86WORX
Goomba_james
Old 06-05-2014, 10:53 PM   #239
nelsmar
Originally Posted by sw20kosh View Post
So 320 whp dynojet on AZ91 oct?
Quite possibly around that!
Originally Posted by FR-S Matt View Post
I think you need a larger turbo, @nelsmar
Glad to see you back up and running bud.
The plot posted wasn't mine! Lol I haven't strapped mine down for actual power yet. I need to swap my injectors out I maxed them out at 18-19psi I was looking at iniectors today and trying to decide what to order... I'm sure my
3071 will be big enough :P
My flickr - Canibeat
Local magazine scout
The Following User Says Thank You to nelsmar For This Useful Post:
FR-S Matt (06-05-2014)
Old 06-05-2014, 11:47 PM   #240
FR-S Matt
Oh I know that plot wasn't yours. Expecting 450+ on yours.
Old 06-10-2014, 11:07 AM   #241
BRZ68
Drives: BRZ m/t
@steveoexige @dwx @JDLAutoDesign Can you guys confirm the exact fittings you used with your RacerX oil pan when plugging the JDL return oil line ? Do you know if Map Performance's or FullBlown's oil pans will fit well with the JDL EL turbo manifold? Im currently in the market for a larger pan right to help with the temps. Thanks
BRZ68 is offline   Reply With Quote
Old 06-10-2014, 01:48 PM   #242
xwd
All of the pans should work with the EL manifold. FBM/MAP's turbo manifolds are the same basic design as JDLs. The MAP pan is more extra capacity at 1.5q vs. 1.0, it comes with a -10AN to 3/8 NPT fitting I believe. It's around the side of the pan instead of right in front like the RacerX. The FBM is even more capacity, I think it is an extra 2q at least.
The fitting on the JDL side of the line is -10AN and the pan is 1/2 NPT. You can easily find -10AN to 1/2 NPT fittings from just about everywhere. I was curious if they just used a straight fitting or any kind of angle? Or if the oil return line is short enough you could just use a 1/2 NPT to barb fitting?
The Following User Says Thank You to xwd For This Useful Post:
BRZ68 (06-10-2014)
Old 08-12-2014, 11:25 PM   #243
Jesse@JDLAutodesign
Jesse@JDLAutodesign's Avatar
Drives: 2013 Raven Black FRS
Well it's been a bit since this thread has been posted in. We've got a bunch more kits out there now, and working a few new ones along with getting a few things lined up for SEMA this year.
The guys at Speed Element Performance are running one of our UEL kit's with a gtx3071 on there infamous FRS
We're also working on a Borg Warner EFR spec kit for the guys over at Delicious Tuning!
Jesse@JDLAutodesign is offline   Reply With Quote
The Following 2 Users Say Thank You to Jesse@JDLAutodesign For This Useful Post:
ThisGuy919 (08-13-2014)
Old 08-13-2014, 02:28 AM   #244
ThisGuy919
Top notch quality and great support! Still in the process of putting mine together but everything looks great so far! cant wait to finish it up and write a review (and not get banned to update).
ThisGuy919 is offline   Reply With Quote
Old 08-13-2014, 09:16 AM   #245
Fr-s.h
Drives: Golden White
[/QUOTE]
I wish that efr kit was out 3 months ago, I see the turbo manifold is different, does this mean it will be a more involved process to switch over to efr? Or can you still reuse parts from you base kit?
`13 Whiteout Fr-s.h
Fr-s.h is offline   Reply With Quote
Old 08-13-2014, 11:49 AM   #246
xwd
I asked Jesse in the sale thread, the EFR requires a new manifold, downpipe, and hot-side IC pipe. Probably new coolant/oil lines as well.
Fr-s.h (08-13-2014)
Old 08-13-2014, 11:56 AM   #247
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
mostly because its ginormous.
LSx Powered 86/ASE Master Certified Automotive Technician
AZFA20 is offline   Reply With Quote
The Following User Says Thank You to AZFA20 For This Useful Post:
Old 08-13-2014, 01:09 PM   #248
JDLAutoDesign
JDLAutoDesign's Avatar
Drives: 13 FRS
Due to the external size of the turbo and the location internal wastegate actuator the turbo placement is not the same. This requires a new manifold, downpipe, and IC piping.
JDLAutoDesign is offline   Reply With Quote
The Following User Says Thank You to JDLAutoDesign For This Useful Post:
Fr-s.h (08-13-2014)
Old 08-13-2014, 10:19 PM   #249
Fr-s.h
Things only get better, good luck with the new kit, its gonna be a beast.
Tuned in.
`13 Whiteout Fr-s.h
Old 08-19-2014, 09:04 PM   #250
Jesse@JDLAutodesign
Every Lb counts right? 3" Ti overpipe
The Following 5 Users Say Thank You to Jesse@JDLAutodesign For This Useful Post:
AZFA20 (08-20-2014), Fr-s.h (08-20-2014), Raven604 (08-19-2014), SkAsphalt (09-24-2014)
Old 08-19-2014, 09:10 PM   #251
FirestormFRS
No wonder Car and Driver recommends your stuff.
FirestormFRS is offline   Reply With Quote
Old 08-19-2014, 09:22 PM   #252
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Hmmmm can i please haz a 3" TI turboback ?
Search this Thread:
Advanced Search
MAPerformance turbo kit thread! MAPerformance Forced Induction 277 02-14-2023 03:49 PM
AVO turbo kit for BRZ - initial build thread AVOturboworld Forced Induction 3109 12-01-2019 04:55 PM
All TURBO kits compilation thread subatoy Forced Induction 112 04-10-2015 10:14 PM
P&L Turbo Owners Topic Thread GTB/ZR-1 Forced Induction 4 09-01-2013 07:27 PM
Synack Turbo Drift/Drag/Road Thread Synack Tracking / Autocross / HPDE / Drifting 5 09-20-2012 02:20 AM
