#687 | |
Drives: Hydra EMS Powered FRS Raven Black
There is nothing inside your FA motor at all that makes it so special you have to run 20w oil. That is a complete myth perpetuated by owner manual readers and not engine specialists. Viscosity changes with temperature so you pick your oil weight based on your demands. 20w gets the job done in NA form due to low power an effort to reduce drag, and better fuel economy. Add a turbo and look Subaru recommends 5w30 on the WRX FA20 (yes we build those two andI know everything about the internal measurements there). Subaru also fitted a larger oil pump and we all know why. : Anyways just stating the facts. Run any oil weight you want.....there's no voodoo!
| The Following 3 Users Say Thank You to Element Tuning For This Useful Post: |
#688 | |
What I would do and recommend would make your pocketbook very light. LOL! If you've already built your motor, roll the dice but put a pressure gauge on and monitor it like a hawk. |
| The Following 2 Users Say Thank You to Element Tuning For This Useful Post: | sam69 (03-01-2016), whataboutbob (03-06-2016) |
#689 | |
Drives: 1FRS, 1 BRZ, 2S2000s, Evo8, Dak.R/T
#690 |
| The Following 5 Users Say Thank You to Element Tuning For This Useful Post: | BRZGM3 (02-25-2016), Calum (02-25-2016), flippy (04-09-2022), Griever423 (03-02-2016), killboy (02-24-2016) |
#691 |
It just doesn't handle like it used to.
| The Following 14 Users Say Thank You to killboy For This Useful Post: | Bykov (02-25-2016), Calum (02-25-2016), chaoskaze (02-25-2016), choiboie (02-25-2016), DocWalt (02-24-2016), flippy (04-09-2022), johan (02-25-2016), new2subaru (03-01-2016), P@ul (03-04-2016), RavioliG (09-01-2017), sato (02-25-2016), Spartarus (02-25-2016), texasbound972 (03-05-2016), Ultramaroon (03-01-2016) |
#692 | |
Drives: GT86, SQ5, RS3
#693 |
#694 |
Ok i'm a bit confused then as to how your setup worked as I thought you were running the upgraded stock pump with a scavenge pump.
#695 | |
The external oil pump has never proven better than the OEM pump at delivering optimal oil pressure. I am only testing the pressure stage because that is the most critical (not the scavenge stages). What would the point of releasing a 3 stage $6k dry sump kit when it produces less oil pressure than the OEM pump? We've got 95% of the hardcore power guys handled with our motor builds. Any power you can throw at it, we've got you covered for drag racing and street abuse. It's the last 5% who are high power road racers (400+ hp) that we are trying to help. |
#696 |
USMC
Drives: 2013 FR-S 6-MT Raven
#697 | |
That Guy
Drives: 2013 asphalt FRS MT
#698 |
USMC
Just some info about what oil subaru recommends running if there is a turbo or not. Big debate over oil.
Sent from my SAMSUNG-SM-N920A using Tapatalk |
#699 |
That Guy
The only people that debate about which oil to use are the ones that don't know enough to make the decision based solely on facts. I don't have that knowledge, but the original poster certainly does. I know enough to understand that bearing clearances, bearing size, connecting rod force, oil temperature, and oil pressure are involved in the decision. Based on that, it should be obvious that the oil properties should be based on what the engine is going to be used for. Elemental Tuning builds their engines and they know exactly what each of those parameters is, so they are well aware of what oil they should be using in their builds to suit various end users.
| The Following User Says Thank You to Calum For This Useful Post: | texasbound972 (03-06-2016) |
#700 | |
If you have triple the oem power and you run your oil at 280 degrees under track conditions, you do not use the oem oil viscosity. |
| The Following 9 Users Say Thank You to Element Tuning For This Useful Post: | Bykov (03-06-2016), Calum (03-07-2016), CxG (03-17-2016), DustinS (03-07-2016), flippy (04-09-2022), FT-86 SpeedFactory (11-23-2016), killboy (06-25-2016), texasbound972 (03-06-2016), The Racers Line (03-06-2016) |
| FA20 Engine component photos | Crawford | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 89 | 02-22-2016 03:31 AM |
| FA20 Engine component photos | Crawford | Engine, Exhaust, Transmission | 46 | 01-26-2015 06:19 AM |
| Engine Hardware, Gaskets, & Bearings Oh My; All on sale at FR Sport. | FRSport.com | Engine, Exhaust, Bolt-Ons | 0 | 01-10-2014 01:33 PM |
| FA20 Le Mans Race Engine | SilverSkyline210 | Engine, Exhaust, Transmission | 11 | 11-18-2013 12:24 AM |
