#155 |
Drives: Monkey-butt red FR-S
The Phoenix scca autox club (azsolo.com) runs summer events in Taylor, AZ (northern AZ between Flagstaff and the Border). My fastest clean run was 47.177. This one was dirty, I clipped the 2nd to last cone, but I felt good.
[ame="http://www.youtube.com/watch?v=IHyTjXonv1s"]fastest run Taylor.avi - YouTube[/ame] sorry the vid sux, youtube said it was "shaky" and offered to "fix it," unfortunately it distorted the video. Hankooks rs3 41psi front 37psi rear. Next tires will be star specs 225s. Also I managed to spin the car on one run. I shifted into second as I went around the first slalom on a different run, and it got away from me. The car is a blast autoxing. I have had three co drivers over three events, and they all dig the car. Last edited by Evil86; 07-09-2012 at 09:04 PM. Reason: more stuff |
| The Following User Says Thank You to Evil86 For This Useful Post: | MarkRacerX (07-11-2012) |
#156 |
Dodging cones
Drives: 2013 BRZ Limited, 93 Z28
Low turnout?
Our events are way too crowded lol |
#157 |
AutoX Addict
Drives: 08 Pontiac G8 GT,13 GBS BRZ Limited
I'm on 225/45/17 star specs and they are fantastic. Had a bunch of great runs yesterday but needed to play more with pressures. It was about 105 on the Tarmac so I was spraying a lot of water. Once the edges were scrubbed in the car came alive.
2013 BRZ Limited- GBS - 6MT -VIN #0937 ~~NYR SCCA # 18 C Street R (CSR)~~ "But there’s no mistaking the noise. This car is loud, and not in a particularly nice way. There’s no crisp exhaust note, no induction wheezing. It’s just the sound of petrol exploding in a metal box." - Jeremy Clarkson |
#158 | |
I have heard the star specs have a stiffer sidewall so 235/40 on a 7" rim may not be terrible although it will be pinched. |
#159 | |
Drives: Raven 6 speed Manual FRS
Honestly though, I need to be fixing my driving before playing with pressures too much. Coming from a front wheel drive celica GT-S, I find I tend to trail brake late into the turn to rotate the rear, rather than using the throttle to help it get around. The end result being too fast of an entry and a slow exit witha ridiculous amount of understeer. (I'm embarrassed to say my average PAX position has dropped slightly in the FR-S despite better tires and a MUCH quicker car)
2013 6-Speed Raven Black Scion FRS - Unmolested, for now
2000 Celica GT-S - "Frankenstein" CAI, Boosted2.0 Ported Header, TRD Exhaust, ES Motor Mount Inserts, ES Suspension Bushings, Southbend TZ clutch, Fidanza Flywheel. |
#160 | |
AutoX Addict
#161 | |
Not worried about the weight, but agree there's an oomph penalty to the 45s that would be exaggerated by a tight or power course. The upside is an additional 2 mph at the top of second. It's not just about avoiding the shift -- it's staying off that rev limiter, which is pretty cruel. They don't roll over (stiff sidewall, as you point out), and pyrometer shows we are using all of the tire. I probably will go for the 40s next set (soon) because our Bay Area venues are smaller. |
#162 |
Drives: 2013 FRS Asphalt
So not sure why you guys are running such high pressures. Stock pressures work great on the stock alignment. Pryometer said so. I run 225/45/17s on rs3s. Been Acutally running 35 front 32 back for added rear grip. Now on my past car with -2 degrees of camber I had to run 45 front for roll over reasons.
2013 Scion FR-S AT Picked up 5/30/2012
#163 | |
Drives: Scion, Honda
I'm still on the OEM tires and have run 35F/33R, and it's not even close to rolling over... I only ran 34F/32R with the Dunlops on my much heavier BMW for many years with success. |
#164 |
Drives: BMW 135i, soon to BRZ
While those are *probably* too high, remember that RS3's and not Star Specs, pyrometers are super useful but not a catch-all, still need to test, and size matters. Fatter star specs typically like less pressure. 17's will run a little different than 18's, etc.
If you have something this a -> b comparable, bmw on 17x7's in that same size, with hopefully the same camber, then pressure on a lighter car can possibly be dropped. If pyrometers told the whole story, Andy Hollis wouldn't spend days testing various brands, or even fine tuning his selected one. Ideally you'd have a repeatable slalom and a skidpad at various pressures with recorded temps. Then see if the result helps your times. repeat. repeat. repeat. repeat. |
#165 |
Delightfully so. Our Phoenix events vary between 90 to 150 people, but Taylor events are much smaller. This had the lowest turnout, 22 each day for a mini tour format. Six runs in the morning and six in the afternoon each day. Saturday we were done at 2:00 and Sunday at 12:30.. We could have had more runs each day, but 24 total runs were enough. With the exception of a few noobs, everyone was very experienced.
#166 |
I played with tire pressures at the test and tune for the SOPAC super regional at El Toro in Cali. I wanted to start with a stock size tire and see what happened. We ran 215 RS3s. We started high, 45/45 and worked our way down. We ended up with 41F/37R. Since then I have tried a few pounds lower in the tires, and for that specific size in RS3, it works pretty good. While I sucked, my co-driver did a very respectable 3rd in a field of 20 (RTR). This weekend, running the same pressure I was coming close to fast STR times. I tried lowering the pressure to around 36/33 and it sucked. The tires became unpredictable.
Optimum tire pressure is as high as you can go before performance falls off. |
#167 |
I'm still trying to figure out if I want to run RTR or CS.
If I do CS I'm probably going to bite the bullet and run the 245/40/17 BFG R1-S tires. If I do RTR I'll probably end up with the 235/40/17 Star Specs. I've raced on both Hoosiers and street tires before, but not for a few years. Wheels show up tomorrow... |
#168 | |
| Which autocross class? | jpdarty7 | Tracking / Autocross / HPDE / Drifting | 66 | 06-21-2012 06:53 PM |
| FORMULA D Round 1 Long Beach 2012 Discussion Thread | Kids Heart | Off-Topic Lounge [WARNING: NO POLITICS] | 0 | 04-08-2012 03:43 AM |
| GT5 Stock GT86 Competition - March 2012 | Deslock | Off-Topic Lounge [WARNING: NO POLITICS] | 34 | 04-01-2012 08:39 AM |
| 2012 Mercedes A-Class Revealed | ZetaVI | Other Vehicles & General Automotive Discussions | 12 | 03-06-2012 03:15 PM |
| GT5 Stock GT86 Competition - February 2012 | Deslock | Scion FR-S / Toyota 86 GT86 General Forum | 100 | 03-01-2012 08:14 AM |
