Old 04-19-2014, 09:43 PM   #29
Kolian
Kolian's Avatar
Drives: Raven Black scion frs
Question
Originally Posted by N1rve View Post
Get camber bolts LOL. I believe I've read somewhere on here that the lower the car gets, the more camber you'll get... it's just the nature of the car.
We'll the car was stock hight my springs are being installed today. And alignment should be done in 2-3 days I want them to settle first. So I should buy camber bolts for front and rear?
Kolian is offline   Reply With Quote
Old 04-19-2014, 10:26 PM   #30
ZionsWrath
Thanks
ZionsWrath's Avatar
Originally Posted by Kolian View Post
No it does not look like that my rear tires are straight with my fenders and looks fully straight all around the car no camber and nothing like the picture.
Stock rear has visible camber. Ask for the printout from the alignment machine or at least take a pic of the screen when he is done.
The Following User Says Thank You to ZionsWrath For This Useful Post:
FRSBRZGT86FAN (04-19-2014)
Old 04-19-2014, 10:31 PM   #31
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
So what can I do to fix camber wear?
Camber bolts or plates, or actually get a a dealership that knows what they're doing alignment wise (no offense but all the signs point towards camber issues)
Sent from my SGH-T999L using Tapatalk
Old 04-19-2014, 10:33 PM   #32
FRSBRZGT86FAN
Not yet figure out the issue first you might not need them yet, also be aware that you should contact whoever did the alignment initially to give back your money
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
ftc~brz (04-29-2014)
Old 04-20-2014, 12:02 AM   #33
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
The only way to adjust rear camber is lower control arms or whiteline adjustable upper control arm bushings.
And like someone said get a printout from the alignment shop. Dont take their word that its ok. Also the factory range is fairly large so it could be camber and toe is at the extreme end of the spectrum combines with too much tire pressure.
How many miles on the tires? Have you rotated them?
Old 04-20-2014, 01:36 AM   #34
naticedog04
Drives: 02 RSX-type s(sold) 99 Civic CX
Its probably not ur camber unless the car is "hella flush"... And staggered... Lower ur tire pressure and make sure ur "toe" is perfectly unlined. The "toe" of the car is the most important part of ur alignment, next comes camber, and last is caster. Fix ur "toe" and most of ur tire wear will be fixed. If problem persist, then fix ur camber by purchasing a rear camber kit since u said it was mainly the rear tires.
naticedog04 is offline   Reply With Quote
Old 04-20-2014, 01:44 AM   #35
Kolian
Kolian's Avatar
Smile
Thank you. Can I fix the toe myself or alignment shop? And the tires have about 3k miles on them and the back are really worn on the inside. They have not been rotated they are staggered back ones are about an inch wider and they are a little bit stretched.
Thanks for the help everyone!!
Old 04-20-2014, 03:02 PM   #36
naticedog04
Its possible to do a toe alignment urself... Read the write-up from this link and see if its something u would like to try... http://www.negative-camber.org/jam14...alignment.html .... If you're not sure, i recomend taking ur car to another alignment shop and tell them to align ur rear toe.
Old 04-21-2014, 01:51 PM   #37
Kolian
Kolian's Avatar
Smile
Thanks you i will just take it to the alignment shop and have them fix my toe.
Old 04-21-2014, 04:22 PM   #38
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Just for your FYI....
Toe Vs Camber
As you can see, Toe is more of the edge but camber is the inside half of the tire.
N1rve
The Following User Says Thank You to N1rve For This Useful Post:
Old 04-21-2014, 04:51 PM   #39
8R6
8R6's Avatar
Drives: FRS
sounds like a toe issue. incorrect toe specs will do way more damage than just camber.
8R6 is offline   Reply With Quote
The Following User Says Thank You to 8R6 For This Useful Post:
questions, rims, tires, tread life
Odd rear tire wear...anyone else? BRZnut Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 03-09-2014 08:31 PM
Let's Discuss Tire Wear SkitterSkotter Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 01-15-2014 12:35 AM
staggered setup - how's the tire wear? cfordart Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 04-21-2013 01:27 PM
question about tire wear driver01 Tracking / Autocross / HPDE / Drifting 8 08-05-2012 10:50 PM
Outer tire wear at track? fasteddy Tracking / Autocross / HPDE / Drifting 20 07-24-2012 02:16 PM
