#1611 | |
Drives: Kia Optima SX
#1612 |
Drives: '13 Ultramarine FR-S
#1613 |
Just got mine in, so far I love it! One question though. Mine seems to bug on increasing volume when I press the home button. Once I press it, the HU thinks its mapped to increasing the volume up and its spamming it. If I go to SPC it shows that key as blinking on volume up really fast. after I press it again once or twice it stops increasing the volume but keeps blinking on SPC. Any thoughts?
Or is this a known issue that I suck at searching for? EDIT: Fixed it with a factory reset via settings. Last edited by Necric; 10-21-2014 at 09:55 AM. Reason: Fixed |
#1614 |
Drives: 14 WRB BRZ Limited MT
Here's a summary of my Ca-Fi adventure...
What I bought:
What you'll be missing:
Installation:
Stuff that worked: All the software that came with Ca-Fi. Resuming works as intended, GPS works. Other third party apps. Wifi tether from my phone. I made a NFC tag + this to toggle my phone's hotspot Stuff that didn't for me: 1. Freezing Carhome for a custom launcher (I tried Apex). This messed up the resume feature. It resumed if I turned it back on within a couple of minutes, but longer duration, the HU restarts from scratch. 2. PowerAmp/Other media players. Resuming doesn't work. Sometimes, my amp (connected to amp on wire) wouldn't come back on when using these players unless I adjusted the volume. As soon as I did, the amp came back on. I had no issues with this on the stock apps. It is also very a PITA to use 3rd party media players + Carhome, since you can't change the defaults of what Carhome launches.. If you do want to freeze Carhome, make sure you've already installed your launcher + set the launcher as default with home2shortcut. If you don't, it'll be stuck on the Android logo screen. 3. My cheap [ame="http://www.amazon.com/ELM327-Bluetooth-CAN-BUS-Diagnostic-Scanner/dp/B0090ZJPMK"]ODBII [/ame]. Ca-Fi can find it and connect, but Torque said unable to talk to ECU ![]() Overall impressions? Pretty good for something from China. Blends in nicely, looks OEM. It's slow compared to today's phones, but its still light-years faster than OEM and other Android HUs out there (some are still on 2.3 ??? ) If you've used an Android phone, you know how to use this. Unless someone is able to completely remove Carhome and have it resume, I'll be sticking with the apps that came standard.Consult this Google Doc for other issues/info. Whew! Wall of text.. Thanks for reading.
| The Following 4 Users Say Thank You to lamune For This Useful Post: |
#1615 |
Using tech support via email sucks. It's taking almost a week to work through my problems. Currently my amp only turns on when I turn the head lights on. It is wired up correctly. There is something clearly wrong with mine and no offers from Ca-Fi to just replace the thing already. Everything I get an email, I have to respond and wait... Sometimes it's days before I get an email back. Do they have a phone number for support?
Sent from my Nexus 7 |
#1616 | |
Drives: 2014 Scion FR-S
Sent from my SM-N900T using Tapatalk |
#1617 |
I love peanut butter
Drives: 2013 SWP BRZ Limited
Is there any custom ROMs available for CaFi, such as CM? I want this but don't want to be stuck with the stock build.
#1618 |
Drives: 2013 GBS BRZ Limited
| The Following User Says Thank You to Pwolf For This Useful Post: | lamune (10-21-2014) |
#1619 |
#1620 |
#1621 |
Drives: Neptune GR86
Case by case basis of course, but a custom ROM can be loaded without custom recovery.
#1622 |
Is there a difference between removing Carhome via "factory.prop" and freezing Carhome (if you have root)??
If at all possible, I do want to go back to a custom launcher with resuming working fully. When I was testing, I had pretty sweet setup where the home button Apex, home in Apex went to Poweramp. When in PowerAmp, home went back to Apex.
#1623 | |
#1624 |
| REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo | SHIFTER | Electronics | Audio | NAV | Infotainment | 16 | 06-13-2017 07:23 PM |
| Android, bluetooth, Music, and the FR-S stock pioneer stereo | JayNutter | Electronics | Audio | NAV | Infotainment | 27 | 12-18-2014 04:54 AM |
| How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 | SHIFTER | Electronics | Audio | NAV | Infotainment | 29 | 04-07-2014 05:58 AM |
