#99 | |
The Antiriced
Drives: women wild
#100 | |
Drives: 2013 GBS BRZ Limited
I meant that I can down shift through all 5 gears 6->5->4->3->2 all without using the clutch. And you can skip gears up or down at any time and the transmission does not know the difference. Of COURSE if you do not rev match and try to make such a large rev change, it is harder on your synchros. |
#101 |
I do most of my town driving in 4th, coming to stops I down shift to 3rd (with rev match, I don't like excessive engine braking bust coasting with proper match is fine by me) and then coast in 3rd, clutch out at 2K then ride brakes to stop. I used to downshift all the way to 2nd but I find I'd rather loose a bit more brake than clutch as you'll always rub a bit coming down from that shift.
On occasion I'll heel-toe all the way down to 2nd and take corners with some speed
#102 |
Drives: 2006 Cayman S, 2007 Outback 2.5i
I skip gears all the time, and it isn't ever a problem. I tend not to be in a hurry when skipping gears though, so as a result, I don't miss the one I'm aiming for. The main time I'd be concerned with missing a shift and going into the wrong gear would be on a track, when I am trying to shift quickly and near redline.
#103 | ||
There's two ways to look at it, downshifting by rowing into each gear (5, 4, 3, 2, etc) keeps the synchros from being overworked by doing a little work at a time for each gear, instead of jumping straight from 5 to 2, which would require the #2 synchro to do excessive work. The proper way to single clutch downshift employs two techniques, rev matching, and heel & toe. Rev matching simply matches speeds before reengaging the clutch, and heel/toe allows you to apply the brakes (typically with the inside ball of your foot) and pivot the outer edge or your heel to blip the throttle. This allows you to brake while simultaneously blipping the throttle to downshift each gear. |
#104 |
I'll use engine braking only if I need to in an emergency stop or lessen the stopping distance. Otherwise I use the brakes for stopping and the trans for moving.
#105 |
I don't understand this mentality - if you need to stop in the shortest distance possible, the best way to achieve this is to push the brake pedal to the floor as hard as you can (well into ABS territory) (Yes, I know, thershold braking can theoretically be slightly better in some circumstances, but I don't want to get into that detail at the moment). Engine braking will not add anything to this, aside from distracting you from using the brakes. In an emergency stop, I will always go "both feet in": brake pedal to the floor, clutch pedal to the floor.
#106 |
Drives: Scion
Interesting thread. What do you guys do when you're approaching a red light and then it turns green all of a sudden while slowing down to about 30mph in neutral?
#107 | |
#108 | |
#109 | |
#110 |
I was just paying closer attention to how I drive while out getting some datalogs.
It is essentially impossible for me to take a corner without being in gear. So it is just natural (and automatic in my brain) to downshift into the correct gear for the speed I intend to take on the next corner. It felt very unnatural for me to coast to a corner, so I guess I downshift all of the time. |
#111 |
You aren't the only one with years of driving experience
![]() If you're braking to the point of ABS, it won't do a thing other than distract you. You're already at the limits of grip on all 4 wheels, so if you're adding braking force by engine braking, the ABS will let off the brakes in the back to compensate (to keep them from locking up). Now, if you're good at it (not letting off at all on the brakes when downshifting, and heel-toeing properly), it won't hurt things either, but I don't see any reason to do it when it doesn't shorten your stopping distance. |
| The Following User Says Thank You to chrisl For This Useful Post: | stevesnj (04-23-2014) |
| A Week of A/T Manual Shifting Mode | Ocala FR-S | Scion FR-S / Toyota 86 GT86 General Forum | 98 | 05-15-2013 03:35 AM |
| TRADE: my Silver GT Manual (October Delivery) for Pegasus White GT Manual -AUSTRALIA | ysagisan | Cars for Sale/Trade | 0 | 09-19-2012 12:24 PM |
| MT Shifting | n8dog11914 | Engine, Exhaust, Transmission | 4 | 08-28-2012 04:28 PM |
| shifting and down shifting feel | Lowellrenzo | Scion FR-S / Toyota 86 GT86 General Forum | 23 | 07-08-2012 06:09 PM |
| SWP and WRB Limited/Manual, WRB Premium/Manual + SS Prem Auto available in Colorado | huma | BRZ First-Gen (2012+) -- General Topics | 15 | 06-14-2012 12:33 PM |
