Old 06-26-2014, 03:05 PM   #29
WORKS
WORKS's Avatar
Drives: WORKS CARB Legal Turbo BRZ
Put two more track days under the BRZ's belt at the Sonoma Raceway NASA event on June 14th and 15th.
WORKS is offline   Reply With Quote
Old 06-26-2014, 03:15 PM   #30
glorydays
Remember me?
glorydays's Avatar
Drives: BRZ Series.Blue
Originally Posted by WORKS View Post
Should be happening soon! We're still working through making minor changes to see how they affect the vehicle. Things like using WRX "crash bolts" to gain a bit more negative camber in the front wheels, trying different alignment settings, and swapping out the BRZ suspension springs for FR-S springs.
To give you a preview for our power mod plans here are a couple more photos of our second Stage 1 development kit.
In case it isn't clear, the metal bar attached to turbo is only there to hold the turbo in place for development purposes; it is not a part of the kit.
lets just say you did make a bar like that to not hold up the turbo but to replace the cross bar that was removed, do you think it would regain its rigidity? I placed my turbo in the same location and removed that bar but kept the other side. have you noticed any change in handling with it gone? I havent noticed a huge difference but at the same time I dont push my car's handling to the limit.
glorydays is offline   Reply With Quote
Old 06-26-2014, 03:20 PM   #31
BadBRZ
Drives: Subaru
Why in the world would you want a "heat sink" on top of your alternator... Its bad enough there is no air flow there but now what air is around the alternator is going to be heated. Heat + electricity = bad, thats why most front mount kits have slim fans.
But hey, good luck!
BadBRZ is offline   Reply With Quote
The Following User Says Thank You to BadBRZ For This Useful Post:
Ayoitszritchie (06-26-2014)
Old 06-27-2014, 03:09 PM   #32
WORKS
WORKS's Avatar
Hi glorydays,
A properly designed replacement strut that routes around a turbo could definitely regain rigidity lost by removing the stock bar. This is something we’ve considered and will look into at a later stage in our kit development process. Obviously a structural bar would look very different from the bar shown above, which merely locates the turbo for mock-up purposes. We have yet to gain enough testing time on our kit to determine if the absence of the passenger side bar has a noticeable effect on handling. Thanks for your comments!
But hey, good luck!
Hi BadBRZ,
We anticipate the heat sink making only a slight increase in air temperatures around the alternator that should not affect its operation, but will verify this during testing.
We will also be testing for the effectiveness of the heat sink on intake air temperatures. That is to say, we want to make sure that the heat sink isn't soaking up heat from other areas of the engine bay (the alternator being one possibility) and therefore being more harmful than helpful.
Thanks for the question!
The Following 2 Users Say Thank You to WORKS For This Useful Post:
BadBRZ (06-27-2014), srizzors25 (06-27-2014)
Old 06-27-2014, 03:52 PM   #33
WORKS
WORKS's Avatar
Cut together some clips from the June 11th Sonoma Drift event. Enjoy
[ame]http://youtu.be/kXgm5kr9o80[/ame]
Old 06-30-2014, 02:47 PM   #34
WORKS
WORKS's Avatar
More progress on our second Stage 1 turbo development kit
(Don't mind the haze on the front bumper. The body is being wet sanded, but we needed to steal the car back from the body shop before they could finish)
The Following User Says Thank You to WORKS For This Useful Post:
Lonewolf (06-30-2014)
Old 07-02-2014, 03:39 PM   #35
WORKS
WORKS's Avatar
Video of the first start-up, dyno tuning and drive with second Stage 1 turbo development kit coming soon.
Old 07-18-2014, 06:25 PM   #36
WORKS
WORKS's Avatar
[ame]http://youtu.be/0pNbND3LtsA[/ame]
First start-up, dyno tuning and drive with our Stage 1 turbo development kit installed in our BRZ
Old 07-28-2014, 07:55 PM   #37
WORKS
WORKS's Avatar
Leon performing more tuning with brzEdit for our Stage 1 turbo development kit.
http://instagram.com/p/rAsCmoM9IO/
Old 08-01-2014, 03:51 PM   #38
Lonewolf
Lonewolf's Avatar
Drives: Moped
Why brzedit over some of the other options out there? Are there specific benefits with using brzedit over something like ecutek?
Old 08-01-2014, 04:39 PM   #39
WORKS
WORKS's Avatar
That just happened to be the tuning device we were using that day. We have been tuning the car with Open Flash Tablet, EcuTek and brzEdit.
Lonewolf (08-01-2014)
Old 08-01-2014, 05:07 PM   #40
themajesticone
themajesticone's Avatar
Drives: '13 UM86
You guys were running this FI kit back in 2013 at 86 fest. Are you waiting for CARB approval? Or will this not be sold
themajesticone is offline   Reply With Quote
Old 08-01-2014, 07:11 PM   #41
WORKS
WORKS's Avatar
A kit will be for sale. We haven't decided if we will make it CARB exempt (or make a CARB exempt version), but are considering it. Thanks for question!
themajesticone (08-03-2014)
Old 08-04-2014, 02:17 PM   #42
WORKS
WORKS's Avatar
Here's a look at using temperature paint in the development process of our turbo kit.
Our engineer applied the paint to various areas of the kit, ran the vehicle and then using the key (last photo) can get an indication of the maximum temperatures reached.
Lonewolf (08-09-2014)
Search this Thread:
Advanced Search
Rev Works - This is what we do! Rev Works Member's Car Journals 146 04-21-2014 05:58 PM
WTB:Used Works VS-XX whitefrs Wheels and Tires 5 02-20-2014 05:29 PM
Wtb works abm BlackyRose Engine, Exhaust, Bolt-Ons 0 08-09-2013 06:27 PM
From Rev Works UEL to HKS EL ramiram1984 Engine, Exhaust, Transmission 48 07-12-2013 09:17 AM
gps fix in the works Lytheum Issues | Warranty | Recalls / TSB 3 08-24-2012 02:43 PM
