#169 |
Trust me, I'm the Doctor
You mean the v2 kit? Why? They've fixed the issues with the kit & the V3 is more than adequate for my future power goals.
On phone I am. Therefore, if mistakes I make, Frank Oz blame you should.
Daily Driver: 2014 BRZ 6MT Limited ^GT5 Replay Photo Mode^ |
#170 |
Great White
Drives: 2013 Whiteout FRS
All right guys, Yesterday I attended FT86 Cup at Streets of Willow CCW. I had never seen heat issues...before that day. As soon as I did my first two sessions I started seeing the coolant temperatures start to reach 210F. When I did my third session I saw it peak to almost 230F on my hot laps. Luckily I did not suffer any damage to the fans, but I had a feeling if I ended up staying for the last session than it would have melted them. Oil and Intake temps were perfectly stable.
I am going to order a 20amp 12" fan for the left side of the radiator, to see if I can pull some more air into that thing. Other than that everything performed well and I had a blast. Had a pretty high MPH spin that was the most awesome/scariest thing ever, luckily nothing was damaged at all. Definitely have to take care of this heat, or I might consider switching to supercharger.
Sterz' Great White 86 http://www.ft86club.com/forums/showthread.php?t=54533 Invidia Q300 Catback | Invidia Catless Frontpipe | Invidia Overpipe Last edited by Sterz; 05-12-2014 at 03:18 PM. |
#171 |
in orbe terrum non visi
Drives: violent
UNDER 230 isn't dangerous
Sent from my SAMSUNG-SGH-I747 using Tapatalk
I have E85 where there isn't E85, that's my secret.
http://www.ft86club.com/forums/showt...t=reaper+build |
| The Following User Says Thank You to Reaper For This Useful Post: | Sportsguy83 (05-12-2014) |
#172 |
NASA SpecE30 Racer
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#173 |
Drives: Attitude
#174 | |
Drives: Scion FR-S Whiteout
![]() I got to 260F in Buttonwillow, not really bad for the engine according to most people, but it will lose power. I installed an oil cooler and got to 228F max in SoW.
2013 Scion FR-S
#175 |
Great White
My point was that I was reaching 230F after 2 laps. If I had hot lapped for all 8 in the session I'm sure that I would be seeing temperatures that are starting to get pretty dangerous.
Sterz' Great White 86 http://www.ft86club.com/forums/showthread.php?t=54533 Invidia Q300 Catback | Invidia Catless Frontpipe | Invidia Overpipe |
#176 | |
| The Following 2 Users Say Thank You to CSG David For This Useful Post: | retrosmiths (05-12-2014), Sportsguy83 (05-12-2014) |
#177 | |
Great White
| The Following User Says Thank You to Sterz For This Useful Post: | CSG David (05-12-2014) |
#178 | |
2013 Scion FR-S
#179 |
Drives: Toyota 86
#180 | |
- @Sterz was running on wastegate pressure, which is his *lowest* output calibration. - The car is running E85 - The car has a FB Radiator, SPAL fans, and a FB shroud - Ambient temperature never went over 73F the whole day TL;DR: The car is NOT trackable in current condition, even with E85 and cooling mods. Additional (minor) tweaks were recommended to get the coolant temps under control. |
#181 |
One thing that no one has mentioned is if they have replaced any of the air dams that get removed when you install an aftermarket radiator.
The stock radiator has foam air dams that help duct air through the radiator, and all these go bye bye when installing aftermarket radiators, leaving a lot of area around and above the radiator that air can simply go around, instead of through the radiator. Replacing/fabricating the air dams/ducting so the air is directed through the radiator I think is one of the last pieces of the puzzle. The Spal fans and shroud make a big difference, but a LOT of air can go around and above the radiator without the air dams in place. |
#182 | |
Has anything been done regarding eliminating the engine bay hot air? Vented hood? Modded skidplate? Fender garnish vents?
Without Something to eliminate the hot engine bay air, I'd expect the same results. Quote:
| going forced induction | ft86me | Forced Induction | 14 | 02-05-2014 09:23 AM |
| So who is running Forced Induction and tracking their car? | track_warrior | Tracking / Autocross / HPDE / Drifting | 88 | 08-20-2013 11:00 PM |
| Forced induction for ATs? | Lokutus | Forced Induction | 10 | 02-26-2013 04:42 PM |
| NOS or Forced Induction? | v3rgil | AFRICA | 1 | 11-08-2012 08:17 AM |
| Forced Induction | Primo86 | Engine, Exhaust, Transmission | 11 | 05-29-2012 08:50 PM |
