86WORX
Old 04-10-2014, 04:56 PM   #29
RB Performance Brakes
RB Performance Brakes's Avatar
Drives: BRZ/FRS
BRZ/FRS Rear Brake Kit
As DAEMANO mentioned,
Racingbrake rear two piece rotor aluminum hats are designed without compromising the integrity of OE's emergency brake.
How?
We integrate a iron sleeve into our rear rotor hat to allow the use of emergency brake. Do not be confused between "Emergency" and "Parking" brake.
"Emergency" brake is for you to use it during emergency when your hydraulic brake system fails, while the "Parking" brake is for you just to park the car.
If you go with an alternate rear two piece kit, that uses an all aluminum hat.
You run the risk of damaging the hat if you apply the emergency brake while driving. Which is why they will advise not to utilize your e-brake unless your only parking your car.
Being the reason why we design or rear hats with an iron sleeve,
to safety use your emergency brake the way its supposed to be. (OE)
Weights
OE 1-pc (290x18mm) = 13.4 lbs
RB 2-pc (330x22mm) = 12.8 lbs
OE Calier = 6.6 lbs
RB Caliper = 6 lbs
Total weight saving per corner = 1.2 lbs
for our matching front
we use a 332mmx25 two-piece rotor and our 4 piston calipers weighing
10lbs less that OE's stock brakes at each corner.
RB Performance Brakes is offline   Reply With Quote
The Following 2 Users Say Thank You to RB Performance Brakes For This Useful Post:
DAEMANO (04-10-2014), Jason@DSG (05-20-2014)
Old 04-10-2014, 06:59 PM   #30
mike156
Drives: EVO
Originally Posted by Poodles View Post
Takes far less than that to rotate the engine, and the resistance isn't constant. If someone bumps the car and gets it over the hump of compression, the car will easily keep moving. Unlike using the parking brake which unless the cable breaks (unlikely) won't have this issue.
It's also illegal damn near everywhere to park in this manner as well.
I've got an e-brake less car and it's about a 10-15* grade before it will roll in 1st gear.
I'm not arguing it's a good idea though. I'm speaking from experience, it's a PITA on a street car. I chock my car at home because my driveway is slightly sloped. It's annoying as hell.
mike156 is offline   Reply With Quote
Old 05-13-2014, 03:06 PM   #31
Drives: BRZ/FRS
We have decided to offer a 15% off our front and rear bbk.
All kits are in stock and ready to ship.
Old 05-13-2014, 11:11 PM   #32
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Who here has the rb setup
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
Old 05-14-2014, 12:32 PM   #33
Drives: BRZ/FRS
https://www.facebook.com/photo.php?f...type=1&theater
Old 05-19-2014, 06:52 PM   #34
F1fletch
F1fletch's Avatar
Drives: 13 FR-S AT
I understand if RB gets 12 orders for two piece rotors, they will make them for us.
Chris, how about a group buy special pricing for two piece rotors?
F1fletch is offline   Reply With Quote
Old 05-20-2014, 05:53 PM   #35
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Are we talking about stock size 2 piece rear rotors with the e-brake provision?
industrial is offline   Reply With Quote
Old 05-20-2014, 06:49 PM   #36
F1fletch
F1fletch's Avatar
Drives: 13 FR-S AT
That is my understanding, hopefully we will receive more info from RB soon :-)
Old 05-20-2014, 09:20 PM   #37
puma
crew chief
puma's Avatar
Drives: Race car FR-S
i am in for at least 2 sets of rear in stock size, personnally i don't care for the e-brake, it is for a race car that won't have it anyway.
puma is offline   Reply With Quote
Old 09-24-2015, 08:53 PM   #38
justint5387
Drives: 4 wheels
Did this ever happen? What would the cost be?
justint5387 is offline   Reply With Quote
Old 05-04-2018, 07:23 PM   #39
SuperTom
SuperTom's Avatar
Drives: C5 Corvette, '17 Toyota 86, Jeep XJ
Im guessing this never happened going to reignite the demand for a light stock size 2pc rotor. Im open to keeping or loosing the E-brake for even more weight loss. Going to be installing the lightweight Wilwood Front kit so I need something light for the rear. Car is getting close to 2450lbs so not looking for a heavy kit
I realized I went almost 2 years without my ebrake on the Vette. The handles are notorious for the teeth to break on the lever.
SuperTom is offline   Reply With Quote
Old 10-15-2018, 05:59 PM   #40
SuperTom
SuperTom's Avatar
How?
Weights
OE Calier = 6.6 lbs
RB Caliper = 6 lbs
Did the demand for a stock size 2pc rotor ever come through. I would prefer the hat to be completely aluminum as I only ever use my ebrake for parking.
If the ultra rare situation occurred where I would have to use ebrake an emergency occurred then I wouldn't be upset to ruin a rotor if my life was saved
Search this Thread:
Advanced Search
P&L STI Lightweight rear brake kit diss7 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 57 05-31-2017 09:26 PM
Was tapped on rear bumper, options? drewbot CANADA 9 10-25-2013 01:13 PM
Aftermarket options for fixing up rear fender body edocura Cosmetic Modification (Interior/Exterior/Lighting) 1 08-13-2013 07:20 PM
Got rear ended on Saturday night. What are my options? Demotic Scion FR-S / Toyota 86 GT86 General Forum 25 07-16-2013 06:36 PM
Rear camber adjustment options? zooki Suspension | Chassis | Brakes -- Sponsored by 949 Racing 24 09-12-2012 11:46 AM
