| BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
#16 |
Drives: 2017 Audi S3
You buy an automatic if you have to ask a question like this.
| The Following 4 Users Say Thank You to immaculate For This Useful Post: |
#17 |
Drives: Widebody '94 Miata R-Package
I usually drive in city traffic with lights so its FFFIIIRRRSSSTTTT!!! SSSSEEECCCOOONNDDDD!!!!! BBBBRRRRAAAKKKEEEE!!!! stop. repeat.
![]() I <3 my Miata. But I <3 my new BRZ even more! |
| The Following 4 Users Say Thank You to merlin2111 For This Useful Post: |
#18 |
Drives: white Sport-tech
If your asking, do the first method, your not confident in driving manuals. You don't wanna be having hi rev fun and over rev because you accidentally hit 3rd.
#19 |
Drives: Yes
Not a dumb question actually. Method 2, because less chance of getting stuck between gates
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
#20 |
Drive From Home
Drives: BRZ STI Performance
Use the method that is more consistent for you to get it right.
#21 | |
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
Shifting 2-3 you shift up and let the shifter center itself then push up again. You don't need to really push over much to the right. In fact, the only time I'm pushing right besides the shift into 5th is between 5 and 6. If you just pull straight down the spring will try to center the shifter and you'll hit the gate between 4 and 6. That's of course if you're not man-handling the shifter and slamming it from gear to gear. I've never had to replace a clutch or have syncros go bad in one of my cars. No transmission rebuilds. Just slip it into gear with a matched rpm and everything is good. I recognize I'm very much in the minority on this, even among enthusiasts. |
#22 | |
Drives: Yes
Some more seat time would probably have improved my accuracy, but I went the other route and just started doing method 2. No more missed shifts, so I stuck with it. Of course, I'm habitually making sure to push it to the right enough to clear the gate. Guess it all comes down to what the individual is most comfortable and consistent with
#23 |
Trust me, I'm the Doctor
in short, to sum up this thread:
In order to shift from 4th to 5th, you disengage the clutch, shift from 4th to 5th, and reengage the clutch. /thread
Daily Driver: 2014 BRZ 6MT Limited ^GT5 Replay Photo Mode^ |
| The Following 3 Users Say Thank You to SirBrass For This Useful Post: |
#24 | |
/dev/null
Drives: Uphill
May I suggest a few topics for new interesting threads: - Foot placement on ground when getting in and out of car - How to ease off the brake to have a smooth full stop - A/C settings for warm and cold weather |
| The Following 3 Users Say Thank You to Sarlacc For This Useful Post: |
#25 |
It's a good thing you are not dealing with a Hurst shifter from the '60s.
mrhemi |
#26 |
Just start off with whatever works, likely method where you push with a slanted force. After a while you'll get the feel for the gates and do it properly. the problem is that 5th is slightly 'out there' and we just do get enough practice making the shift since it's essentially all about merging on highways. Problem is doing it fast since gearing doesn't give you many RPMs of leeway from 4 -> 5.
#27 | |
Drives: 13' DGM Built FBM BRZ
I understand what your getting at. I sometimes wonder if you do method 2 that it rubs against other parts causing ware and tear eventually. I always did method 1 though. /shrug |
#28 |
Drives: MDX, Camry
Thanks for the considerate comments. That is exactly what I am getting at. In layman's theory, 2 should be easier on the shifter and transmission etc. However, if 1 is the correct approach, I would think Subaru must have done something about it. So if I do not do 2, I just do it wrong.
I have always been doing 1, but recently I started practicing 2. I heard somewhere before that if I can match the speed well, I can push the shifter into gear with two fingers easily. I actually can achieve this using 1. But it is very hard to achieve this effect using 2, since I got a lot of resistance in doing so. It feels that the gearbox is not very well lubricated and I forced the shifter in. The resistance is so big that I started to suspect whether it is the right thing to do. Anyway, I could not drive manual before I got my BRZ and learned driving manual from online. After 4000 miles I can now drive w/o too much drama. But I am always concerned whether my approach is optimal or not. Thanks for the help again. |
| The Following User Says Thank You to qqzj For This Useful Post: | Marcoscrdo (04-24-2014) |
| Shift resistance | amaciose | Engine, Exhaust, Transmission | 2 | 12-06-2013 09:53 PM |
| HUD shift up and shift down display question | JS86JS | Electronics | Audio | NAV | Infotainment | 6 | 05-17-2013 03:54 AM |
| Shift Knob | Zoomryder | Issues | Warranty | Recalls / TSB | 5 | 04-09-2013 09:39 PM |
| How do you shift? | Carbon420 | Scion FR-S / Toyota 86 GT86 General Forum | 27 | 12-30-2012 02:11 PM |
| Shift Knob | yomchi1989 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 12-07-2012 10:19 PM |
