86WORX
Old 01-06-2015, 08:58 AM   #281
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
Originally Posted by mid_life_crisis View Post
I suspect that you may be in for a letdown combining these with FI.
We'll find out soon.
texasbound972 is offline   Reply With Quote
Old 01-06-2015, 10:41 AM   #282
mid_life_crisis
Drives: FR-S 10 #103 AT
As a general rule, small changes in runner length have very little effect on FI systems because the air is being forced through the runner instead of drawn as it is with NA systems. Diameter can still make a noticeable effect, but minor tweaks of length, not so much.
Old 01-06-2015, 10:43 AM   #283
jdnguyen
jdnguyen's Avatar
Drives: 2013 FR-S Series 10 and 2010 Camry
On a side note, I received an updated tune to factor in the power blocks. On the "butt" Dyno my car seems to have more power again up. I guess we will see
jdnguyen is offline   Reply With Quote
Old 01-06-2015, 01:36 PM   #284
wparsons
wparsons's Avatar
I would be shocked to see any significant gains from the blocks with a turbo.
flickr
Old 01-06-2015, 04:20 PM   #285
alanhung85
Drives: 2014 Subaru BRZ Sport-tech Pkg
If I have Catless Headers already (Open Flash). The rest of my exhaust is stock, will the provide noticeable improvement?
alanhung85 is offline   Reply With Quote
Old 01-06-2015, 04:21 PM   #286
jdnguyen
jdnguyen's Avatar
Third Party Testing: Crawford Billet Power Blocks (BPB / Manifold Spacers)
Yes. OFT should have maps for the power blocks too
Old 01-06-2015, 04:52 PM   #287
GhostOp86
Fr-s Whiteout
GhostOp86's Avatar
Drives: 2017 civic type R #1353 2017 ss1le,
I am using spacer with my turbo kit no problem.
GhostOp86 is offline   Reply With Quote
The Following User Says Thank You to GhostOp86 For This Useful Post:
texasbound972 (01-06-2015)
Old 01-06-2015, 04:58 PM   #288
wparsons
wparsons's Avatar
Did you dyno after turbo install/tuning but before the BPB, and again after BPB with no other changes?
I'm not saying they won't work together, but I am saying that I would be shocked to see any significant (outside the normal variation between runs) from running the BPB with a turbo.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
raven1231 (09-17-2015)
Old 01-06-2015, 05:19 PM   #289
GhostOp86
Fr-s Whiteout
GhostOp86's Avatar
The tuner does I'll have to go by and grab it sometime here is my dyno 5800 altitude openflash header, invidia front pipe, TRD exhaust, intake manifold spacer 91oct and works stage 1 turbo kit.
Edit better pic of dyno
Old 01-07-2015, 02:01 AM   #290
texasbound972
USMC
Here is mine before I had the plugs changed. I was close to 50,000 miles before she blew. Bill from delicious tuning had to let off of the throttle because it was miss firing.
http://instagram.com/p/wpbT21BXYf/
Old 01-07-2015, 11:39 AM   #291
wparsons
wparsons's Avatar
Those charts are useless for seeing what the BPB do to a turbo car. The only way to show it is with two charts (ideally on the same day). One before BPB, one after, nothing else changed.
flickr
The Following 3 Users Say Thank You to wparsons For This Useful Post:
BlueDubbinTDI (02-04-2015), GT86_PRAGUE (09-17-2015), raven1231 (09-17-2015)
Old 09-17-2015, 09:08 AM   #292
Moto-P
Moto-P's Avatar
Drives: Many types of cars in R&D.
Should be great to use with a nice set of camshafts and a retune
I'd love to see this installed with HKS high duration/lift cams.
Moto Miwa
www.club4ag.com
R&D Driving Engineer, Product Planning Consultant
Consulting Member at Cusco, OEM+, RS-R.
www.club4ag.com
Moto-P is offline   Reply With Quote
The Following User Says Thank You to Moto-P For This Useful Post:
Old 09-17-2015, 11:46 AM   #293
nelsmar
The HKS cams are real mild just FYI. And quite expensive. I would no call them high duration or lift as they barely increase the lift over stock. They are designed to be used with OEM valve springs. HKS sample power graph shows very small gains (10 HP @ the crank iirc and that was WITH a supercharger). This is a lot of money to spend for a tiny power upgrade in an NA engine.
If you were upgrading your cams typically you end up shifting your power band up at a higher RPM in which this modification will actually start to hurt you. This makes the intake manifold less efficent at high RPM. When I did testing with a full exhaust and an UEL catless header the top end was fairly low. The mid range was quite nice but the top end was pretty rough... I plan on removing them and re-tuning the car without in the next few weeks.
My flickr - Canibeat
Local magazine scout
Old 10-27-2015, 12:37 AM   #294
ort895
ort895's Avatar
So i already have a DC Sports catback, i have a Skunk2 header on the way, and i plan on adding the BPB and a Skunk2 intake. After a custom tune i wonder what ill be putting down (on an automatic, sigh)
And eventfully i would like to swap out my final drive.
exciting times lay ahead
Yeah its an auto, deal with it.
ort895 is offline   Reply With Quote
Crawford Billet Power Blocks smbstyle Engine, Exhaust, Transmission 799 01-18-2016 06:01 PM
Crawford Performance Turbo BRZ! Balance Meets Power - Ignition Episode 71 ZetaVI BRZ Photos, Videos, Wallpapers, Gallery Forum 22 04-01-2014 06:19 PM
Squidbelly wants to know the best way to gut a manifold cat regal Engine, Exhaust, Transmission 14 03-07-2014 11:31 AM
short blocks? 350matt Engine, Exhaust, Transmission 4 11-04-2013 09:37 PM
Billet Oil Catch Can #BC-175 by Billet Custom Tim_Asphalt_FRS Engine, Exhaust, Transmission 48 10-27-2013 03:29 PM
