Old 04-07-2014, 12:02 PM   #43
1Cor10:23
1Cor10:23's Avatar
@steve99 as far as I know, oft can't log kc? Only kclv
Old 04-08-2014, 04:38 AM   #44
steve99
OFT will log kc learned an d knock correction. I reckon you need to download latest 1.07 open flash manager update oft nad get new template file then it will show about 30 logable parameters , can log any 12 at a time
Old 04-10-2014, 11:49 AM   #45
husker741
I have this, very similar to the first video in the OP. Got mine late last April right off the boat.
husker741 is offline   Reply With Quote
Old 04-16-2014, 01:28 AM   #46
sparx
Drives: 08 STI
I have this tip-in knock on my new 2014 BRZ. It has B01C. It pretty much happens every time I blip the throttle. My car is 100% stock. I use 93 octane with 10% ethanol.
sparx is offline   Reply With Quote
Old 10-13-2014, 09:14 AM   #47
nfaj
Drives: 2015 BRZ limited 6MT
anybody find a real solution on this on stock cars? when mentioned to the dealer, do they do anything about it?
nfaj is offline   Reply With Quote
Old 10-13-2014, 11:15 AM   #48
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
I doubt the dealer can or will do anything about it. You'll need a proper tune to take care of it if your car has it. Some cars are much worse than others about it too.
Xero-Limit is offline   Reply With Quote
Old 04-02-2016, 02:06 AM   #49
themadscientist
Hotlink Terrorist
themadscientist's Avatar
Drives: 2015 WRB BRZ Spec S
Mine does it too. I told the dealer to check for knock codes, but I suspect they didn't do it and don't care.
Engine Knock sound issue nos145 Issues | Warranty | Recalls / TSB 65 10-20-2019 05:57 PM
Knock Correction vs Knock Correction Learn values? swift996 Software Tuning 19 11-03-2015 11:09 PM
FR-S Rod knock pozer Issues | Warranty | Recalls / TSB 95 11-03-2015 10:39 AM
ca-fi knock off questions fionnsfrs Electronics | Audio | NAV | Infotainment 2 10-27-2013 02:47 PM
Knock on e85 not a problem? gdrider77 Forced Induction 76 10-21-2013 12:36 AM
