Old 04-15-2014, 02:59 PM   #1
shif7i7down
Erected Member
Drives: frs
FI kit that does not throw CEL's and can pass readiness check
Just as the title states. What turbo or SC kit will pass readiness check and does not throw CEL's. Emissions equipment must be intact and functional to pass readiness check, no cel delete accepted.
Thanks in advance
shif7i7down is offline   Reply With Quote
Old 04-15-2014, 03:36 PM   #2
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
i think any of the superchargers would pass. they would have to be tuned but none of them should throw CELs if tuned well. none of the turbos would pass if having both cats is a requirement.
FreshFRS is offline   Reply With Quote
Old 04-15-2014, 03:42 PM   #3
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I would say a front mount turbo kit is good, I'm not sure about SC kits.
All you would need is a high flow catted UEL or EL header over pipe and a high flow cat front pipe from nameless or whoever, then catback.
Old 04-15-2014, 03:56 PM   #4
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
Most rear-mounted turbo kits CAN retain the factory emissions system.
Ironsquid is offline   Reply With Quote
Old 04-15-2014, 04:02 PM   #5
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
super charger, or a kit that has a cat in header and allows you to retain factory cat back I suppose.
Old 04-15-2014, 04:28 PM   #6
wparsons
wparsons's Avatar
Do you actually need a cat to pass the readiness check with O2 sensors? My understanding is that the sensors have to be there, but they will report a valid ready state even if the value should be throwing a CEL?
If I'm right, you can disable the CEL(s) in the tune, and keep the sensors and it should pass the readiness check without issue as long as the sensors aren't old/defective.
flickr
Old 04-15-2014, 04:40 PM   #7
shif7i7down
Erected Member
Drives: frs
Not sure if disabling a cel would work for readiness check. Unless you could somehow use a tune to force readiness which I'm not sure if it's even possible or if a tuner/vendor would be willing to break epa regulations in a emissions enforced county just to sell their kit.
Old 04-15-2014, 04:44 PM   #8
mrk1
Drives: Sterling BRZ Ltd
Find a shop in your state and discuss with them, every state is different. No CEL's isn't hard to do.
Aren't there a few SC kits with CARB approval.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 04-15-2014, 04:48 PM   #9
mrk1
Readiness and CEL's are 2 different things. Some softwares can force readiness I haven't looked yet to see if ecutek will. Also forcing readiness doesn't always mean you cheat the tests, it can mean you short cut the sometimes long procedures required to achieve readiness. I know back in my service days I would often drive a car around all day trying to hit all the requirements.
The Build Thread
Old 04-15-2014, 04:56 PM   #10
shif7i7down
Erected Member
Drives: frs
In my county they only check the obd2 to make sure that your emissions control equipment are working and intact. Also there must be no cel.
Old 04-15-2014, 05:09 PM   #11
TemeCal
Drives: 86
The Innovate kits will pass this. I'm sure the JR, KW(possibly?) and Vortech kits would too.
TemeCal is offline   Reply With Quote
Old 04-15-2014, 05:32 PM   #12
shif7i7down
Erected Member
Drives: frs
awesome, now.. how about the turbo kits..
Old 04-15-2014, 05:36 PM   #13
Model Citizen
Lacking brains
Drives: frz
Previously on subarus Access tuner race can force readiness, from what i've read it was introduced when cobb hired one of the guys who did a lot of the open source work, so i'm assuming it was available on that too.
If those platforms have it it can be implemented elsewhere.
From what I've gathered in the last year or so issues can arise in certain states (mass) from just disabling a readiness monitor. Setting a monitor as not supported may get rid of a cel and work in many states, but in some it will fail.
Model Citizen is offline   Reply With Quote
Old 04-15-2014, 05:50 PM   #14
wparsons
wparsons's Avatar
Does disabling the CEL actually affect readiness though? A ready state just means the sensor is functioning and has met driving conditions for the ECU to trust the readings from it.
Disabling the CEL in the ROM shouldn't change that at all, it should just stop the ECU from interpreting the reading and storing a CEL.
IE: No cat, secondary O2 sensor reading would be indicating a bad cat. The sensor is still ready and working. If the CEL is disabled the sensor is still ready and working, it's just not tripping a code.
flickr
Will headers cause me to not pass smog? 67corvette Engine, Exhaust, Transmission 39 11-13-2018 12:12 PM
Forcing readiness, which tuning platforms can? utekineir Software Tuning 1 12-22-2013 01:55 PM
Franschhoek pass closed for some time Vladror AFRICA 1 11-18-2013 08:28 AM
MAYBE Marylanders Rejoice and Throw Away your Relocators!Check Back Oct 1 kanundrum Mid-Atlantic 38 10-01-2013 11:11 PM
Race left, pass right? dem00n Off-Topic Lounge [WARNING: NO POLITICS] 7 09-16-2013 03:19 AM
