05-14-2014)
Old 05-13-2014, 02:38 PM   #206
SirBrass
SirBrass's Avatar
I understand that, and it makes sense. Path of least resistance. Just making sure I've got the right idea when putting in these parts. I've got time before I go FI, so I've got time to get my supporting mods done right ahead of time. Like these for cooling.
Old 05-13-2014, 02:50 PM   #207
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
This is one of the few reasons I am still considering buying and building another turbo BRZ. I would build it for track only just to go set laptimes and show that it is possible to you and everyone else.
The Following User Says Thank You to King Tut For This Useful Post:
Old 05-13-2014, 03:15 PM   #208
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
The PTuning kit seems to have faired well
http://www.ft86club.com/forums/showp...&postcount=341
Old 05-13-2014, 03:36 PM   #209
That's been said about various kits, and EVERY SINGLE turbo kit I've driven will overheat without me pushing the car remotely close to hard; the owners that have sat in the passenger seat with me can attest to that.
While I've yet to drive a PTuning kit in person, at this point, I'm skeptical of any setup until proven otherwise.
Oddly enough every supercharger setup (Innovate ic/non-ic, 91 and e85, Vortech various stages, and Jackson Racing) I've driven has not had the same heat issues.
MrC's 2013 FR-S:
GTX3076R
PTUNING prototype 4-1 race header
PTUNING prototype air/water Laminova oil cooler system
E65 tune running about 425whp
OEM hood
That car didn't overheat? Are you kidding me?
As a point of reference, stock Corvettes/Porsches/Lamborghinis/Ferraris all overheat.
Old 05-13-2014, 03:40 PM   #210
I have no doubt that it can be done. It's just that nobody's actually done it, yet.
going forced induction ft86me Forced Induction 14 02-05-2014 09:23 AM
So who is running Forced Induction and tracking their car? track_warrior Tracking / Autocross / HPDE / Drifting 88 08-20-2013 11:00 PM
Forced induction for ATs? Lokutus Forced Induction 10 02-26-2013 04:42 PM
NOS or Forced Induction? v3rgil AFRICA 1 11-08-2012 08:17 AM
Forced Induction Primo86 Engine, Exhaust, Transmission 11 05-29-2012 08:50 PM
