Old 10-14-2019, 06:14 PM   #925
steve99
Originally Posted by D-VO View Post
Well now that's interesting. The last set of data the OUT file had looked like this:
param name: Ram_GDI_Flow_Rate
param id: 0x00000000 <---WTH?
read width: 4 bytes
data width: 32 bits
data offset: 0 bits
float: 1
raw int: 0
signed int: 0
sign/magnitude int: 0
mode: 0x23
scaling: x
This was included in some of the RAM logging stuff that I added. I guess I forgot I did that. Anyway I removed those parameters that I added and I'm good to go again. Now on the thread I posted: http://www.ft86club.com/forums/showthread.php?t=137258
you asked that I log pulse width to see if it changes before the O2 or vice versa, which one is correct for logging pulse width on Za1jb01c?
;paramname = Base_Pulse_Width(ms?)
;paramid = 0xFFF89744
;isfloat = 1
;paramname = Fuel_Injector_1_Pulse_Width_4byteExt_E60
;paramid = 0xFFF887C8
;isfloat = 1
;paramname = Port_Injector_PW
;isfloat = 1
;scalingrpn = x,0.001,*
;paramname = Port_Injector_PW_Ram
;paramid = 0xFFF887D8
;isfloat = 1
;paramname = Direct_Injector_PW
;paramid = 0xFFF887E8
;isfloat = 1
;paramname = Direct_Injector_PW_Ram
;paramid = 0xFFF887F0
;isfloat = 1
They are commented out because I couldn't get them working right. Also, will the O2 sensor sway wildly and hold lean or rich for days like that with no codes?
Also, would the O2 sensor still be affecting fueling even though I have it set to forced open loop?
Thanks!
If the 02 sensor just swings full rich to full lean then the ecu doesnt generally detect any faults. If the 02 pegs full rich or lean for a period of time then ecu sgould detect it as cobsrant rich or lean condition or no ectivity amd log a fault.
Arrh yes on B01C you might not have all the parameters working.
Ues correct the 02 senspr isnt used for fueling when in open loop other than fuel trims learned previoisly unless they are disavled as well.
Your car would run rins on an A01G rom if needed ie to go flex or get the increased logging ability
D-VO (10-15-2019)
Old 10-15-2019, 05:03 PM   #926
D-VO
Drives: Whiteout FR-S, Evo 8 RS
Your car would run rinson an A01G rom if needed ie to go flex or get the increased logging ability
OK thanks! But what's rins?
D-VO is offline   Reply With Quote
Old 10-16-2019, 06:05 PM   #927
steve99
Thats just my fat fingers
Should read , your car will run ok on A01G
gt7877 (10-17-2019)
Old 12-08-2019, 05:28 PM   #928
hifiguy99
Drives: 19' Toyota 86 TRD
Hello all, not sure who can answer this so maybe @steve99 can help clarify this
So I recently picked up a Tactrix OP2 to flash OFT OTS tunes.
I downloaded the ROM for my car (Cal ID: ZA1JS00C) and the definitions off Open Flash's website, used the RR2EcuFlash utility to get the EcuFlash definitions. I flashed the OTS Stage 1 ROM using the definition, it flashed fine and the car runs great on 93. However, I have few questions.
The first of which is logging on the car. I am under impression that logging is only defined for ZA1JK00G (http://www.romraider.com/forum/viewt...p?f=34&t=13808)
My car is a 2019 USDM 6MT CAL ID: ZA1JS00C, so how do I go about logging? I assume the RAM addresses haven't been defined for ZA1JS00C, so is it possible to flash ZA1JK00G? Would anything break/not work correctly/get bricked if I did so? And is it as simple as taking the ZA1JK00G OTS ROM and definition and just flash it with EcuFlash?
The second question I have is that when I extracted the stock ROM, it worked fine and I got the SRF and I was able to save it just fine. However, when I tried saving it as a BIN, it complains and wants to apply zero-padding. Is my ROM fine? I have attached it. If it isn't, can I get a working ZA1JS00C stock ROM?
Thanks!
hifiguy99 is offline   Reply With Quote
Old 12-08-2019, 05:49 PM   #929
tomm.brz
Drives: brz 2017 hksv2
If you flashed stage 1 ots, it should be already a k00g inside
Maybe try put the cfg on the tactrix s microsd for k00g and should log
Old 12-08-2019, 05:52 PM   #930
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Padding the bin is normal. I could define this rom for you and pull the logging addresses out, slowing down for the year.
Td-d is offline   Reply With Quote
Old 12-08-2019, 06:24 PM   #931
hifiguy99
Pshhh, I didn't even think to check if it would work in the first place
Yeah it works lol. Thank you.
The Following User Says Thank You to hifiguy99 For This Useful Post:
tomm.brz (12-08-2019)
Old 12-08-2019, 06:33 PM   #932
hifiguy99
Eh I am using the OTS ROMs anyways, which are based on K00G. Are you talking about defining the ZA1JS00C rom?
Old 12-08-2019, 07:35 PM   #933
tomm.brz
Just keep a k00g based, more defined than those newer cal ids
Old 12-10-2019, 08:04 AM   #934
Td-d
Yup - but if the K00G OTS based maps are working - all good.
Old 12-10-2019, 08:36 AM   #935
steve99
Thanks!
All the manual 2017+ car oft roms are all based on the K00G base rom jist calid hacked to look like different roms.
With ractrix its easier\safer to jist flash the Base K00G based tunes and use K00G defs so your not dealing with jacked roms amd defs.
And ues you should be avle to log with ghe K00G logcfg.txt file
Grab it from first post but unzip amd the rename to logcfg.txt
Old 12-10-2019, 05:01 PM   #936
hifiguy99
Alright, when I install headers and go e85 I'll flash the K00G OTS rom next time.
Thanks guys!
Sent from my HD1905 using Tapatalk
Old 01-30-2020, 06:47 PM   #937
hifiguy99
Thanks!
Okay, I have another question. How do I flash back to stock? I opened the ROM in ecuflash but it is complaining about not having the correct definitions.
Reason for me going back to stock is I want to head to the dealer to see if I can get some stuff repaired under warranty. If I can't flash it back should I just wing it and see if they won't notice?
Thanks
Old 01-31-2020, 04:45 AM   #938
steve99
Thanks
Make a flash only definition , see first post in this thread
hifiguy99 (01-31-2020)
ecuflash, tactrix, taxtrix, tuning
ECUFlash - Getting close! xjohnx Software Tuning 698 03-22-2015 01:10 PM
EcuTek Flash finished but now it shows only a Partial Flash... Cross Software Tuning 32 02-12-2014 11:55 AM
Tactrix Openport jamesm Engine, Exhaust, Bolt-Ons 1 01-28-2014 09:27 PM
Visconti Tuning - Latest BRZ Flash Info Visconti Software Tuning 6530 12-24-2013 11:18 PM
Overboost Protection With OFT/EcuFlash? FrX Software Tuning 9 10-23-2013 08:27 AM
