#267 | |
Always open rom and check some tables to see all looks ok as per first post |
#268 |
Drives: 86 GTS
Had some strange behaviour with a hard rev cut in 5th gear over 6000 rpm and then a couple times in 4th. It basically felt identical to the stock redline hard cut.
Anyone seen that with the E85 OFT tunes? Using United E85 (107 Octane) http://www.datazap.me/u/tech86/oft-stg2-el-e85-map http://www.datazap.me/u/tech86/oft-stg2-el-e85-map-0 |
#269 | |
fuel trims and afr look a bit ordinary afr bit rich top end for e85 11.6 from memory olfuel table was 12.2 , probably worth doing maf scale next time your on petrol or transfer the maf scale from a v2 petrol tune to the e85 tune i am pretty sure nothing was done to e85 tunes from V 1.5 to v2 so it still got the rich anf safe maf scaling. |
#270 | |
Drives: 86 GTS
There is almost nothing different between the v1.59 and v2.061 OFT Stg2 EL A01G maps, 3 tables in total (none related to fuel or MAF) and a CAT DTC which I though was strange. Am I taking the MAF scale from a v2.061 stg1 or stg2 petrol tune? They both look slightly different to the E85 one. |
#271 | |
if yu transfer the stage2 petrol maf scale to e85 tune check afr and knock but that scale is much better even better if you do your own. with that weird rpm limit make sure you have the flat foot shift delta set to zero as it can sometimes cut in if you rest yur fot an clutch as it works off cutch switch |
#272 | |
Drives: 86 GTS
Definitely wasn't touching the clutch pedal but I don't see FF/LC in RR. Are they defined for A01G? |
#274 |
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Anyone who's download the OFT specific Ecuflash definition - please re-download - I have made some updates to the definitions.
#275 | |
Drives: GT86
TIA |
#276 |
I don't include the LC and the FFS because they are proprietary code - what you can do is open up the RR definitions that are on the OFT site, and copy the LC and FFS code into the xml. Pretty straightforward, give a shout if you struggle.
| The Following User Says Thank You to Td-d For This Useful Post: | XCO (10-03-2014) |
#277 |
ZA1JD00D (2015 USDM AT) definition is up: http://www.romraider.com/forum/posti...mode=post&f=34
| The Following User Says Thank You to Td-d For This Useful Post: | steve99 (10-04-2014) |
#278 | |
#279 |
Sure, no problem.
| Tags |
| ecuflash, tactrix, taxtrix, tuning |
| ECUFlash - Getting close! | xjohnx | Software Tuning | 698 | 03-22-2015 01:10 PM |
| EcuTek Flash finished but now it shows only a Partial Flash... | Cross | Software Tuning | 32 | 02-12-2014 11:55 AM |
| Tactrix Openport | jamesm | Engine, Exhaust, Bolt-Ons | 1 | 01-28-2014 09:27 PM |
| Visconti Tuning - Latest BRZ Flash Info | Visconti | Software Tuning | 6530 | 12-24-2013 11:18 PM |
| Overboost Protection With OFT/EcuFlash? | FrX | Software Tuning | 9 | 10-23-2013 08:27 AM |
