| BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
#29 |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
After 6 weeks of waiting, it finally showed up! I absolutely love having this arm rest installed, I honestly think it should have been there from the factory (or at least a dealer option).
| The Following User Says Thank You to BirdTRD For This Useful Post: | qqzj (04-27-2014) |
#30 |
Drives: MDX, Camry
Looks really nice, congratulations! I debated and debated and finally I figured out that I like this design slightly better. The cup holder on the door is actually tall enough for my tumbler. So this design will offer more functionality than the Scion OEM one, IMHO.
How long did it take you to install this arm rest? I am a little afraid to drill into my car, seriously. Have you had a lot of trouble drilling? Thanks. |
| The Following User Says Thank You to qqzj For This Useful Post: | BirdTRD (04-27-2014) |
#31 |
Simply Forgotus
Just take your time and follow the instructions carefully, found here-> http://www.toyota-tech.eu/aimuploads..._002_827_0.pdf The only thing I did differently was to use the paper template only to mark the 5 alignment pin holes on the hinge side (3 for pins and 2 for screw heads to sit flush into, shown on page 11 of 17). Once those holes were drilled and cleaned out, I used the actual mounting frame to mark the remaining mounting holes. Also, remove the padded top part from the top frame before you start to make life easy on yourself (6 internal hex screws covered by black plastic caps on the underside of the top part). You will definitely need a de-burring tool of some sort (rat tail file, Dremel tool etc.) to clean out the crap from the freshly drilled holes so everything fits perfectly, just don't go crazy and make your holes too big. Took me about an hour or so to do. $200 is pricey but to me it's worth it!
#32 | |
Drives: MDX, Camry
I looked at that UK company's website, it is $187-ish for the cover itself and then 21 UK pounds for shipping. If so, why not buy from some JDM sellers in US? Cost about the same and probably less wait.
#33 |
Simply Forgotus
The only other place I found it was Nigel-JDMparts and the price was about the same. Had I known it was going to take 6 weeks from CTP........but I think there must have been an issue with customs or something, CTP sent it out pretty quickly.
#34 |
Drives: MDX, Camry
Placed the order 5 minutes ago at
http://www.fteightysix.com/new-produ.../#.U2GQGFfRbxs slightly more expensive than the UK place. But I just cannot wait any more ... The seller is great. Do not forget to ask for a coupon here. |
#35 |
Drives: '13 GBS BRZ Lim, 2006 Dodge RAM MC
I just got the $70 amazon one. Love it! Very flexible in it's placement options. Quality is top rate, and it's "relatively" cheap.
#36 |
I love peanut butter
Drives: 2013 SWP BRZ Limited
| My idea for a center arm rest / console cover / center cup holder | ravenblackfrs | Cosmetic Modification (Interior/Exterior/Lighting) | 67 | 02-13-2016 04:00 PM |
| Center Arm rest | steve2800 | Interior Parts (Incl. Lighting) | 0 | 09-20-2013 03:13 PM |
| Center arm rest? Did anyone buy these? | Wilsonk227 | BRZ First-Gen (2012+) -- General Topics | 54 | 07-25-2013 04:42 PM |
| Center Arm Rest...Install | Scooby South | Cosmetic Modification (Interior/Exterior/Lighting) | 11 | 04-03-2013 01:59 PM |
| Center arm rest | speedracer38 | BRZ First-Gen (2012+) -- General Topics | 7 | 06-05-2012 02:27 PM |
