#29 |
Factory is definitely not an H1 on the FR-S or the BRZ. Most aftermarket housings use H1 & H7 if that's what you meant.
D2S is an OEM HID bulb size, and will produce much more output than an H1 Nick C.
#30 |
Drives: 2015 scion FR-S
can somebody please help me on what to do with wiring?
I used a T tap connector to tap the white boomerang wire to the daytime running light red wire on the bottom of the bumper. It worked for about 10 seconds and then went dead. Now the daytime running lights and the boomerang will not turn on. My FRS is a 2015 and it comes stock with the LED strip daytime running lights. I connected white boomerang wire to red positive in DRL wire. The black is grounded to the chasis. |
#31 | |
Drives: 2013 Firestorm FRS
#32 |
| The Following User Says Thank You to tazz786 For This Useful Post: | continuecrushing (11-09-2016) |
#33 |
I got the Spec D & D4S H11 kit from Ft86speedfactory but after doing my research on here everyone says they don't work so I didn't even try to install them. Long story short what is the proper size for these lights?
#34 | |
Drives: 2014 FR-S
Here is the Spec D page. Check the third picture, the rear of the housing. The round plastic thing on the left covers the headlight connector. Turn to remove this and the bulb is behind there. Unbox your HID kit and find the HID bulb, follow the wire and it should run into a round rubber piece. At the rubber piece there should be another wire with a connector on it. The HID bulb and connector will be on the same side of the round rubber piece. This connector will plug into the same socket as the bulb that came with the Spec D headlight. You need to drill a hole in the plastic cover thing to run the bulb and connector through. Then plug the hole with the rubber thing. The ballast and igniter will stay outside the housing just mount them some place. |
#35 |
Drives: 2015 FRS Firestorm Red
anyone else figure out how to connect an hid kit ever since they changed the connectors to this?
#37 |
#38 |
Drives: Pearl White '13 ZN6
so guys quick question... what do we do if one of the boomerangs go out? like am I SOL here?
#39 |
#40 |
Drives: scion frs
![]() Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to zman For This Useful Post: | Teseo (01-20-2017) |
#41 |
Drives: frs
OP pictures doesnt show
Edit: i want those headlights but the wiring stuff overwhelming to me. Its possible to let the boomerang in all time? Did i need to buy HID kit also, or is optional? |
#42 | |
Drives: scion frs
No need for HiDs. You could have them on all the time, just need to find a wire with 12v. I used T taps on mine which come on with the DRL lights Sent from my iPhone using Tapatalk |
| Springs! Post your Pics!! | stevohl | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 113 | 11-10-2016 03:30 PM |
| Cat/Car pics, post yours :) | ZionsWrath | Other Vehicles & General Automotive Discussions | 18 | 08-10-2014 12:26 PM |
| Post your winter pics | kidgogeta | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 13 | 12-16-2013 02:52 PM |
| Raven Only! Post Pics! | imlevinit | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 1 | 07-06-2012 08:41 PM |
