| Member's Car Journals Car journals by our members. |
Drives: 2013 SWP BRZ
Assunta's SWP BRZ - Innovate SC
This project has been realized with a lot of help from
![]() Pictures 2015-04-09 photos by Wong Photography ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() 2015-02-19 Tomei Expreme Ti Catback Type 80 Exhaust ![]() ![]() Current Mod List Black - Installed Blue - Ordered/Waiting to Install Red - Planned Engine/Exhaust/DriveTrain Innovate intercooled supercharger Tomei Expreme Equal Length Header (website) Tomei Expreme Joint pipe (website) OEM Catted straight pipe Tomei Expreme Ti Catback Type 80 Exhaust (website). Whiteline gearbox positive shift kit (website) Mtec shift lever springs (website) Whiteline crossmember mount insert bushing (website) Whiteline diff mount inserts (website) Fluids: - Tranny - Diff - Engine = Motul 8100 5W40 (~8000 km, 11700 km) Handling/Wheels/Brakes Winter Tires: Nokian Hakkapeliitta 7 (studded) 215/45R17 Winter Rims: Factory 15 spoke (gray) 17x7 +48 Summer Tires: Dunlop Direzza ZII 265/35R18 Summer Rims: Enkei RS05RR (Silver) 18x9.5 +43 (website) Track Tires: Dunlop Direzza ZII 245/40R17 Track Rims: Enkei RPF1 (custom gunmetal) 17x9 +35 Project Kics R26 black chrome lug nuts MSI Street front camber plates (website) Stock rear top hats Whiteline steering rack bushings (website) Whiteline rear control arm (toe correction) (website) Cusco rear LCA KW V3 Coilovers Interior/Exterior Escort 9500ix Radar Detector (hard wired) Weathertech Digital Fit floor mats Weathertech Digital Fit trunk liner Grimmspeed hood struts (website) Chrome amber front and rear signal bulbs (website) Licence plate white LED (LED website) Trunk light white LED Dome light white LED Vanity light white LED Door light white LED Backup light LED (website) Helix clear crystal side markers (website) Side marker white LED Passenger side exhaust hole delete (CF) (website). Stubby antenna (eBay) WC Lathewerks stainless steel STi piston shift knob (website) FR-S console stitched/padded knee pads DAMD 'D' steering wheel (website) 30% front, 20% rear tint 2014-04-02 Dyno (thanks Sunny) ![]()
This evening I installed the Grimmspeed Hood Struts. They say it helps to have a second set of hands, but this was very easily a solo task. Grimmspeed have gone green and no longer provide printed instructions, so you find them online here. What's in the box? A couple of struts, top and bottom brackets, and a bunch of bolts/nuts. Ooh, and a sticker. ![]() ![]() ![]() ![]() ![]() ![]() ----------------------------------------------------- 2014-02-22 A local member very kindly installed a hard wire for the Escort 9500ix radar detector. Here's what comes in the bag: ![]() Here's the "before" cable cluster fuck: ![]() And here's what it looks like when finished (the mute switch is right by the drivers leg, just above the seat bolster): ![]() Later I'll replace the poxy suction cups with the $10 3M'd Ebay clip and mount the detector higher so it gets a clear rear window sweep. C'mon Canada Post! ----------------------------------------------------- 2014-03-01 Replaced all interior incandescent bulbs with LED's. ![]() WARNING: do not use a metal pry to remove the door bulbs. You will short circuit your BIU (Body Integrated Unit). Ask me how I know this. You can also ask me why I'm pissed off that there was no warning anywhere of this possible outcome. I only found out what had happened because the interior door courtesy lights won't turn off (hello battery drain). I Googled it and found this thread a little too bloody late: http://www.ft86club.com/forums/showthread.php?t=21537 ... and another thread from another forum which I can't seem to link here. 2014-03-12 Dealer has replaced the BIU under warranty. I was surprised not to have to pay labour so I bought them a 12 pack of Steamwhistle for their troubles. Big thanks to Centaur for fitting the car in for both visits without appointments (the beer may have helped). Before/After pictures: License Plate: ![]() ![]() Trunk: [img]https://c2.staticflickr.com/8/7312/12889045134_***2b5913b.jpg[/img]Vanity: ![]() ![]() Door Courtesy Light: ![]() ![]() Interior (after): ![]() ----------------------------------------------------- 2014-03-02 Today I installed the Helix clear crystal side markers. Typically, this should be a quick job. I found the Diode Dynamics LED's were sitting loosely and only working intermittently. This OCD guy goes into nerdrage mode and had to strip them out several times before he was satisfied they wouldn't randomly give up on him. I ended up padding the wires to ensure they engaged properly. Fitment of the side markers wasn't perfect and both of the "A" clips disappeared into the cavity inside the front bumper. Much swearing, rattling, bashing and an extended magnet later they were recovered and swapped out for the clips on the OEM side marker. These side markers are also prone to leak and mist up. Acting on the advice of FT86Club I pre-empted doing this when they were full of water and sealed them with silicone adhesive the day before install. Before (showing that bloody "A" clip on the left): ![]() After: ![]() End result: ![]() ----------------------------------------------------- 2014-03-02 Fitted the chrome amber bulbs and finished off the LED interiors... this time without frying the BIU. ![]()
And here's where it begins. An Innovate (intercooled) supercharger courtesy of VEX Performance.
![]() ----------------------------------------------------- 2014-03-12 Supercharger install progress - Day 1 Intake is out ![]() ![]() ![]() ----------------------------------------------------- 2014-03-13 Supercharger install progress - Day 2 ![]() ![]() First listen. Bolted in, untuned. Idle only. [ame="http://www.youtube.com/watch?v=HGuBWJvRV_k&list=UUev_75IwRdGH1NrjtHVB08g"]First listen. Innovate Supercharger on a BRZ - YouTube[/ame] Another vid. [ame="http://www.youtube.com/watch?v=dANuLy6TPk8&list=UUev_75IwRdGH1NrjtHVB08g"]Another listen. Innovate Supercharger on a BRZ - YouTube[/ame] ----------------------------------------------------- 2014-03-27 First numbers on the 75mm pulley are very positive. Here's a taster: [ame="http://www.youtube.com/watch?v=6vLwKs-_dhc"]Innovate on the dyno - YouTube[/ame] Last edited by Assunta; 04-04-2014 at 02:35 AM. |
Wheel choice made:
Enkei RS05RR 18x9.5 +43 (Silver) front and rear. Shod front and rear with 265/35R18 Direzza ZII's Images borrowed from FT-86 Speedfactory: New Enkei colour "Jizz in my pants" Silver: ![]() ![]() So close. Damn, they look good...
This is what a passenger exhaust delete looks like - "test fit"... I'm just sayin'
![]() Mmm, seafood... ![]() Chrome amber bulbs are here to further the colour delete. After these go in there will be no more orange on the vehicle: ![]() MTEC shifter springs to change that sideways slam from 2nd to 3rd into a straight up push... or helping that crazy high speed downshift from 5th to 4th (wut?): ![]() Aww yiss ![]() ![]() Robispec rear top hats - for increased stroke on the KW V3's.
First drive with the Innovate. Still on studded winter tires in Calgary
[ame]http://youtu.be/EPTF6POFxZo[/ame] |
#10 |
Drives: SWP Subaru BRZ
Great mods so far! Loving every bit of it. Diode Dynamics does a great job. You're welcome for the door vanity LED's haha, I found that out for them.
As for that lake, you are a bold individual!
2013 SWP BRZ full STi Lip kit installed. Tons of other mods from interior to exterior. One of the cleanest BRZ's around in the midwest! Enjoy the build thread below. Full of pictures, exhaust clips, garage shots, and walk around video encasing its beauty. |
| The Following User Says Thank You to Khazzy For This Useful Post: | Assunta (04-12-2014) |
#11 |
Woop Dee Woop Woop Woop
Drives: Raven 6MT FR-S
where did you get that black button shift ring from?
#12 |
Drives: Asphalt Scion Frs 6MT
#13 |
Not what you think
Drives: 718 GTS 4.0
In for pics with the wheels on
#14 | |
DarkCard is correct, you can get the black shift lever cover from Japanparts.com See here for the ring and other parts. NOTE, this is not the flat black colour you see in my linked image. It's a glossier satin dark metal colour. Kind of like a tinted shade of the silver you already have. If you don't mind the flat black colour you can get the parts from Amayama. These two threads have some good info in them, amongst all the bullshit: http://www.ft86club.com/forums/showthread.php?t=45255 http://www.ft86club.com/forums/showthread.php?t=22352 |
| Innovate OBD Tuning Kit | MattQ-WP | AFRICA | 9 | 12-04-2013 07:18 AM |
| Innovate OT-2 | jamesm | Engine, Exhaust, Bolt-Ons | 0 | 12-03-2013 11:38 AM |
| innovate sc drive by? | nonicname returns | Forced Induction | 8 | 11-18-2013 04:56 PM |
| Innovate in norcal? | EAGLE5 | Northern California | 0 | 11-09-2013 04:29 PM |
| Innovate questions | Fast_Freddy | Forced Induction | 12 | 07-02-2013 03:27 PM |
