#43 | |
Site Moderator
Drives: Stuff
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#44 |
Drives: '23 BRZ
They make them for StopTech ST40, which is I think an old Porsche pad shape. Have those on the FD for street. Is the AP pad shape unique to AP?
#45 |
Site Moderator
Drives: Stuff
Same as the Wilwood superlite 4 pot IIRC
-Dave
#46 | |
Perrin CAI|Perrin MCB|P&L header|Motiv OP/FP|MXP catback|Tein Type Flex coilovers|Eibach F/R sway bars|GS front strut brace|Street:PM HC+800/Track:Carbotech XP10|StopTech slotted rotors/SS lines|SBC RPF1s|Street:FK453/Winter:Pirelli SottoZero3/Track:Toyo R888s|Leg Sport rear spoiler|EcuTek Tuned|OEM oil cooler|4th/F1 brake lights
#47 | |
Professional Smartass
Drives: White Out FRS
#48 | |
Drives: First SWP BRZ-L
I guess I want to throw my experience into the mix regarding Hawk HPS pads. I ran through two sets of them on my WRX. Overall, I feel like they are decent street pads, with a large warning. When it was wet and roughly 40 degrees out, I had to come to a full stop from freeway speeds (after spending a good 5 or 6 miles on the freeway without touching my brakes- so they had no heat in them at all). I hit the brakes, and I got worse than OEM bite, by a wide margin- it felt like I was braking with wood 2x4s in my calipers, like others have described. I smashed into the rear of the F150 and did 5k in damage to the car, and to date, it is the only accident I have ever had that was my fault. I had more than enough stopping room for my usual driving habits, but the brakes just did not perform. NOW, after that accident, it gave me a certain level of awareness about the heat in the pad. I just stopped slightly more aggressively every now and again to keep some heat in the pads, and they performed very well for street use. On freeways where traffic might be coming up, I'd just make sure to touch the brakes once in a while or give a little extra distance. Even a few degrees into these things will make them work quite well. BUT, if you have NO heat in them at all, they won't work. I ran a 2nd set of them through the car after that. I felt comfortable enough with their stopping characteristics that I felt it was a non-issue, even after 5k worth of damage, because the pads work quite well in 99% of scenarios. The 1% being ice cold pads/rotors in the wet, or track-like driving.
First white BRZ in the country
![]() Limited SWP BRZ, 35% tint, clear bra, Nameless Performance downpipe, axelback, headers |
#49 |
driving smoother faster
Drives: Sold
North East + AP Sprint + J hook rotors + Carbotech 1521 Bobcat for street and XP12 for track = no issues with rotors and even wear. But I don't brake that hard very often. Changing fluid from Motul RBF600 that got flaky on me on a fast track (WGI) to Torque RT700. Will try plain blanks and XP10 on track next as I'm not braking hard enough to wear XP12 much. Looking for steel vented pistons like the ones BOE Fabrication sells for standard front lotus AP calipers to help keep brake fluid cool on track - anyone knows if there is anything like that available for this kit? What is the outer diameter of the pistons @JRitt? Maybe the pistons BOE sells already fit this kit, I can ask them if you give me dimensions. Thx
#50 | |
Drives: Used to Drive:Grand-Am GS #54 E36M3
#51 | |
Drives: 2012 BRZ Premium WRB 6MT
Good fluid is critical to preventing fluid fade. Probably no big surprise there! I'd definitely try something with a higher dry boiling point if the Motul isn't working for you. I have no experience with Torque, but we have a whole list of fluids that are superior to RBF600...I'd take the AP Racing R4, PRF, Super 600, or Ferodo Super Formula over the Motul.Do you have brake ducts on your car? I would go there before messing with pistons. Even though they are only interacting with the discs when set up properly (dumping directly into the center of the disc), brake ducts cool everything downstream as well. In other words, cooler discs means cooler pads, means cooler pistons, means cooler calipers, means cooler brake fluid. We have 500hp cars thrashing the same disc and caliper that we have in our Sprint Kit. There's no need to mess with the hardware. Good fluid and ducts will lower your temps and eliminate fluid fade. You can probably buy both for under $500, and you'll receive a whole bunch of other benefits as described above. Again though, I'd start with good fluid and go from there. My hunch is that will cure any fluid fade you may have experienced.
Jeff Ritter|Mgr.- High Performance Division
Exclusive Importer AP Racing and Ferodo Racing www.essexparts.com ![]() |
| The Following User Says Thank You to JRitt For This Useful Post: | CSG Mike (07-11-2014) |
#52 | |
Drives: Sold
Great feedback, thanks! Will swap to Torque RT700 brake fluid tomorrow. Good suggestion but no brake ducts for me as it's a year-round north east primarily street driven car. |
#53 |
Drives: Sold
AP Racing Sprint BBK with Torque RT700 and Carbotech XP12 performed flawlessly at the NJMP Lighning course. No need for vented pistons or brake ducts.
#54 |
Drives: 22 GR86
reviving a dead thread because i #searched!
Hi mike. I sent you a PM but couldnt' attach a picture. Here are my stock rotors after about ~120 minutes of track time (1.5 days in dry-ish conditions). Using the R12 pads that i didn't bed in
Thanks again! Matt :edit: i see OEM rotors from parts.toyota.com are only $73/ea. that's comforting since my camaro's were like 3-4x that much. Edit#2 : Mike at CSG got back to one of my private messages and said that it looks like I greatly exceeded the capability of the pads. Apparently uneven pad where is a tell tale sign of this. Thought someone may find this useful.. Last edited by evanescent03; 04-18-2022 at 07:31 PM. |
| The Following User Says Thank You to evanescent03 For This Useful Post: | Dzmitry (04-27-2022) |
| Will STi 08+ Brembos fit stock rotor? | omgwtfbbqsauce | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 04-02-2014 08:24 PM |
| Rotor Weight | ender2664 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 17 | 05-14-2013 06:14 AM |
| Has anyone cracked the OEM rotor yet? | ayau | Tracking / Autocross / HPDE / Drifting | 10 | 04-22-2013 05:41 PM |
| Turbo 4 rotor GS300 | jschendel | Other Vehicles & General Automotive Discussions | 1 | 01-16-2013 08:15 PM |
| Sprint Rotor Temperatures | Captain Snooze | Tracking / Autocross / HPDE / Drifting | 2 | 12-19-2012 01:59 PM |
