Old 11-18-2015, 02:11 AM   #281
Aztec
Lost in the twisties
Aztec's Avatar
Drives: 2014 BRZ Dark Gray Metallic
Originally Posted by Dr Speed View Post
Interesting. I'll be surprised to see if you crack much over 210whp. Ill be watching for SAE dyno sheets and the smoothing factor, none of these bs Dyno sheets with STD numbers.
Good luck tho.
205-210whp is easily attainable with the right bolt-ons and E85 on the stock FA20. with the 2.3ltr and the right tune this will be able to be TUNED for much higher whp IMO
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft
Aztec's Build Thread
Aztec is offline   Reply With Quote
The Following 2 Users Say Thank You to Aztec For This Useful Post:
celek (11-18-2015), FRS Justin (12-15-2015)
Old 11-18-2015, 04:13 AM   #282
sw20kosh
Drives: 2013 Black FR-S
Good luck tho.
Lol people are hitting that with e85 and headers.
The Following User Says Thank You to sw20kosh For This Useful Post:
celek (11-18-2015)
Old 11-18-2015, 09:45 AM   #283
celek
Resident Gear Head
celek's Avatar
Originally Posted by Aztec View Post
I like how you slowly just ease a screwdriver into the hole and don't say anything :P
Yeah my day job is a public speaker but I can not stand the sound of my own voice.
celek is offline   Reply With Quote
Old 11-18-2015, 10:23 AM   #284
burdickjp
Drives: 2013 ultramarine Scion FR-S
Originally Posted by celek View Post
Also interesting, I did not know our stock cams were hollow and the lobes pressed on.
That's becoming increasingly common. I interned at a company in Danville, IL which made camshafts like that for Ford, VW, Chrysler, Harley Davidson, and Honda. It's a very cool process.
Sent from my SM-G900M using Tapatalk
burdickjp is offline   Reply With Quote
Old 11-18-2015, 02:51 PM   #285
Dr Speed
Drives: Red
Right but what do you think all this extra work will gain? Was the 205 on E85 Tune with Header measured in SAE with a smoothing Factor 5 or was it STD.
I have seen a few of these cars tuned, and while I don't own a BRZ/FRS personally I have seen claims for the car I own where people front manufacturer claims, or present dyno sheets in STD. That's just not accurate.
I'm sure OP will have fun, and I'm tuned in to see final numbers.. but to air on the negative side a bit, I think this will be a lot of work for not a lot of go vs FI vs tune only especially when you look at time, costs and reliability. I have been down this road with other platforms and learned hard lessons... like 7rwhp from a set of cams and $2000 in new parts and hours and hours of my time and trapping .4mph faster with an identical e.t
Honestly 300cc's extra, pistons and a set of cams and ported heads on this engine I would bet might add 10-12hp. Its already making 100hp per liter OEM or about 78-80whp per liter measured at the wheels
FI is getting guys into the 220-230 range conservatively SAE... you might hit that lower number with a full N/A build.
Dr Speed is offline   Reply With Quote
Old 11-18-2015, 03:23 PM   #286
swarb
If he didn't think it was worth it, he wouldn't be doing it
time? he is not in a rush, or it doesn't seem like it.
Cost? his money.
Reliability? should all be there depending on how high rev limit is.
By your math, 100hp per liter, .3 liter would be 30hp.
160whp stock. 24whp gain(by your math)
Car dynos 155-165 completely stock. header/e85/tune pulls 195-205 or so.
205+ that magical 24hp. 229hp
it is going to be a full build, so your math works out. I suggest you look at more dyno sheets
response in bold
The Following 3 Users Say Thank You to swarb For This Useful Post:
celek (11-19-2015), CxG (11-18-2015), skye67 (07-04-2016)
Old 11-18-2015, 03:35 PM   #287
Dr Speed
Drives: Red
Originally Posted by swarb View Post
response in bold
You are right my math does work out. I've looked at a lot of dyno sheets. I'm not discrediting the OP. I just finished a full build on another platform similar to what he is doing.
Just adding my two cents.
Old 11-18-2015, 04:16 PM   #288
200hp/tonne
200hp/tonne's Avatar
Drives: Raven Fr-S
All that math didn't even account for the raised rev limit. Assuming he makes 200 Nm torque at crank from the 2.3L at 9000 RPM, we end up with 253 crank BHp, which is quite a lot. With porting and a proper tune, this number should be easy to hit at those revs, as the engine makes more or less 200 Nm stock.
FR-S Mod target: 200 BHp / Tonne
4lb Li Battery, RPF1 17x9, 245 RE71R, RCE T2, OFH, OFT Stg 2, Berk Over+Front Pipe, , STI Eng/Trans Mts, PU Bushings, Forrester Liq-Liq oil cooler, Al Driveshaft, OSGiken Diff
200hp/tonne is offline   Reply With Quote
The Following 2 Users Say Thank You to 200hp/tonne For This Useful Post:
celek (11-19-2015), chaoskaze (11-18-2015)
Old 11-18-2015, 04:54 PM   #289
sato
sato's Avatar
Drives: Dodge Patitas
Isn't there a Mazda/Ford 2.3L engine (used in racing) that produced almost 300hp?
Sent using Tapatalk
Old 11-18-2015, 07:45 PM   #290
Snake
Drives: ADM Toyota 86 GT
http://www.cosworth.com/products/cra...ratec-engines/
280bhp for the top of the range 2.3ltr
Looks like they run dry sump, ITBs, 13:1 compression and 8500rpm limit.
Snake is offline   Reply With Quote
The Following User Says Thank You to Snake For This Useful Post:
Kronos (11-18-2015)
Old 11-18-2015, 10:27 PM   #291
Aztec
Aztec's Avatar
@celek What type of gearing are you planning on doing? Any sort of FD swap??
NEW CAR!🚨🏎️⛽
Old 11-19-2015, 12:30 PM   #292
celek
Resident Gear Head
celek's Avatar
response in bold
Not to mention everything is exponential.
If all I did was increase displacement to 2.3 liters and left everything else stock you are looking at a 15% increase to a base 230 Crank HP All the other addons work with each other.
Old 11-19-2015, 12:32 PM   #293
celek
Resident Gear Head
celek's Avatar
Its been considered but I do not want to go too crazy as the increased TQ and Power may not be a good combination of a really high Final Drive like 5.7:1
Old 11-19-2015, 12:35 PM   #294
celek
Resident Gear Head
celek's Avatar
Hopefully the meeting with Piper Cams at PRI proves successful. The current Cam profile stock falls flat at 7000 RPM. there is really no reason to go higher unless you have boost. In a NA platform its different you dont want to struggle with acceleration to 9000RPM not making power when you could have shifted to a new gear and be going faster.
The Following User Says Thank You to celek For This Useful Post:
CxG (11-19-2015)
2.3ltr, all motor, helpful, hks, hks stroker, informative, na brz
Search this Thread:
Advanced Search
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 08:52 PM
Ultimate coilover thread, What do you run on your car? got REVIEWS post it up! THMotorsports.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-11-2013 06:25 PM
The *ULTIMATE* Exhaust Thread by ECS Motorsports! | Over 2 Dozen Options! + FREE S&H! AJ@ECSMotorsports Engine, Exhaust, Bolt-Ons 27 09-05-2013 10:14 AM
*--->>ULTIMATE COILOVER THREAD<<---* The Best Deals + Free Shipping FT-86 SpeedFactory Brakes, Suspension, Chassis 95 01-30-2013 08:48 PM
Who's in for the long haul? Laika BRZ First-Gen (2012+) -- General Topics 47 07-09-2012 10:48 AM
