Old 10-29-2017, 12:18 AM   #827
In1t
In1t's Avatar
Drives: Black Limited JDM BRZ
Can anyone help with a definition for JDM 2012 MT ZA1J700A?
I did some research and unfortunately there's very little information available on ZA1J700A. From what I found (http://minkara.carview.co.jp/userid/...262/parts.aspx), this ROM is compatible with ZA1JA01A (and possible ZA1JA02A).
I managed to read it using ZA1JA01A definition, however not sure how save this solution would be.
Any advice is highly appreciated.
In1t is offline   Reply With Quote
Old 10-29-2017, 07:00 AM   #828
steve99
Sounds like you have a japanese import ?? If it runs the same ax other countries then 700A A01A and A02A will ve compatable. Id flash the A02A rom if your staying stock.
Reading amd writing is pretty safe as all roms from all countries are same basic size amd flashmethod. However editing is different story defs must match exactly.
If you want to tune the car you might want ro try flashing a A01G from australia\europe their is rearly good definitions for that rom series and its highly likely it will run fine in your car.
If theirs any dramas jist make sure you keep a copy of your A series rom to flash back.
In1t (10-30-2017)
Old 10-29-2017, 07:15 AM   #829
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
+1. make your life easy, switch to A01G
The Following User Says Thank You to Wayno For This Useful Post:
In1t (10-30-2017)
Old 10-30-2017, 01:48 AM   #830
In1t
In1t's Avatar
Thanks man, this is what I thought. Yes, this it is Japanese import, so I think I'll just flash to A02A rom for now (need that fix for DI issue, already replaced the seals once) and will be looking into OFT Stage 1.
Do you guys have any experience using OFT roms with OpenPort 2 cable?
Old 11-14-2017, 08:26 PM   #831
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
So I've bent my pins in and haven't noticed any connection losses yet I'm still getting a ton of log files during one drive. I have no issues running a Bluetooth odb2 logger with torque but this always has issues. Here's a link to my files from a 30ish minute drive.
https://drive.google.com/folderview?...AsAd-jH69D2O3m
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
Old 11-14-2017, 09:32 PM   #832
ermax
ermax's Avatar
Tactrix EcuFlash Info for BRZ 86 FRS Rom flash update and logging
I had the same problem on mine. Bending pins didn’t help much either. A heavy rubber band seemed to help. I ended up getting a 6ft extension and ran it into the glovebox so it’s easier to access and it has a solid connection.
Here is the exact cable I ordered:
https://www.amazon.com/dp/B0716RW33M
Old 11-14-2017, 11:11 PM   #833
steve99
have you also removed any triggers in the logcfg.txt file they are unreliable
Old 12-26-2017, 04:11 PM   #834
Roadcone
StreetKart
i only have the trigger for if rpm over 0. I was under the impression that you had to have that otherwise it wouldnt log. the rear defroster trigger is 100% worthless i know that.
Old 12-26-2017, 06:19 PM   #835
steve99
Thats strange , ive always run with no triggers, and nothing refering to triggers.
Just either plug in tactrix, or switch power on to it via switched cable when i want to log
If it creates a bunch of log files like that its likely the connection to obd port is intermittent. Try bending both roms of pins inwards, use say an old SD memory card so you keep the pins in straight line, onlt need to bend them vert slightly like 0.5mm or so
Old 12-26-2017, 08:26 PM   #836
ermax
ermax's Avatar
Triggers never worked for me either. When no triggers are set it logs at all times. I do however log the defogger switch and use it to tag the parts of the log I am interested. I then use a PowerShell script to extract the parts of the log that have the defogger enabled into individual log files.
Old 12-27-2017, 05:08 PM   #837
freerunner
freerunner's Avatar
Drives: GT86
Trigger based on oil temp works for me. Tactrix begins logging when my engine is warm. :-) Currently on the tab right now. I'll post my logcfg.txt when I'm back at the computer. Stay tuned.
freerunner is offline   Reply With Quote
Old 12-27-2017, 07:23 PM   #838
freerunner
freerunner's Avatar
Drives: GT86
Remember to use the pointers/ids from your corresponding calid.
Here you are:
Code:
;-------------FREERUNNERS "ZA1JA01G" CONFIG------------
type = obd
protocolid = 6
mode23txaddrwidth = 4
mode23txlenwidth = 1
mode23rxaddrwidth = 0
mode23uds = 1
sortpids = 1
calcsampinterval = 1000
;debug=noout
;-----------DESCRIPTION--------------------
; Notice that the next 3 parameters have a "sampgroup = X" setting.
; There are 15 sample groups (1 - 15) that you can assign parameters to.
; Any parameters assigned to a sample group will be alternately logged in a single
; timeslot at a lower speed, the speed being 1 / N that of the sampling interval -
; where N is the number of parameters in the sample group. In this example, these
; 3 parameters will be logged at 1/3 the speed, but will also use 1/3 of the communications
; to the ECU, allowing you to log everything else faster.
; Since you can make up multiple sample groups, you can fine tune how fast different kinds of
; parameters are logged.
;-----------LOGGING PARAMETERS-------------
paramname = IAM
paramid = 0xFFF8119C
isfloat = 1
sampgroup = 2
paramname = MAF_V
paramid = 0xFFF842AC
databits = 16
scalingrpn = x,0.000076293945,*
paramname = MAP
paramid = 0xFFF87C60
isfloat = 1
;scalingrpn = x,0.133322368,*
scalingrpn = x,0.00133322368,*
;log MRP (psi relative sea level):
;scalingrpn = x,760,-,0.01933677,*
paramname = IAT
paramid = 0xFFF87C64
isfloat = 1
sampgroup = 2
;paramname = WaterTemp
;paramid = 0xFFF87C68
;isfloat = 1
;sampgroup = 2
;paramname = BattVolt
;paramid = 0xFFF87C6C
;isfloat = 1
paramname = MAF
paramid = 0xFFF87C70
isfloat = 1
type = obd
protocolid = 6
mode23uds = 1
sortpids = 1
;debug=noout
paramname = IAM
isfloat = 1
sampgroup = 2
paramname = MAF_V
databits = 16
paramname = MAP
isfloat = 1
paramname = IAT
isfloat = 1
sampgroup = 2
;isfloat = 1
;sampgroup = 2
;isfloat = 1
paramname = MAF
isfloat = 1
paramname = OilTemp
paramid = 0xFFF87C74
isfloat = 1
sampgroup = 3
paramname = Port_IPW
paramid = 0xFFF887C8
isfloat = 1
scalingrpn = x,0.001,*
;paramname = Direct_IPW_0
;paramid = 0xFFF887E8
;isfloat = 1
paramid = 0xFFF887F0
isfloat = 1
paramname = Throttle
paramid =  0xFFF89030
isfloat = 1
;paramname = TipIn
;paramid = 0xFFF89038
;isfloat = 1
paramname = Load
paramid = 0xFFF89148
isfloat = 1
paramname = Accelerator
paramid = 0xFFF8922C
isfloat = 1
paramname = AFR
paramid = 0xFFF8932C
isfloat = 1
scalingrpn = x,14.7,*
;paramname = FuelPress
;paramid = 0xFFF8936C
;isfloat = 1
paramname = Defogger
paramid = 0xFFF89393
databits = 8
isvisible = 1
sampgroup = 2
paramname = Speed
paramid = 0xFFF893C4
isfloat = 1
sampgroup = 2
paramname = RPM
paramid = 0xFFF893EC
isfloat = 1
;paramname = AF_Corr_3
;paramid = 0xFFF8A860
;isfloat = 1
;scalingrpn = x,100,*
;paramname = AF_Learn_3
;paramid = 0xFFF8A8A0
;isfloat = 1
;paramname = Tip_In_Enrich
;paramid = 0xFFF8AB08
;isfloat = 1
paramname = TotTiming
paramid = 0xFFF8ACF4
isfloat = 1
;paramname = BaseTiming
;paramid = 0xFFF8AD70
;isfloat = 1
;paramname = KCA
;paramid = 0xFFF8AFA8
;isfloat = 1
paramname = FBKC
paramid = 0xFFF8AFAC
isfloat = 1
paramname = FLKC
paramid = 0xFFF8B048
isfloat = 1
;paramname = FLKC_Offset
;paramid = 0xFFF8B066
;databits = 8
;scalingrpn = x
;paramname = vvt_intake_r
;paramid = 0xFFF8BF80
;isfloat = 1
;scalingrpn = x
paramname = vvt_intake_l
paramid = 0xFFF8BF84
isfloat = 1
scalingrpn = x
;paramname = vvt_exhaust_r
;paramid = 0xFFF8BFC8
;isfloat = 1
;scalingrpn = x
paramname = vvt_exhaust_l
paramid = 0xFFF8BFCC
isfloat = 1
scalingrpn = x
paramname = STFT
paramid = 0xFFF8D250
isfloat = 1
paramname = LTFT
paramid = 0xFFF8D254
isfloat = 1
;paramname = FuelLev
;paramid = 0xFFF8D28C
;isfloat = 1
;sampgroup = 9
;paramname = AmbPress
;paramid = 0xFFF8D290
;scalingrpn = x,0.00133322368,*
;isfloat = 1
;paramname = Cat_Temp
;paramid = 0xFFF8D298
;isfloat = 1
;sampgroup = 9
paramname = AFR_CMD
paramid = 0xFFF8D2AC
isfloat = 1
paramname = CL_OL
paramid = 0xFFF8D2E2
databits = 8
scalingrpn = x
;-----------CALCULATIONS-------------
type = calc
paramname = VVT_overlap
scalingrpn = vvt_intake_l,vvt_exhaust_l,+,3.5,-
;type = calc
;paramname = AFR_Error
;scalingrpn = AFR,AFR_CMD,/,100,*
;-------------TRIGGERS---------------
;---- START LOGGING IF ENGINE RUNNING
;conditionrpn = RPM,0,>
;action = start
;conditionrpn = RPM,0,==
;action = stop
;---- START LOGGING ON DEFOGGER
;conditionrpn = Defogger,1,==
;action = start
;conditionrpn = Defogger,0,==
;action = stop
;---- START LOGGING IF ENGINE WARM
conditionrpn = OilTemp,80,>
action = start
conditionrpn = OilTemp,76,<
action = stop
Old 12-27-2017, 07:54 PM   #839
ermax
ermax's Avatar
You have your trigger set to OilTemp but the paramid for OilTemp is missing. Maybe it is working for you because it’s dropping the miss-configured trigger and you’re actually logging all the time.
Or maybe you just didn’t post your entire config... or maybe I am blind (reading on my phone) and OilTemp is in there somewhere. Hahaha
Old 12-31-2017, 09:55 AM   #840
freerunner
freerunner's Avatar
Drives: GT86
∆ this :-)
ecuflash, tactrix, taxtrix, tuning
ECUFlash - Getting close! xjohnx Software Tuning 698 03-22-2015 01:10 PM
EcuTek Flash finished but now it shows only a Partial Flash... Cross Software Tuning 32 02-12-2014 11:55 AM
Tactrix Openport jamesm Engine, Exhaust, Bolt-Ons 1 01-28-2014 09:27 PM
Visconti Tuning - Latest BRZ Flash Info Visconti Software Tuning 6530 12-24-2013 11:18 PM
Overboost Protection With OFT/EcuFlash? FrX Software Tuning 9 10-23-2013 08:27 AM
