#15 |
Superchargers take horsepower to make horsepower turbos don't. A centrifugal supercharger is basically a belt driven turbo so why bother when a turbo will do the same thing but better?
The Frozen North
#16 |
Drives: White 2013 FRS
Running a 2867r and the power comes on smooth and predictable. Was on the fence before going turbo, now that I have, I wouldn't even consider a SC for the 86. The high compression helps a lot when you are out of boost.
#17 |
Boosted Noob
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
If you live in CA, CARB EO status may be important to you. AFAIK, there aren't any CARB legal turbo kits. The innovate, Vortech, Jackson Racing, and (soon to be) Kraftwerks S/C kits with "factory" tuned are CARB legal. Comes in handy when it comes time to get a smog check 4-5 years down the line (or to avoid a fix-it ticket).
#18 | |
Drives: UK GT86
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | neutron256 (04-22-2014) |
#19 |
It uses wasted heat and exhaust energy to create horsepower that is essentially free. And if you use a system like anti lag it turns the turbo into basically a small gas turbine. But yes is does create a restriction but no where near as parasitic as a supercharger
The Frozen North
#20 |
Drives: ZN6 / GDB-G
You bought the wrong car if you really like 0-60, but I will say get a turbo kit because turbo. With a little boost, lets say around 0.7 bar or less, you will reduce the chances of breaking stuff, find a cooling solutions that can be installed with your turbo setup, and drive safely.
#21 |
NASA SpecE30 Racer
Has OP bought two of the big bottles yet?
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#22 |
Drives: 2014 BRZ AT
Now I'm more confused than I was originally. It seems like more people are saying turbo but I've read other threads where more people are saying SC. So I guess there are pros and cons to each.
I do not live in california by the way so I don't care about the weird emissions requirements, and we have 93 octane here. |
#23 | |
Supercharger gives you a good % bump in power. It's directly related to the engine speed (belt driven). Response is different and heat soaking characteristics are different. Power potential is lower than a turbo, but the kits available these days show that heat management isn't as much of an issues as turbos. There are a few reasons and it's simply due to where the heat comes from and how much less power superchargers are capable of pushing out compared to their turbo brethren. 0-60 time is as important with power as is with proper suspension and wheel/tire setup. With all that power, you better be able to put that power down. On top of that, 0-60 doesn't end there...what about slowing down properly? With additional weight and additional grip, your tires will be working a little hard to slow yourself down.
| The Following User Says Thank You to CSG David For This Useful Post: | WRXGuy1 (04-23-2014) |
#24 |
When was the last time you actually launched your car to do a 0-60?
Serious question. 5-60 times are more relevant to most people. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | SirBrass (04-22-2014) |
#25 |
Drives: Scion FR-S
I wanted linear acceleration for all around handling, a substantial power boost and the most reliability so I went with a supercharger.
It's a daily driver after all and the point of doing all this was for the car to be as fast as it looks. It makes a considerable difference over stock (ie: you can get in trouble very quickly). This summer I'm planning on buying Michelin Sports and maybe increasing the PSI with a smaller pulley. Should be fun! |
#26 | |
NASA SpecE30 Racer
- King Tut
| The Following User Says Thank You to King Tut For This Useful Post: | Mad1723 (04-23-2014) |
#27 |
Sad I didn't make the list
![]() The Frozen North
#28 |
Seņor Member
The best way to decide what you would prefer is get to a local meet and see if someone with each setup will take you for a spin or better yet let you drive. Then do your research. There is lots of info on what the different kits provide and are capable of.
Also keep in mind that any modifications of this level are not an install and forget affair. They will at least require a good amount of time tuning and tweaking. There will also be added maintenance.
1974 TA22 Celica
2013 86 GT |
| Tags |
| automatic transmission, supercharger, turbo |
| Looking for a turbo or supercharger kit!! | Anthony7515 | Want-To-Buy Requests | 11 | 05-16-2014 09:25 AM |
| Turbo or supercharger | dparnell | Southeast | 7 | 11-07-2013 03:40 PM |
| HKS Supercharger / Avo Turbo Kit / Greddy Turbo Kit - All Available at Import DPS!! | rickspecd | Forced Induction | 4 | 07-12-2013 12:50 PM |
| Supercharger or Turbo ? | #87 | Forced Induction | 192 | 01-25-2013 11:20 AM |
| Looking for a Frs for R&D on a turbo and supercharger | Toxic | Forced Induction | 38 | 10-23-2012 04:13 PM |
