#29 |
( ͡° ͜ʖ ͡°)
Drives: '13 Whiteout FR-S A/T
@1Cor10:23 FWIW, I have an AT and that sound comes when it auto blips during downshifts.
I'm running Shell V-Power |
| The Following User Says Thank You to drewbot For This Useful Post: | 1Cor10:23 (04-04-2014) |
#30 |
I'm going to do a mini write up and update op tonight but basically after switching to ultra94, the noise is drastically reduced / non existent, only hear aggressive intake air rush noises on throttle blips.
Also, IAM immediately went from a low of. 57 to. 98 in the span of about 1 hour of driving after filling up with ultra 94 (had 6 liters of vpower left). I'm not going to bash on vpower because I know it's a good fuel but could've gotten a bad batch but for now going to fill 94. Sent from my Nexus 5 using Tapatalk
#31 | |
Drives: Audi A3 2012
(I'm using shell 91 vpower)
Moto east Ecutek /JDL UEL Header/Nameless Performance axleback exhaust-Motiv overpipe/Full Perrin CAI/BC Racing Coilover/Traklite angle 18x9/Federal 595 RS-R (245-35-18)/Blackhousing,hid 4300k headlights/Crystal eyes taillight/Anarchy Motive Heavy ShiftKnob/Cusco Sport pedals/Jpm Coachworks alcantara dash panel,cluster,shift boot,
| The Following User Says Thank You to mxsled For This Useful Post: | Xero-Limit (04-05-2014) |
#32 | |
Looking at the stock tune to my current tune, it is pretty clear why stock was much worse for me. |
#33 | |
Emperor JDM
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Why the hell would you use anything less when we have 94 octane at our disposal?! Only the idiots will tell you otherwise. The car calls for 93 octane to run optimally. Sure it runs on 91, but why bother when we can get 94?! TRUST ME, just fill Petro 94 and you'll be good to go. That's all I've been running since my first fill up and will not use anything else. My car runs like a champ.
#34 | |
The SquadWhisperer
Drives: '13 Ultramarine FR-S (STX)
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion 2017 Bluenose Autosport Club Overall Rallycross Champion Powered by Great North Performance, Jani-King Canada, and OK Tire. |
#35 | |
Emperor JDM
Pumping 91 when 94 is readily available is like choosing to be 2nd place. Sucks even more if 91 is all you have.
#36 | |
Drives: Scion FR-S
Sent from my XT1060 using Tapatalk |
#37 |
The SquadWhisperer
TRD intake with stock tune is what I'm on, so we need to look at other variables like fuel and build date.
#38 |
Drives: Scion FR-S
#39 |
Drives: Panda FR-S
What knock correction values are you getting?
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
![]() 242whp/197ft-lb on Mustang Dyno (91 octane water) 284whp/223ft-lb on Mustang Dyno (E85) Delicious Tuning |
#40 | |
If you look at his log his KC Learned (knock correction advance) is being retarded quite a lot at 5000-7000 rpm. If you could log "Knock Correction" on your OFT next time it will show you more easily the low rpm 2000-3500 tip in knock thats dropping you IAM. I did a bit of a write up on is here http://www.ft86club.com/forums/showthread.php?t=61820 Your fuel formulations are different and our octane rating system is different 98RON kind of equals 93 AKI (USA) 100 RON 94 AKI But is does appear that your fuel is slightly better. I could always log the knock but never hear it except on stock factory tune Basically you need to log the knock, if you see knock corrections are occurring consistently at an RPM/load point either FBKC or FLKC (you will have to calculate this if you have OFT) . Then pull about half the correction amount from the "Base timing B" table at that rpm/load point (it best to pull a bit from adjacent cells as well). ie if your seeing -1.5 knock correction values pull -0.75. flash the modded map and log again. looks like you will have to pull timing in similar areas to us but maybe a bit more if your on 91 AKI octane fuel. Last edited by steve99; 04-07-2014 at 04:09 AM. |
| The Following User Says Thank You to steve99 For This Useful Post: | 1Cor10:23 (04-07-2014) |
#41 |
@steve99 thanks for that steve, I've been following your AUS-related post the past couple days as well, very insightful. I've got a few mods coming in later this month and will be going stage 2. At that point, will do the fine adjustments as you have mentioned.
#42 |
Updated OP, thank you all for helping me out!
| The Following 2 Users Say Thank You to 1Cor10:23 For This Useful Post: | Kodename47 (04-07-2014), TemeCal (04-07-2014) |
| Engine Knock sound issue | nos145 | Issues | Warranty | Recalls / TSB | 65 | 10-20-2019 05:57 PM |
| Knock Correction vs Knock Correction Learn values? | swift996 | Software Tuning | 19 | 11-03-2015 11:09 PM |
| FR-S Rod knock | pozer | Issues | Warranty | Recalls / TSB | 95 | 11-03-2015 10:39 AM |
| ca-fi knock off questions | fionnsfrs | Electronics | Audio | NAV | Infotainment | 2 | 10-27-2013 02:47 PM |
| Knock on e85 not a problem? | gdrider77 | Forced Induction | 76 | 10-21-2013 12:36 AM |
