86WORX
Old 05-03-2014, 11:29 AM   #29
Deslock
Deslock's Avatar
Drives: 2013 DZE/01 (sold for MX5 ND1)
Originally Posted by Weasel Soup View Post
Being completely locked out of second when the trans is cold
Out of curiosity, can you elaborate on this?
2nd gear in my BRZ can be a bit stiff when cold, but it's never been locked out.
Deslock is offline   Reply With Quote
Old 05-03-2014, 12:03 PM   #30
Harinjo
Harinjo's Avatar
Originally Posted by racecarshots View Post
It's funny, a Golf R is why I bought a FRS. I drove my friend's APR'd out Golf R and missed having fun driving. It sent me on a search for a new car that lead to the FRS.
Correct ^^
For me as german driving a golf r is like cold coffee compared to my brz (altough its a better car for everyday driving)
Harinjo is offline   Reply With Quote
Old 05-04-2014, 12:39 AM   #31
Weasel Soup
Veteran RallyCrosser
Weasel Soup's Avatar
Drives: 10 Series FR-S, 95 Escort Rally Car
Its happened multiple times. Car sits outside overnight and the temp drops to low 40s. I start the car, and drive off to work. I live off of a busy street and need second within 2 minutes of starting the car. Shifting at about 3,500-4,100 rpms and it WONT go into second. It takes multiple tries, clutching in between every attempt.
The car has about 1050 miles on it now, and the issue is getting better as we get further into spring/miles on the ODO. But rest assured I'm bringing the issue up to the dealer when it goes in for its 1000 mile check-up.
Everything should be attempted twice. Once to satisfy curiosity, and the second time to see if you like it.
My Journal
2016 SCCA RallyCross National Champion - Prepared Rear Wheel Drive
Weasel Soup is offline   Reply With Quote
Old 05-04-2014, 08:31 AM   #32
Deslock
Deslock's Avatar
That's abnormal. I've never encountered that behavior (15k+ miles, driven below freezing temps throughout two winters). Good luck.
Old 05-04-2014, 01:09 PM   #33
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Did you adjust the clutch?
Old 05-05-2014, 11:28 PM   #34
Weasel Soup
I have not adjusted anything that has anything to do with the drivetrain. I've seen threads about adjusting both the clutch and the reverse lock-out mechanism.
Perhaps I should start a thread in the drivetrain section, so as to not muck up this vs thread.
My Journal
The Following User Says Thank You to Weasel Soup For This Useful Post:
EAGLE5 (05-05-2014)
Old 05-06-2014, 02:10 AM   #35
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Had and encounter with an R32 the other day...dang that thing is fast in the corners and accelerates really quick from a stop. Lots of power and mechanical grip. Doesn't mean I'd want to have one - I don't particularly care for German car design philosophy at all...
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 05-07-2014, 09:31 AM   #36
slickd
slickd's Avatar
Drives: 2013 silver toyota 86 (high) man.
I have this problem with my 86 aswell. It appears to happen most when either the engine is cold (and hence the gearbox) or early in the morning. I can only assume that maybe the dropped temperatures also play their part on the transmission fluid which may cause it. Also just try pumping the clutch for about a minute and try shifting again
slickd is offline   Reply With Quote
Search this Thread:
Advanced Search
Golf Bag mattyboy311 Scion FR-S / Toyota 86 GT86 General Forum 21 06-17-2019 02:01 PM
86 vs 15 Golf R ? Whitigir FR-S / BRZ vs.... 69 02-01-2014 05:15 PM
Used Golf R32 or less used Golf R? Trashed675 Other Vehicles & General Automotive Discussions 32 01-24-2014 10:42 PM
Top Golf Anyone? Texaz Boy Southwest 0 11-15-2013 11:59 PM
ft86 vs. M1 vs Golf R..which one to get? CyberFormula Other Vehicles & General Automotive Discussions 17 07-07-2010 02:28 AM
