Old 04-07-2014, 04:44 PM   #15
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Originally Posted by Shutter View Post
My rear camber is -2.5 on both sides, dropped on ST coilovers, with NO aftermarket rear arms/toe links etc).
I am dropped about 1.25"-1.5" front and rear
Is there a specific reason why you preferred different drop from front than rear?
How do you like the ST coilovers btw? Any track experience with them?
glamcem is offline   Reply With Quote
Old 04-07-2014, 05:51 PM   #16
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
awe, my bad...I meant my drop was between 1.25 and 1.5, all around...I can't remember what it is exactly, I think I did 1.25, but it settled close to 1.5
I worded that in a confusing way haha.
I've had the coilovers on for about 6k miles now, no track yet(been a busy year haha) but for daily/aggressive canyon its been great.
The Following User Says Thank You to continuecrushing For This Useful Post:
glamcem (04-07-2014)
Old 04-07-2014, 06:36 PM   #17
glamcem
glamcem's Avatar
No worries what kind of spoiler is that btw?
Old 04-07-2014, 06:42 PM   #18
continuecrushing
Oh, and I'm also running 0 toe, if you were wondering. And my front camber is currently at -1.9L and -1.4R(max negative camber on the slotted holes on the ST coilovers) But I want to get camber bolts or top hats with adjustable camber plates in the near future, as I'd like to get my camber up front around -2.5 or -3
The spoiler is a cf duckbill from modbargains.
Old 04-07-2014, 06:44 PM   #19
puma
crew chief
puma's Avatar
Drives: Race car FR-S
I know it depends on setup, track, tires and driver but i want to know how YOU would align it.
I will be running on street tires but will sometimes run on slicks, slicks will prefer more camber. As far as setup, my alignment will dictacte my setup if i need -3.5 in front and can't get over 2,8, i will buy parts to make it happen, simple as that.
We will do a lot of test and tune on the alignment, just wanted to know what to start with, i am pretty setup on -3,5 front and 2 or 3 in the rear, not sure. For caster, we will get as much as we can and toe we'll have to try depending on how the car drives but we will start at 0 everywhere.
puma is offline   Reply With Quote
Old 04-10-2014, 01:41 PM   #20
Thongpocket
Master Troll
Thongpocket's Avatar
Drives: 2013 BRZ Limited
I'm on Fortune coils with 6k and 7k springs with whiteline RLCA's. I went with -2F and -3R based on someones recommendations on here and my car feels very sticky in the turns. I havent got a chance to do a track day or autoX with it yet but I want to so I can see how much understeer is left. My car is also quite low so I should probably raise it up a bit.
Thongpocket is offline   Reply With Quote
Old 04-10-2014, 01:42 PM   #21
Thongpocket
Master Troll
I might be a little too low. Name:  uploadfromtaptalk1397148155249.jpg
Sent from my XT1080 using Tapatalk
Old 04-11-2014, 01:38 PM   #22
glamcem
glamcem's Avatar
how much did you drop your car? you have an interesting camber setup, assuming you have the default spring setup (Fortune springs) any particular reason why you chose more negative camber in the rear tires? are you on OEM sways?
Old 04-11-2014, 01:42 PM   #23
Thongpocket
Master Troll
Eibach sways and everything white line makes. I chose this setup based of a buddy of mine who races his and so far I really like the sharp turn in and controllability. My car is probably too low but after my next race I may raise it up and change. I like a bit of oversteer.
The Following User Says Thank You to Thongpocket For This Useful Post:
glamcem (04-11-2014)
Old 06-15-2014, 12:45 AM   #24
dp1
driving smoother faster
Drives: Sold
dream track alignment?
Quick update...my -3.4f/-2.7r worked very well on track, and I was set up a couple of cm lower than Ohlins spec. Had manageable oversteer at the limit on track, may also be due to pretty stiff Ohlins settings -4 clicks front and -5 clicks rear, next time will go with -6f/-7r.
Now have a new car with the same Ohlins but at their recommended -20mm drop front and -15mm drop rear and -3f/-2.5r camber with 1/16 toe in rear. You may want to zero out the toe, I just want to try this out. Will update this post with impressions after track days in early July. Car seems to drive a little better on the street with this new setup.
dp1 is offline   Reply With Quote
The Following User Says Thank You to dp1 For This Useful Post:
CSG Mike (06-15-2014)
Old 06-15-2014, 06:30 PM   #25
I suspect initial turn-in response is also more crisp at the recommended height.
Try changing the damping settings mid-session, so that you can compare the results back to back.
Do you have your LSD in yet?
Old 06-15-2014, 08:32 PM   #26
dp1
Drives: Sold
I am at 700mi now with the new car so still not pushing it hard. Will try out different damper settings at the WGI track in early July...it's a fast and unforgiving track so I hope to get things right the first time around.
Car behaves very well on the street at Ohlins spec height and new camber. I think that I will lose some crispness in handling with spec height and less camber, but don't mind having it adjusted again until it's just right. I'll have camber adjusted twice per year for summer and winter anyway. JR SC behaves differently on the manual due to trannies and I like it even a little bit more on a manual. If only this shifter were a little less notchy...heavier Raceseng shift knob helps and hope mtech springs and reinforcements below the deck will help.
OSGiken is going in on 7/16...have to figure out more track days to test it out.
Thanks
Search this Thread:
Advanced Search
Post your track alignment ayau Tracking / Autocross / HPDE / Drifting 60 07-01-2016 10:27 PM
Ohlins Road and Track special! ***Free install and alignment w/purchase!*** Corner3garage Southern California 23 02-11-2014 07:02 PM
Dream Mod For FR-S/BRZ JPxM0Dz Other Vehicles & General Automotive Discussions 22 03-08-2013 11:35 PM
Alignment help, track day comin up boonFRS Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 09-27-2012 05:39 AM
I had a dream... ashtray Off-Topic Lounge [WARNING: NO POLITICS] 1 03-13-2012 12:35 AM
