Old 05-16-2012, 01:42 PM   #29
EMguy
Originally Posted by Dark_Angle View Post
I will probably leave it all alone because changing weight will change the handling characteristics of the car.
Yes, it will change the handling characteristics of the car.... For the better.
Less weight is always a good thing. (so long as it doesn't compromise safety, structural integrity, etc.)
EMguy is offline   Reply With Quote
Old 05-16-2012, 01:50 PM   #30
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
Originally Posted by jdrxb9 View Post
I'll be surprised if we see a TSB from Toyota because: AFAIK they've been putting the alignment/crash bolt info in the FSM for a while now; the FR-S manual shows the procedure with only one alternate bolt (which is actually the lower bolt used in the upperr position instead of the upper lower bolt); the bolts do not have part numbers anything like the normal Toyota alignment/crash bolts. (link,link)
Since I'm pretty sure I'm getting a BRZ, I'm hoping we 1) don't need much static camber due to low roll, and 2) I'm right about no FR-S TSB
Wow, 3/4 degree adjustment? Lol
Sccabrz192 is offline   Reply With Quote
Old 05-16-2012, 02:09 PM   #31
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
hmmmm..sorry.didnt know the omplete stock ruleset....but I would expect lots of griping about this car
...already hearing rumblings of the Miata contengent bitching about it....and 3/4 of a degree is better than nothing...
Bill
Scooby South is offline   Reply With Quote
Old 05-16-2012, 02:11 PM   #32
jdrxb9
jdrxb9's Avatar
Drives: ND2, formerly BRZ (MT/CBS)
Originally Posted by EMguy View Post
Lightweight Wheel Options in 17x7, 5x100, ET 42-54:
-Kosei K4R (14 lbs)
-Buddy Club P1 Racing SF (17.4 lbs)
-Team Dynamics Pro Race 1.2 (17.3 lbs)*
*These won't be in stock in the right size, but TD will custom make individual orders to your specs with a 6-8 week lead time. They're reasonable priced, and 17.3 lbs.
Originally Posted by Sccabrz192 View Post
Following bill's lead, you do have some rota options...
GR-A, Boost, and circuit 10 are available in +48
Subzero in a +45
Ill edit this Post if i find others.
some more:
Code:
Kosei K1-TS      avail now in ET50 - listed at kosei's website in 42, but can't find a source in that offset
Kosei K3         listed at kosei's website in 42, can't find a source
Enkei            EV5,G5,Klamp,T-Fork - all 18+ lb, 45 or 48
Enkei            RPF1 - enkei lists a ET48, but can't find a source
Enkei            RPF1,RS+M,PF01 - all options at ET43 or ET45 with custom lug pattern drilling
Motegi           MR121 ET48 17lb
Tenzo            DC-5 and DC-6 ET42 ~17.5lb
Kyowa            228 ET42 ~17lb
jdrxb9 is offline   Reply With Quote
The Following User Says Thank You to jdrxb9 For This Useful Post:
RWD_only (05-17-2012)
Old 05-16-2012, 02:14 PM   #33
Scooby South
Conedancer
So removing the exhaust and adding the shorty pipe is probably a no no.
nope....look at my thread...towards the end and you will see the pipe I am talking about.....that is legal for stock
Bill
Old 05-16-2012, 02:14 PM   #34
Dark_Angle
Dark_Angle's Avatar
Drives: 91 Turbo Mr2
Dont forget that if you lose weight then you will be messing with the distribution that I am sure that scion designed for. This could cause over/understeering characteristics. Yes you are saving weight but at what cost.
If you take off the same amount from the front of the car you would be back to the origiional distribution.
I bet you could drop about 100lbs. from the rear without trying very hard. Spare tire and tools along with the exhaust, truck carpet. Might get you close.
Dark_Angle is offline   Reply With Quote
Old 05-16-2012, 02:36 PM   #35
Scooby South
Conedancer
trunk junk has already been weighed at 35lbs...muffler is about 40lbs..
Bill
The Following User Says Thank You to Scooby South For This Useful Post:
ultra (05-29-2012)
Old 05-16-2012, 02:49 PM   #36
Dark_Angle
Dark_Angle's Avatar
Bill
Not bad
How about rear seat? The fold down and seat itself.
Old 05-16-2012, 02:59 PM   #37
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Cant remove seats. You will be reducing the yaw moment by removing trunk junk and muffler weight but slightly moving the cg location forward. In the grand scheme of things, you wont be able to tell from a vehicle dynamic standpoint.
The Following User Says Thank You to Sccabrz192 For This Useful Post:
Dark_Angle (05-16-2012)
Old 05-16-2012, 03:03 PM   #38
Dark_Angle
Dark_Angle's Avatar
Seats
Per class rules???
Old 05-16-2012, 03:27 PM   #39
AX_FRS
Drives: 05 Ford Focus ZX4
Per class rules, you can't remove seats. You know, you could actually download the rule book in its entirity from SCCA for free. And the stock section isn't that long, only about 9 pages (if you don't count all the clarifications and classing pages).
AX_FRS is offline   Reply With Quote
Old 05-16-2012, 03:50 PM   #40
Dark_Angle
Dark_Angle's Avatar
That book gives me a head ache. I currently am going through a build and the SCCA rule book makes me go cross eyed. durrrrr
Old 05-16-2012, 04:27 PM   #41
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
What class is your build for? Classes like mod and prepared can be really confusing. But stock, ST, and SP are pretty straight forward.
Old 05-16-2012, 04:53 PM   #42
Dark_Angle
Dark_Angle's Avatar
Street prepared if I remember correctly. I tossed that book in the trash and said screw it I was going to build the car I wanted and race it in whatever class. I gave up on trying to please the book.
Search this Thread:
Advanced Search
Which autocross class? jpdarty7 Tracking / Autocross / HPDE / Drifting 66 06-21-2012 06:53 PM
FORMULA D Round 1 Long Beach 2012 Discussion Thread Kids Heart Off-Topic Lounge [WARNING: NO POLITICS] 0 04-08-2012 03:43 AM
GT5 Stock GT86 Competition - March 2012 Deslock Off-Topic Lounge [WARNING: NO POLITICS] 34 04-01-2012 08:39 AM
2012 Mercedes A-Class Revealed ZetaVI Other Vehicles & General Automotive Discussions 12 03-06-2012 03:15 PM
GT5 Stock GT86 Competition - February 2012 Deslock Scion FR-S / Toyota 86 GT86 General Forum 100 03-01-2012 08:14 AM
