#85 |
Drives: Toyota 86
Ravspec - Do Work release 18x9+30 in 5x100 or are they a special order?
#86 |
Drives: BRZ(sold), STI
Is all your info - with bare wheels or with tires mounted? My concern for 8" (and even for 7.5") +48 wheels is that even 225-wide rubber, tires could rub on the spring under load.
#87 |
Drives: Mitsubishi Evolution 1 GSR
I wanna run 18x9s all around.. sounds like 18x9 +30 in the front with coils should be okay. Yeah?
#88 |
Drives: 2008 Fit Sport
This may have been mentioned earlier but don't forget about the additional clearance you will have with a healthy dose of camber via your favorite adjustable suspension goodies. Another thought would be flaring that front fender out a bit to make something like an 18x9 +35 to 30 fit with a 245 or 255 tire. Its very likely with coilovers you will gain a good amount of clearance inboard. It seems to me like 18x9 +35 all around with a 255/35 tire would be achievable, with a little work of course, and probably be a very effective Non-Staggered track setup.
#89 |
Random Internet dad
Drives: 2013 FRS and 2010 Mini Cooper
Hrm so I saw the post about 18x8.5 +47, but would +44 make much of a change? I should easily clear suspension since you're moving the wheel more outward bound correct?
I'm still super new to the wheel dynamics and math involved, but it sounds like you'd gain 3mm of inside clearance. Would they still fit in the fenders in the front? I'm thinking at 225 40 tire on that, but not sure if it would rub on the suspension under load. |
#90 | |
Drives: Rx7
#91 | |
Drives: Rx7
Also 9.0 +38 with tires in the back will work as well. |
#92 |
Drives: Rx7
#93 |
Drives: Toyota 86
All good, placed an order with you on nasioc
#94 |
Drives: 1988 BMW M3 and 2012 Scion FRS
18x8 et40 with 235/40R18
Here is a pic of our FR-S 18X8 et40 235/40R18 Dunlop. The front is perfect and the rear could use about a 10mm spacer. I have a set of Forgedstar F14 being made 19X8.5 et 45 and 19X9.5 et 42. Should be here in a few weeks
| The Following 3 Users Say Thank You to CNC Autosports For This Useful Post: |
#95 |
Random Internet dad
What suspension is the car on? Is that still stock ride height?
#96 |
Its 1.5 lower front and rear with a set of tein springs we had and modified.
#97 |
Drives: Eight Six
Perfect cause the enkeis I was after is the same 18X8 et40. Now to start looking for some 10mm spacers for the rears.
#98 |
Drives: 86 GTS (PW) Manual
is it just me or does 18's look abit too big for a car this size? i mean this car is similar size to an s2k..
| Wheel Directory: Work Emotion XD9 18x9.0 +38 / 18x10.0 +38 | RavSpec | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 124 | 08-01-2016 11:38 PM |
| Wheel Directory: Work Emotion XD9 18x9.0 +38 / 18x10.0 +38 | RavSpec | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 53 | 05-26-2015 12:39 PM |
| Wheel Directory: Work Emotion XD9 18x10.0 +38 | FRS8SIX | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 34 | 05-23-2015 12:54 AM |
| Wheel Directory: Work VS-XX 18x9.0 +33 / 18x10.0 +33 | brunofrs | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 29 | 11-08-2013 01:26 AM |
| Wheel Directory: Work Emotion 11R 18x9.5 +30 | autofashionfred | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 24 | 08-11-2012 02:39 AM |
