Northwest AK, ID, OR, WA
Old 04-11-2014, 12:11 AM   #15
Colpup
Drives: Toyota 4runner Sport Edition
I was told the new universal ones are the issue... Mine was ordered in February and delivered today so I'm assuming I have the newest revision.
Colpup is offline   Reply With Quote
Old 04-11-2014, 12:21 AM   #16
Imrac
Drives: 13 SWP BRZ Prem
I am really surprised at Nameless so far. I think I need to call them. They were very quick to respond at first when I reached out to them. I passed a long the photos of how close the pipe was to the cylinder head (Close enough a feeler gauge was barely able to get in between). The ask a couple questions regarding my exhaust setup as I also have an after market header. I told them I didn't test fit with my OE manifold, but they still gave me a return label.
At that point the pipe was still on my car (Left it on for a couple of days). I took it back to Ishii Motors (Which, btw were very kind to me and didn't pull any punches) to have it taken back off, but I also had them test fit the OE.
There was a little bit more clearance with the OE manifold, about 1/16th of an inch. I had them take more photos which I sent back to nameless clarifying with them if they believed this was an acceptable distance with the OE manifold. I didn't want to send out the pipe and have them come back saying it was fine and me paying the shipping back.
But I haven't heard back from them since. I followed up with a couple more emails, but nothing. I realize they are a small shop, and probably don't check their email often. I have been lazy/busy/forgetful to give them a ring.
I believe they are a reputable brand, I have heard nothing but good things for them, and I believe they will take care of me. Just a little frustrating is all.
BTW, this is with the universal one.
JDL UEL Headers, Nameless Res&Cat Over&Front, Invidia Q300 Catback, AVO Dry Panel Filter, Custom ECUTek Tune by DriftOffice
191WHP/151 ft-lb on 92
Imrac is offline   Reply With Quote
Old 04-11-2014, 12:56 AM   #17
Colpup
I'll let you know next Wednesday when Ishii is going to attempt to install mine. Right now though it appears me and @Imrac are in the same boat. Kinda sucks I have to deal with this after waiting months for the pipe.
Old 04-11-2014, 01:07 AM   #18
NickFRS
Drives: 2013 Asphalt FRS
Shop sounds ignorant to me. The nameless OP/DP combo is almost the same as the OEM just slightly larger and obviously smoother curves.. All exhausts are close to the engine. You can have it coated or wrapped if you are concerned about heat. Brandon has mine now. I had no issues. The install is just kinda a pain in the ass since you have to lift the engine slightly. A inch away from the engine isn't going to do much when we are talking about exhaust temps right out of the header into a collected pipe. There will be LOTS of heat there no matter what. One inch will not disperse much heat.
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
Old 04-11-2014, 03:13 AM   #19
Imrac
What revision did you have? Was it the transmission specific version?
I am not concerned about heat at all. I am NA, so the back pressure is low enough it should be moving the hot gasses out fast enough it shouldn't get insanely hot. I am concerned about the pipe hitting the cylinder head and damaging either the cylinder head or punching a hole in the pipe.
A wrap wouldn't even be able to fit between the pipe and the cylinder head.
As for the shop sounding ignorant.. I beg to differ. There is not much movement you can do when the front pipe is connected to a fixed hanger at the rear and the collector at the front. They loosened up both (as well as the header) and tried to get as much clearance as possible, but the photos attached are the best they could get.
The Digi photos are with the OE manifold (grainier), the regular IMG photos are with my JDL UEL header.
The Following User Says Thank You to Imrac For This Useful Post:
Yamaha_R6 (04-11-2014)
Old 04-11-2014, 03:59 AM   #20
Drift-Office
Drift-Office's Avatar
Drives: AE86 / FRS / FC3S / GC8 / S14 / R32
Originally Posted by Yamaha_R6 View Post
I will probably swap out for a Motiv overpipe and Invidia frontpipe in the future.
Negative on that OP ghost rider!
Bob @ Drift-Office, LLC
Drift-Office is offline   Reply With Quote
The Following 2 Users Say Thank You to Drift-Office For This Useful Post:
NickFRS (04-11-2014), Yamaha_R6 (04-11-2014)
Old 04-11-2014, 12:01 PM   #21
Yamaha_R6
Yamaha_R6's Avatar
Drives: V8 280Z || AP2 S2K
Yo Bob @Drift-Office, I'm waiting for my JDL EL to come in. I'll need a tune from you soon!
Yamaha_R6 is offline   Reply With Quote
Old 04-11-2014, 12:22 PM   #22
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Call them. Sometimes they are slow with email since they are so busy. I have one of the original op/dp. It is specific to manual trans cars (not the factory fit model). If you have the auto trans car you'll need the factory fit model, unless they've changed stuff since I last looked at their website and the pipe.
stockysnail is offline   Reply With Quote
The Following User Says Thank You to stockysnail For This Useful Post:
Old 04-11-2014, 01:03 PM   #23
Imrac
Yeah, I am going to reach out to them Monday via phone. The op/dp did change. There use to be a Manual transmission version and a Automatic transmission version. Now they have a single "Universal" one that fits both transmissions, which I what I purchased.
I have a manual car, but the fitment issues were observed on an automatic transmission as well.
I am not bashing nameless at all. I know not everything works out perfect with aftermarket parts and I believe nameless will take care of me. I am just explaining why Ishii would be hesitant to install this pipe since they have had a couple cars with fitment issues.
Old 04-11-2014, 10:28 PM   #24
NickFRS
I got mine a year ago. That looks way to close then how it should be. Even their 3in doesn't come that close. Do you have the front pipe screwed in? which header do you have? Make sure you screw the FP into the screw point. Chances are your AM header is pulling the FP over. or maybe you got a defective FP. Put the FP in w.o it on the header. Screw it into the mount point w/the axelback. Also if you need to move around your mid pipe a bit. There are multiple mounting points that could alter the FP located.
You should be abe to stick a flat head screw driver inbetween them. Also do you have stock motor mounts? Make sure your motor mounts are on straight. Some AM motor mounts will actually lower your engine slightly.
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
Old 04-12-2014, 12:31 AM   #25
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Motor mounts will not affect clearance between the top of the pipe and the head, it is hard mounted to the header which is hard mounted to the block. Now if it were a clearance issue with the bottom of the pipe and the sub frame that would be another matter...
Decay107 is offline   Reply With Quote
Old 04-15-2014, 10:58 PM   #26
NickFRS
Which is also why I brought up having the FP screwed into the center mounting point. Just some variables.
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
Old 04-15-2014, 11:05 PM   #27
Decay107
Decay107's Avatar
Hmm, now I need to go back and take a look. I thought the center mount was attached to the transmission side of the transmission mount to move all forces back into the spring bolt/donut gasket connection. Didn't look too closely though.
Old 04-16-2014, 02:52 PM   #28
Colpup
Im at Ishii now.. I elected to not install the op/dp. They said they have had numerous people with this issue and they have had a couple people come back in and take them off after install because of how close it is to the cylinder head. When i get home i guess ill try and talk to nameless and see what if anything they can do. Atleast I'm getting the axleback put on. That should tide me over until i get the op/dp figured out. They also said that with the automatic it is even worse fitment wise.
Search this Thread:
Advanced Search
Nameless axle back - Install and initial impression. Mikem53 Engine, Exhaust, Transmission 18 10-21-2015 10:13 PM
Ishii Motors, VTR, or ? Yamaha_R6 Northwest 24 01-29-2014 07:13 PM
Anyone in SD have a nameless exhaust? Or want to help install mine? :) gonzo Southern California 0 09-26-2012 03:06 PM
HKS Special @ Ishii Motors BRZranger Northwest 1 08-31-2012 04:23 PM
Ishii Motor Industries Demo FR-S Ishii Motors Member's Car Journals 51 06-13-2012 09:51 PM
