86WORX
Old 04-08-2014, 10:19 PM   #15
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
I should add, I went with coilovers because I wanted adjustment for shocks for track use, but also enough lowering to put on wheels and improve the look of the car.
If I wanted to enjoy driving the car, I would have kept the suspension stock.
-alex
The Following User Says Thank You to mav1178 For This Useful Post:
Anthonytpt (05-22-2014)
Old 04-08-2014, 10:20 PM   #16
car_roll
Drives: Nuisance BRZ
Not necessarily a benefit.
Better than the compression and rebound adjustment in one knob bs
Compression + Rebound <<<< Rebound Only < Separate compression and rebound
That is, however, if the user knows how to tune that type of suspension in the first place, so I guess beneficial is subjective.
#teamnuisance
I do like, YouTube or something, IDK.
Shameless Plug
car_roll is offline   Reply With Quote
Old 04-08-2014, 10:54 PM   #17
Thunderleg
Thunderleg's Avatar
Drives: Black BRZ
Thanks guys for all the comments! I'm still deciding on what I want, but to further the topic of stock = happiness, what also calculates into my enjoyment is closing the fender gap. So i'm looking for the best solution for a DD with being able to lower it, along with tons of spirited mountain adventures and a few autox's
Thunderleg is offline   Reply With Quote
Old 04-09-2014, 01:50 AM   #18
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
Def st co based in what you want.
I have them, and they fit my needs, which seem very similar to yours.
The Following User Says Thank You to continuecrushing For This Useful Post:
Nah (10-07-2016)
Old 04-09-2014, 03:53 AM   #19
Turdinator
Seņor Member
Turdinator's Avatar
How much lower you want to go will influence your decision as well, so look into that. Most of the performance based coilovers i have looked at don't go much below 1.5" lower than stock.
1974 TA22 Celica
2013 86 GT
Old 04-09-2014, 04:18 AM   #20
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
I've had my ST coilovers on for almost 4 months. Mine took a few weeks to settle so I had to adjust them back up but man I like them so much. Their stiffness is 4.1k front / 5.1k rear versus the twins averaging about 2.5k front / 3.7k rear (more comparos here: http://www.ft86club.com/forums/showthread.php?t=8739). Car handles great on winding roads, excellent bump travel for daily use. I don't cringe worrying about bottoming out like I did on Sportlines. Feels OEM.
They are the same rates as KW V1 which are softer than KW V3 based on what I've seen published on the web. The galvanized construction should be sufficient rust protection unless you live in a snow belt (many reputable coilovers, especially Japanese ones such as Tein or Tokico are not stainless). Even KW's top-of-the-line competition series (found in the TRD Griffon 86, for example) are galvanized because I think I've read it's stronger than stainless.
Advantage of choosing KW V1 is they have a lifetime warranty vs ST's 5-year warranty which is still a way better warranty than most reputable coilovers out there. I had a chance to get V1 for $1200 but still felt ST was a better value since I'll probably want fresh new coilovers in 5 years anyway regardless of which one I picked, so I chose to buy smart. Warranty is only honored if you drop between manufacturer's recommended range of 20-50mm.
Old 04-09-2014, 04:28 AM   #21
major quicknap
Drives: blue sardine
You have torpedoed your own argument
Captain Snooze sends his regards.
major quicknap is offline   Reply With Quote
Old 04-09-2014, 06:52 AM   #22
car_roll
not necessarily. Although someone may have no knowledge of suspension tuning, it's not hard to become accustomed to it. A quick search on google will yield many links including this one. There are also many people on this forum that can help setup their suspension.
That being said I still stand by my statement
Compression + Rebound <<<<<< Rebound only < Separate Compression and Rebound
#teamnuisance
Shameless Plug
Old 04-09-2014, 08:41 AM   #23
ZDan
ZDan's Avatar
Drives: '23 BRZ
If the damping is right out of the box, no adjustability is necessary. Having seperately adjustable rebound/compression isnt really much of an advantage over a single adjuster if its rebound/compression are well matched for the application throughout the useful range. I'd rather have separate high-speed/low-speed than separate rebound/compression.
If you're serious about damping adjustability, you can't really be much of a snob about ONLY having separate rebound/compression.
But anyway, good hi/lo damping with no adjustability or a single adjuster is better than bad hi/lo with separate knobs for rebound/compression.
Old 04-09-2014, 08:01 PM   #24
car_roll
Don't get me wrong, there are suspension systems out there that can pull off compression and rebound in one knob. Furthermore, there are MANY suspension systems that blow the kw v3 out of the water. I was speaking more for the "lower end" coilovers where a majority of them consists of crappy compression and rebound adjustment in one knob. With that being said, the separate adjustments of the v3 are really a plus in comparison.
#teamnuisance
Shameless Plug
Old 04-10-2014, 12:39 AM   #25
wallace03
wallace03's Avatar
Drives: WRB BRZ
You should make a poll. I'm looking to get coilovers as well and my needs are similar to yours, maybe track once or twice a year but 99% DD with 1-2" drop for looks. I'm between Bilstein B14 and ST, Can't figure out why Bilstein cost $150 more though.
wallace03 is offline   Reply With Quote
Old 04-10-2014, 01:23 AM   #26
gboca10
I'm thinking about coilovers too I'm between BC racing BR, ST, and Stance. The reviews for these are all over the place but from what I can tell, the ST are best quality for daily driving non-track use. The Stance are good for track use. And the BC have all the adjustability features and are pretty good as well but I'm not sure about the quality compared to the other two. I need help.
gboca10 is offline   Reply With Quote
Old 04-10-2014, 02:50 AM   #27
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Out of what you list hands down on the STs IMO. There's a reason you see lots of barely used BC coils out there. While they do the job they're not IMO comfort friendly.
Old 04-10-2014, 03:57 AM   #28
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
http://www.ft86club.com/forums/showthread.php?t=62877
Search this Thread:
Advanced Search
Tow hooks on daily drivers... zooki Off-Topic Lounge [WARNING: NO POLITICS] 22 08-29-2013 05:47 PM
LakOfSpeed Daily Drivers III JohnAyySays Northern California 9 08-25-2013 02:34 PM
Daily drivers, do you swap street and track brake pads? qoncept Tracking / Autocross / HPDE / Drifting 31 06-26-2013 04:50 AM
So first time MT drivers (or been a while). hows your daily commute experience? chickdigger802 Scion FR-S / Toyota 86 GT86 General Forum 46 06-22-2013 04:24 AM
brief comment from tsuchiya san mokinbird87 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 16 01-08-2012 01:45 PM
